Offline analogmike
#1 Posted : 02 October 2016 00:04:07(UTC)
analogmike
Do smoke alarms go off from soldering smoke?
I'm doing wiring when the rest of the house is asleep and I don't want to cause an unwelcome fire drill.
MikeyLaugh
#2 Posted : 02 October 2016 00:17:32(UTC)
IT has never happened to me.. I think that they need a fair volume of the right smoke to set them off.. Burnt toast does it, but sulphur fumes don't seem to affect my units..
Offline Tom Jessop
#3 Posted : 02 October 2016 00:31:48(UTC)
Tom Jessop
Don't solder directly under the smoke detector & maybe set a room fan up to move air around in the room, don't direct at the soldering area just something to gently provide a little air movement .
Cheers Tom in Oz
Offline Legless
#4 Posted : 02 October 2016 10:41:28(UTC)
Legless
It depends on whether they are photoelectric or ionization.
Ionization you should be right, since a quarter of your house is on fire before they go off.
Photoelectric just a sniff of smoke and they go off.
Legless
Offline Carim
#5 Posted : 02 October 2016 10:47:44(UTC)
Carim
Perhaps do a test when everyone is awake. BigGrin
Carim
Offline DamonKelly
#6 Posted : 02 October 2016 11:13:08(UTC)
DamonKelly
Cheers Tom in Oz
A fan is always a good idea when soldering - the fumes aren't very good for you!
Damon
Offline Legless
#7 Posted : 03 October 2016 00:27:51(UTC)
Legless
You can check your smoke detector by looking on the top of the unit, if it has a radioactive symbol it's ionization.
Edited by user 04 October 2016 08:21:07(UTC)  | Reason: Not specified
Legless
#8 Posted : 03 October 2016 20:02:50(UTC)
MikeyLaugh
It should not. If you are generating that level of smoke then your not soldering correctly.
I'm assuming your soldering wiring for trains, and not tin/copper tubes for rain gutters, or copper pipe for some complex device.
The small amount of smoke that is the burning off of flux should not set of the smoke detector, though with some sensitive ones, if your directly below the detector, who knows.
This page was generated in 0.322 seconds.
