Offline Steve1434
#1 Posted : 18 July 2016 17:20:08(UTC)
Steve1434
Hello all.
My name is Steve and I am now the proud owner of my favourite childhood memory - my Grandfathers train set!
I don't know much about what I have here, but it is so important to me and I want to protect/preserve so my children can enjoy it one day also.
I do know that my uncles all played with it when they were young (circa 1950's) and it has made in West Germany on a lot of the items. I will try and get photos and details up to help.
Many thanks
Steve
thanks 14 users liked this useful post by Steve1434
#2 Posted : 18 July 2016 18:06:13(UTC)
Hi Steve,
Welcome to the forum!
Offline petestra
#3 Posted : 18 July 2016 19:36:53(UTC)
Welcome and have some fun too, Steve. Cheers,Peter Cool
Offline Danlake
#4 Posted : 18 July 2016 19:44:55(UTC)
Danlake
Hi Steve,
Welcome to the forumThumpUp
Brgds Lasse
Offline Steve1434
#5 Posted : 18 July 2016 20:22:36(UTC)
Steve1434
Thanks guys. Got it out and set up a small loop and with a bit of lube all but one engine pulls :) I have four german engines and one Santa Fe. I think I need to upload photos to a site and then link from there so will figure that out soon.
thanks 3 users liked this useful post by Steve1434
Offline Steve1434
#6 Posted : 18 July 2016 20:43:35(UTC)
Steve1434
thanks 8 users liked this useful post by Steve1434
#7 Posted : 18 July 2016 20:48:47(UTC)
Nice little collection, Steve! ThumpUp
The class 41 is a great looking engine!
Which is the loco that doesn't run?
Offline Steve1434
#8 Posted : 18 July 2016 23:05:48(UTC)
Steve1434
Hi RayF, thanks BigGrin The bigger of the three small ones - 3000 89028 are the model details on its side. It buzzes if you move the direction lever but I suspect a dry connection so will open her up for a look. The wheels turn with the resistance I would expect so possible that the motor is okay...
Offline SteamNut
#9 Posted : 19 July 2016 00:05:07(UTC)
SteamNut
Could be the reversing spring needs adjustment or replacement. It is the same part as your other locomotives. Part# 7194. Marklin's web site has a parts view under the service section. Good luck, be careful as the Marklin bug is dangerous to your wallet! Fred
thanks 3 users liked this useful post by SteamNut
Offline harris19
#10 Posted : 19 July 2016 08:02:31(UTC)
harris19
hi steve !
enjoy your dreams running your trains .
welcome to a very helpfull forum
harris
thanks 1 user liked this useful post by harris19
Offline Ian555
#11 Posted : 19 July 2016 08:33:36(UTC)
Ian555
You have been a member since:: 04/06/2009(UTC)
Hi Steve,
Welcome to the Forum.
Ian.
Offline Steve1434
#12 Posted : 19 July 2016 12:02:32(UTC)
Steve1434
Thanks guys :)
From a look inside I found one break in a wire:
The fwd/rev doesn't seem too clever either..
thanks 2 users liked this useful post by Steve1434
Offline Western Pacific
#13 Posted : 19 July 2016 12:33:17(UTC)
Western Pacific
Originally Posted by: Steve1434 Go to Quoted Post
Thanks guys :)
If you are used to soldering, carefully remove the insulation clear coating on both parts of the broken wire an solder it together. If you don't feel comfortable with a soldering iron, perhaps you have a friend who is. Not counting the time for the soldering iron to heat up, fixing the broken wire could very well be a 5 minutes job if being very careful not to further brake the wire coming out of the field magnet coil.
The reversing relay spring is missing. It is part 7194 and at Märklin's Internet site a small bag with 5 of them costs € 2.99. However the Märklin Online shop charges a € 19:95 shipment fee to the UK, so I would suggest trying to find a cheaper source for that spare part.
Once the broken wire has been fixed it is just a matter of cleaning the locomotive from old oil and give it a few drops of new oil, mount the relay spring and start testing it. The black screw on top of the relay is for adjusting the spring.
thanks 2 users liked this useful post by Western Pacific
Offline Rwill
#14 Posted : 19 July 2016 13:19:34(UTC)
Rwill
Always local suppliers of 7194 on ebay with minimal postage
#15 Posted : 19 July 2016 14:37:01(UTC)
Steve, as the above member mentioned get rid of the insulation on the wire, I have done a few in the past whereas I've wounded the wire around the hole a few times (this is of course if there is enough wire to do it, make sure you've taking enough insulation off so you can put a nice amount of solder onto it and than just solder the wire to it, this will give it a more solid connection point.
I would also strongly recommend you clean the wheels especially the front one as it will be essential for a good and solid contact, actually I would recommend it for all locos. to be sure the motor runs for a longer period, take the brush plate off by removing 2 screws (diagonally) and clean the armature, clean the brush plate inside and the brush tensions. you than will find it will last for another 50 years.
Offline Steve1434
#16 Posted : 19 July 2016 17:48:52(UTC)
Steve1434
Thanks for the replies all :) very helpful forum indeed! I will order the missing part and dust off my small iron - usual soldering requires a cricket bat style tip for me.
#17 Posted : 21 July 2016 19:03:12(UTC)
If you don't feel up to dealing with it, I should be able to help. I'm not too far away in OXON.
Offline Steve1434
#18 Posted : 22 July 2016 18:51:27(UTC)
Steve1434
Bits arrived today so I did the soldering and fitted the spring, also stripped and cleaned and she is running sweet :)
Thanks for the help all. Now to make a suspended ceiling in my garage.....
#19 Posted : 24 July 2016 20:52:23(UTC)
Oh, excellent news. glad to hear it has all gone well.
This page was generated in 0.639 seconds.
