Offline Harryv40
#1 Posted : 19 May 2016 02:28:21(UTC)
Harryv40
I need to extend the length of the lead on my Mobile Station 2 to the connection box
I believe Marklin make several different leads which is the correct one ? 60126?
Any ideas?
Harry
#2 Posted : 19 May 2016 08:05:48(UTC)
None.
To make it correct when using the CS2: 60126+60125+60124.
People successfully jammed the MS2 into the 60126 and then the 60126 into the CS2. But this is a not-terminated siding of the CAN bus.
Märklin have no proper solution for the MS2/trackbox combination.
The 60126 may still work. You just have to jam a 10-pin plug into a 9-pin socket and a 9-pin plug into a 10-pin socket.
Offline Harryv40
#3 Posted : 19 May 2016 09:00:58(UTC)
Harryv40
None.
What is the point of all the different extension leads when they don't fit any of the system controllers!
#4 Posted : 19 May 2016 09:33:41(UTC)
The CAN bus needs termination at both ends. The MS2 is a siding without termination - length is limited to assure reliable operation.
There are third-party and DIY extension cords you can use at your own risk.
Märklin only offers solutions with proper termination - and only for the Central Stations.
#5 Posted : 19 May 2016 10:50:37(UTC)
The 60122 may not be "just a cable", but for the 60113/6 it gives you 1.8m of extra length.
This page was generated in 0.289 seconds.
