Offline Slider
#1 Posted : 05 September 2016 14:34:01(UTC)
Slider
I'm trying to figure out what type op screws will fit the Marklin 7009 portal, for instance.
And all other types of that range for that matter.
The portal whole in it's base, is alot smaller than the M rail screw hole.
I just can't find any information on this anywhere.
Anyone here knows what type I need?
Regards, Steven
Edited by moderator 07 September 2016 13:06:55(UTC)  | Reason: Catenary spelt wrong in title!
thanks 1 user liked this useful post by Slider
Offline analogmike
#2 Posted : 07 September 2016 12:21:45(UTC)
analogmike
Don't screw the masts down. It will cause all sorts of problems. The masts need to "float" a little bit.
The clip under the M-track is plenty strong and you can bend it slightly to adjust the cat wire to the center of the pan.
Mikey
Offline petestra
#3 Posted : 07 September 2016 13:30:31(UTC)
I know we all do things differently. I remove the clip on under track part of each mast. I know this is probably not good for resale eventually but I have
never liked the way it rises up the track a bit and makes things a bit wavy. To me it looks much better without them. I screw the masts down
with a C track screw. In the "old" days I used an M track screw. They work fine. Peter Cool
Offline Slider
#4 Posted : 07 September 2016 14:56:17(UTC)
Slider
Well, I don't plan on using the M rail foot all together.
My table will tilt up, so I really want to bolt them down on a small spacer piece of wood. This piece will be the same height as the M rail foot ofcourse.
I want to be able to change the look and feel of the layout by change the catenary (remove or re-apply).
Screwing down the masts will give me the strength I need for tilting the table and I can remove the masts, straight up, leaving the smallest "whole" in the scenery.
Thanks for the help, I will pillage my local trainshop soon for some screws BigGrin
Offline hennabm
#5 Posted : 07 September 2016 18:39:55(UTC)
hennabm
I used the M track screws as well on my masts.
I didn't find anything suitable in my hardware store so stuck with the M screws.
1957 - 1985 era
What's digital?
Guest (7)
This page was generated in 0.253 seconds.
