2 Pages12>
Offline laalves
#1 Posted : 03 October 2008 00:46:01(UTC)
laalves
I tried it today. My dealer received 8 (his order was larger but he says M is out of stock already). 3 were pre-ordered, and in the hour I was there, he got 2 more orders on the phone, since he announced the "in stock" status in his webpage. They seem to be going pretty fast.
Anyway, he didn't have it connected to the track when I arrived because he was struggling with the touchscreen of one of the samples. He thought the calibration of the screen wasn't good so he decided to do it again. His mistake, apparently, because it went bezerk and no more touchscreen... The screen button required to go to the setup options where "calibrate" is located was not available via hard buttons, so we connected a USB mouse which worked instantly.
We tried the 5-point calibration again, and the crosshairs kept jumping about and 8 times out of 10, I couldn't manage to calibrate the damn thing. Then when I more or less got it, I had to unplug the mouse which goes bezerk after a calibration. Then the mouse pointer kept junping to F5 on the right and pressing it, alone, even with no mouse attached! Ghostly...
So, write one off and try another CS2, which worked fine (but we didn't dare trying a calibration procedure), so now for my impressions:
- It's bigger than I thought. Looks sturdy and feels well built, just like the CS1. It does have a more luxury look, rather than the spartan, utilitarian design of the CS1;
- The screen looks very, very good in both colour and resolution (not as good as, say, my iPhone);
- The interface is very simple and is easy to use in most respects (more on that later);
- Having the lok photos to choose from in the database listing and on lok control screen is a great feature;
- The speedos have an excellent feature: when throttling up or down, there's a red triangle that goes around the dial in a linear fashion, indicating the target speed, while the "actual" speed needle accelerates to catch up. Delta loks have the triangle "attached" to the speedo dial. A very well thought and useful feature. Unfortunately, the speed knobs are rotary "infinite" encoders, just like the CS and MS...;
- Keyboard tab: Turnouts are colour coded (red, green, grey) to indicate their status as are signals;
- The manual appears very limited;
- I couldn't find any way to reset the unit to factory settings. No recessed hard button, no software option. Weird. We didn't try the PC interface, it might be available there;
- Layout tab: very nice feature, very easy to build a layout on screen. Apparently no zoom feature though, and icons are tiny;
- The interface is not as responsive as I would like it to be: some windows take some time to show up, and some time to disappear;
- The one thing I really didn't like: the damn cursor arrow is always there! It will lag after the touch pen or your fingers, getting in the way, not letting to see what's underneath it. It should only be there for mouse uses, not always there! In the layout tab, the arrow is big enough to hide the signal icons, which doesn't allow seeing the signal status. They need to make it disappear. In my view, the best way to use the CS2 is with a mouse, not with the touchscreen. This was a show stopper for me;
When I got there, I thought that, if I really liked it, I would end up with one under my arm on my way home... But the calibration weirdness added by the irritating arrow decided against that.
Judging by this very limited experienced, I'll step back and watch a bit more.
This is however, a very complex device that will require a lot of time to really get to know it. Ideally at one's home...
Edit 04/10/2008:
- The beast searches its picture database using the name of the lok stored in the mfx decoder. For example, I put my Brawa BR 75, modified with a lokpilotmfx, with the name BR 75 005 and the CS promptly put a BR 75 onthe display. Pretty neat!
- It is silent, contrary to the CS1, which has a constant hum/buzz.
Offline mmervine
#2 Posted : 03 October 2008 01:36:14(UTC)
mmervine
You are really lucky to have a local dealer where you can actually touch and see something. Thanks for the report!
#3 Posted : 03 October 2008 01:58:07(UTC)
Thanks for your report Luis.
Offline perz
#4 Posted : 03 October 2008 02:11:16(UTC)
perz
[size=1" face="Verdana" id="quote]quote:Originally posted by mmervine
<br />You are really lucky to have a local dealer where you can actually touch and see something.
Yes, it is really a luxury these days. Most of us would be totally lost without the forum reports. Thank you Luis.
Offline laalves
#5 Posted : 03 October 2008 02:31:50(UTC)
laalves
Yep, he sent me an email and I was at a client's.
I gave them a lame excuse and off I went! 15 min afterwards, I was there, hands on!
Offline jeehring
#6 Posted : 03 October 2008 04:44:49(UTC)
jeehring
This evening I spent 2 minutes demonstration with CS2 , true it looks nicely built .
It was a too short time to test it seriously. My dealer told me It tooks a few minutes to intall it .
I can only say that interface & screen look faster than CS1
The knobs are "encoder type" and give a nice sensation :providing a kind of very accurate link between the driver and the loco with accurate reactions ...
ALso : I appreciate the choice of colors ( and their denseness )
(You can also call aid panels that look quite clear & helpful )
One thing I'm sure about : this one , I'll buy it as soon as possible . No hesitation .
( CS1 never had inspired me .I'm still with my good 6021 + control 80f+keyboard+memory + MS )
BTW Cursor arrow don't disturb me ( But I didn't play with layout screen)
#7 Posted : 03 October 2008 05:17:21(UTC)
Hey Lutz, is your CS2's serial number #000000001 ?? [:O][:I]wink
Offline laalves
#8 Posted : 03 October 2008 12:37:21(UTC)
laalves
Ah! My dealer just told me that there's an option to disable the mouse pointer when the mouse is not in use!
This now has my attention! Let's see how long will I resist without getting one for myself!
#9 Posted : 03 October 2008 14:45:04(UTC)
Hi Luis Many thanks for information .. just what we needed.
Maybe better to ignore the first CS2 you saw which appears to have a problem and concentrate on the second one.
Looks like I will need to find a mouse as mine are all wireless.
I am hoping you will buy one of these and give us a full home report.
Also good to see that M have sold the first batch and are out of stock. Looks like mine will come from the next batch.
Lucky chap to have such a good dealer.
David
Offline Frostie
#10 Posted : 03 October 2008 18:30:32(UTC)
Frostie
One advantage to early buying will be price.
I purchased CS1 for $425.00 Current price is $700. Nice to have $275 more money
Current price for CS2 (AJCKIDS.COM) is $660.00. Future Price Probably $900. Do you really want to pay more.
I have enjoyed my CS1 very much and had NO problems at all.
So Why Wait !
CS/MS Digital Era 1/2
#11 Posted : 03 October 2008 19:44:41(UTC)
Frostie, I'm sure a lot of that price increase was in the exchange rate.
I usually find that new items are at their most expensive, and then you can see them being sold at a discount after a year or two.
#12 Posted : 03 October 2008 19:48:16(UTC)
Very good, Thanks for the report, Luis.
Offline laalves
#13 Posted : 03 October 2008 23:49:06(UTC)
laalves
Ahhhhhh! I couldn't resist!
I bought one already, the last of the 8 that my dealer ordered. I wasn't on time for a booster, though.
Offline dntower85
#14 Posted : 04 October 2008 00:03:30(UTC)
dntower85
I am really impressed with how fast marklin went from press release to dealers shelves. To me that is a good sign.
But I don't want to the beta tester.
(known issues)... good post Luis,
I hope you can find work arounds or figure out how to make it work.
DT
#15 Posted : 04 October 2008 00:21:13(UTC)
Well done Luis! Enjoy!
#16 Posted : 04 October 2008 00:48:02(UTC)
Hi Luis Well done. On looking at your other thread regarding known issues am I right in saying it is not working as you would wish.
David
Offline laalves
#17 Posted : 04 October 2008 00:55:43(UTC)
laalves
<br />Hi Luis Well done. On looking at your other thread regarding known issues am I right in saying it is not working as you would wish.
David
Well, AFAI could test up to now, all train controller functions work, It's just those side issues that don't yet.
BUT, it clearly is a version where not all things are working, which is becoming a trend not only from Märklin, many manufacturers do this nowadays, just check Apple's iPhone. It is becoming more and more important for manufacturers to be first in the market with issues than last in the market with a perfect product.
Has anybody here purchased a Viessmmann Commander?
Offline Macfire
#18 Posted : 04 October 2008 01:08:33(UTC)
Macfire
Thanks Luis.
Enjoyed the read but seriously I will sit back and wait for a suitable Mega set I think.
I also appreciate your Issues Topic.
Good thinking.
Juhan - A Sticky???
Lord Macca
#19 Posted : 04 October 2008 01:34:41(UTC)
Luis ,
COngrats and enjoy.
in you Known Issues topic you mentioned that the IP Address could not be changed from 192.168.1.255. Bit of a problem there.
DO not know anbout Europe but here a lot of Routers use either :
192.168.0.XXX series
192.168.1.XXX series
or
10.1.1.XXX
or
10.1.0.XXX
So if your network is not in the 192.168.1.XXX range you are in trouble.
N
#20 Posted : 04 October 2008 01:36:03(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Frostie
<br />One advantage to early buying will be price.
So Why Wait !
Price of the CS2 on Walthers Web Site is $899 USD.
N
Offline laalves
#21 Posted : 04 October 2008 01:52:17(UTC)
laalves
<br />Luis ,
COngrats and enjoy.
or
10.1.1.XXX
or
10.1.0.XXX
N
Hi Nev,
My router is @ 192.168.1.1 but actually my CS2 managed to connect to the Internet and updated itself to 1.0.3, then 1.0.5. All that with gateway set as 192.168.1.255. Weird.
#22 Posted : 04 October 2008 02:08:20(UTC)
<br />Luis ,
COngrats and enjoy.
or
10.1.1.XXX
or
10.1.0.XXX
N
Hi Nev,
Not too weird. I think that as the router was 192.168.1.1 that is the gateway. the 192.168.1.255 would be the IP Address of the CS so it would "see" the router and connect to the internet.
It would be set that high so that it would not interfere with any other DHCP addresses set by the router.
One problem there, I usually set the max address on a router to about double the current connections,sat 40 , so 255 would be outside that range and then be ignored.
Nev
Offline laalves
#23 Posted : 04 October 2008 02:35:31(UTC)
laalves
Nev, well my CS2 has IP 192.168.1.106, which I chose and then there's another option, that of gateway which it refuses to change. BUT, I didn't RTFM.... And in the manual it says the gateway options are to use only with future software, not yet released...
Offline mmrcnzjohn
#24 Posted : 04 October 2008 02:41:50(UTC)
mmrcnzjohn
so the CS2 has been released and there are already 2 updates for it!
#25 Posted : 04 October 2008 03:02:37(UTC)
192.168.1.255 would normally be the broadcast address for a subnet with a 24 bit subnet mask (255.255.255.0). You therefore should not use it for any devices. Not sure why Marklin would set the gateway on the CS2 to that address.
To get out to the internet, the CS2 needs to know the gateway for the subnet it is on, otherwise it will never connect to the internet. Does the CS2 allow you to obtain IP setup from DHCP? In that case it should then receive the proper gateway info and be able to connect outside of the local subnet.
#26 Posted : 04 October 2008 03:03:55(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by mmrcnzjohn
<br />so the CS2 has been released and there are already 2 updates for it!
Yup, that's why you and I aren't buying one right now! winkwink
Offline Tivvy
#27 Posted : 04 October 2008 05:55:30(UTC)
Tivvy
<br />192.168.1.255 would normally be the broadcast address for a subnet with a 24 bit subnet mask (255.255.255.0). You therefore should not use it for any devices. Not sure why Marklin would set the gateway on the CS2 to that address.
Was about to say that but you beat me to it BigDaddy. Very strange choice by M* although I suppose that it means that nobody can get it wrong really as almost EVERY home network in the world uses 192.168.1.x
You should still be able to change it though...[}:)]
Ep IV / V Marklin Layout
Under construction.
#28 Posted : 04 October 2008 10:43:59(UTC)
Here's one for Macca. The very first starter set with CS2, before Marklin have announced a starter set with CS2's!!
http://cgi.ebay.de/29840...amp;_trksid=p3286.c0.m14
Offline Ratatouille
#29 Posted : 04 October 2008 13:53:20(UTC)
Ratatouille
Hello everybody!Smile
Just a simple question: Was anyone of you able to mapp functions of a mfx-loco?
#30 Posted : 04 October 2008 15:31:51(UTC)
Hi Big D well found with the first starter set. Price is about as I had thought. It will contain the first batch of the CS2 I presume so will hold fire meanwhile.
Luis Interested to see there are up dates already in the pipeline and once again grateful for keeping us up to date with your findings.
David
Offline renevoorburg
#31 Posted : 04 October 2008 17:50:47(UTC)
renevoorburg
A new CS1 costs now € 299,- (as seen at various dealers at the fair in Houten today). The CS2 costs € 629.-. The ECoS does € 450 so an CS1 + 3.0 update costs a much a an ECOS (and results in an ECoS...).
René - paid € 495 one year ago for an ECoS -
Offline laalves
#32 Posted : 04 October 2008 18:25:29(UTC)
laalves
So, at least we can talk about and exchange our own experiences and facts with this nice new toy on an adequate level. wink
Hi Lutz,
Can you verify the issues I've posted? Do you think they will be addressed in the nex update?
Perhaps you could take them to the attention of one of your contacts within Märklin.
The virtual keyboard error is particularly annoying when one is naming accessories or locos: if one wants lowercase of any of the lower row keys, "shift to uppercase" (!!!) must be pressed and all letters are available in the right locations, except for "z" which is nowhere to be found. There are two "y" instead. If one wants uppercase (in lowercase mode!), you have to press the key to the right of the one wanted. Again, "Z" is missing.
Offline Frostie
#33 Posted : 04 October 2008 19:39:32(UTC)
Frostie
If a European orders a CS2 from a US Dealer do you have to declare the VAT and pay the VAT when if arrives in your home country ?
Offline laalves
#34 Posted : 04 October 2008 19:41:10(UTC)
laalves
Oh, yes....
Customs will jump on your package, drooling already and the package will arrive at your place with a neat bill attached. Not only VAT but also import duties.
#35 Posted : 04 October 2008 23:48:59(UTC)
<br />Hi Big D well found with the first starter set. Price is about as I had thought. It will contain the first batch of the CS2 I presume so will hold fire meanwhile.
David
Flash Dave, I think this set is one that originally came with a CS1. The dealer has removed the CS1 and put a CS2 in its place and increased the price. You can see where the polystyrene has been cut to allow the CS2 to fit in.
#36 Posted : 05 October 2008 00:52:48(UTC)
Hi Big D Did not look close enough at the pic. Maybe a good way to sell an old start set but he can keep it until I know the CS2 is as advertised.
Luis is doing a great job for us... I feel like I should contribute to the cost of his CS2.
David
#37 Posted : 05 October 2008 01:09:32(UTC)
The other thing about that set, Flash Dave, is the price. If I convert it to NZD it comes in at about $3000. Deducting the NZ retail price of a CS2 ($1369) gives me $1631 left, which is about $70 shy of what this starter set cost retail in NZ, with a CS1. Methinks this dealer is ripping people off with this set. Can anyone remember what the price for the 29840 set was in euros, I think it was around 800. If so this dealer is charging 800 euros for this set without the CS1, plus another 600 euros for the CS2. I'd be asking him where the CS1 is, for that price!
And the pillock states "A delivery without VAT is not possible", making this set even more expensive for overseas buyers, plus you need to pay 4% paypal fees, plus we would have to pay another 12.5% GST when the set comes into NZ - total would be around $3600.
Cheaper to buy the 29840 set with CS1 plus a new CS2 in NZ at retail prices:
29840 $1750
CS2 $1370
Total $3120 (and I'd have a spare CS1)
Offline TimR
#38 Posted : 05 October 2008 02:33:21(UTC)
TimR
Indonesia
29840 was around 800 Euros, the same as the previous 29825 and 29851.
I agree with you.. that was too expensive.
Now collecting C-Sine models.
Offline laalves
#39 Posted : 05 October 2008 03:06:31(UTC)
laalves
Dave, I like your style biggrin. I can email you my bank account details!
TBH, my impression so far is that the CS2 is, again, an incomplete product and I am a beta tester as are all early adopters.
For my current case, where my layout is not yet operative, I don't really mind, I even like to test beta products occasionally, and this is actually fun. It won't be fun, however, if Märklin does not complete the feature set and correct the bugs in say, a month or two.
My feeling is that Märklin wanted to beat ESU to the market (v3.0) by a comfortable time margin.
My advice is then: if you have an operative layout or if you don't enjoy testing products to the fullest for the sake of it, the CS2 is not for you yet. I'm confident it will, but it isn't as of v1.0.5.
#40 Posted : 05 October 2008 03:32:32(UTC)
Luis,
From your findings, the CS2 is not really ready for mass Marketing. Features Missing, incorrect screens, incorrect function icon mapping and the list goes on. It may be better to go the ESU road for about a year or two until it is all sorted out.
Hopefully M* will have done their homework and do not have to do a recall to upgrade the beast.
Nev
#41 Posted : 05 October 2008 03:35:46(UTC)
biggrinbiggrinbiggrin
Offline Fredrik
#42 Posted : 05 October 2008 12:18:37(UTC)
Fredrik
About the IP-addressing: Let me guess that if you change IP-address of the CS to (let's say) 10.0.0.2 - then the broadcast address will be: 10.0.0.255. Thus the broadcast-address automatically "follows" the IP-address.
Can't test it myself as "my" unit isn't due until next week (I hope...) - incl. the 60173 (couldn't resist...) biggrin
The lack of function mapping is off-course an issue as I too set the lights to "Zoom" - however as I still have a CS1 no big issue. But I will mention it to the development team tomorrow as well as the other issues you've found, although I can not yet confirm these.
Fredrik.
WWW: MJ-fjärren
#43 Posted : 05 October 2008 13:05:55(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by MJ-Teknik
<br />About the IP-addressing: Let me guess that if you change IP-address of the CS to (let's say) 10.0.0.2 - then the broadcast address will be: 10.0.0.255. Thus the broadcast-address automatically "follows" the IP-address.
Yes and No, as the broadcast address depends on the subnet mask. In any IP network, the number of hosts is always 2 to the power of n, - 2. Where n is = to the number of bits equal to 32 - the number of bits in the subnet mask. So, in the example above you have a 24 bit subnet mask (255.255.255.0), so 32 - 24 = 8. Two to the power of 8 is 256, so in the network 192.168.1.0 / 24 you can have a total of 256 - 2 usable hosts, which is 254. The first address in any range is always the network address (192.168.1.0) and the last is the broadcast address (192.168.1.255).
In your example, the 10.0.0.0 network is a Class A network, so normally the subnet mask is 255.0.0.0 (8 bits). We have 24 bits for the number of hosts (32 - 8), so we can have a maximum of 16777216 - 2 (16777214) hosts. Our network address is 10.0.0.0 and our broadcast address is 10.255.255.255. If our broadcast address happened to be 10.0.0.255, then we would be using a 24 bit subnet mask (255.255.255.0), and our number of permissible hosts would be 254.
Offline Fredrik
#44 Posted : 05 October 2008 14:24:40(UTC)
Fredrik
Yes, but 10.0.0.2 was only an example - could as well be anything else in a more "valid", or normally used, range. It merely supposed that the broadcast address was NOT manually choosen and thus not editable in the CS2, but if you change the IP to another value, the broadcast address "follows" to the same range.
So my guess is that if one has a router within 192.168.0.xxx, 192.168.1.xxx or 192.168.2.xxx there should be no problem, just set the IP-address within the actual range (but NOT to x.y.z.255).
Fredrik.
WWW: MJ-fjärren
#45 Posted : 07 October 2008 00:17:45(UTC)
Luis,
How did you update the CS??, Did you have it connected Via a Network Cable to the Router?
or did you download the updates and connect another PC to it?
Reason I ask is that my internet connection is about 10 Metres away from where the CS2 will be if I got one. I have a Wireless Router. with the CS1 I download the upgrades to my laptop via Wireless and then open Explorer to the CS location and do the upgrade. Laptop is connected to the CS.
Thanks in advance ,
Nev
Offline laalves
#46 Posted : 07 October 2008 01:23:12(UTC)
laalves
Hi nev,
I have the CS2 connected the same way I had the CS1, via a Linksys WET54G, which is a wireless bridge. This then communicates to the wireless router. That's how it updated itself, it simply phones home!
My top floor is an open space where I work and to connect the router to the CS in an invisible manner using a cable,I would need about 30 m of cable! And a lot of work. So, I gladly paid 70€ or so for the WET54G.
#47 Posted : 07 October 2008 01:35:01(UTC)
Hi Luis. Glad you are enjoying testing the CS2 but having paid for up front it would have been better if it had worked as you expected. I would have thought Marklin would have learned from the first CS not to supply until all the features were present and working.
However you seem positive that in time all will be well and I will take your advice not to buy yet until there is a complete product on the market.
If you get in touch with Marklin and give them your comments it would be nice to know what they say.
David
#48 Posted : 07 October 2008 01:54:51(UTC)
Thanks for the report and comments, everyone!
(did I forget someone)
Offline laalves
#49 Posted : 07 October 2008 01:55:27(UTC)
laalves
Fully agree Dave, they should have known better.
I can understand some features not working yet, from a markrting standpoint: beating others to the market.
I really can't understand the keyboard screw up, though. This should have been picked up by testing, plain and simple. Testing was not thourough, that's for sure. One would have noticed that when you try to rename a lok and press "b" a "V" shows up, and if you want a "z" or "Z", there is none! You do have two "y", though quite useful, in case you forget where the normal one is...
Also, function mapping not available is not acceptable, as it is not the fact that automatic address fetching is not working.
I have sent them my issues, let's see how it goes.
BUT, I have to say this: this the best and most complete controller I have used so far (I haven't tried the Commander), and I don't regret getting it. It is a shame that not everyone has a dealer with a demo unit connected to an actual layout 10 min away from home like I do.... biggrin
Offline Laffe
#50 Posted : 08 October 2008 16:54:22(UTC)
Laffe
I suspec that M* planned an early 2009 release, or possibly just in time for christmas 2008, but was forced to release it early because of the images leaked on the internet (you know, that design company that won an award). So they rush a release with what software is finished, and leave the rest for future updates. Might also explain why first batch seems so low in numbers.
/Laffe
Wargamer, Roleplayer, Proud Father and Born-again Model Railroader
2 Pages12>
This page was generated in 2.049 seconds.
