Offline sonra
#1 Posted : 13 May 2016 17:27:57(UTC)
sonra
Israel
Hi guys
I order the set that include 8830+9130+9136 . The set reached my place this week but all guide are in German .
To me sorrow I don't knw a word in this language . Has any one this set that he can guide me ??
Regards Doron
Doron
#2 Posted : 14 May 2016 04:40:43(UTC)
There used to be a PDF floating around here that could be copied into Google Translate.. I found the link in the search on here, but the website is now defunct..
A better way is to ask questions here.. Many of us have these wagons and I have the wheel cleaner..
Offline sonra
#3 Posted : 14 May 2016 11:35:56(UTC)
sonra
Israel
Thanks for try to help .
1)On what address are the units and are all the same
2) what function key ?
Doron
#4 Posted : 14 May 2016 12:13:21(UTC)
1) Address 78 is the default address... Hmmm.. It seems that the default address of the vacuum cleaner might also be 49.. There is also mention of 79 and 3 - seems to be dependant on the decoder installed into the unit.. (ESU Lokpilot likes to start at 3).. I would try 78 first.. Have a read of this older post: https://www.marklin-users.net/forum/yaf_postsm261143_Lux-3-rail-digial-track-cleaner.aspx
2) Throttle sets speed of vacuum. Light (F0) switches the vacuum off and on.. F4 selects some speed range - not sure about that one..
Offline NZMarklinist
#5 Posted : 14 May 2016 13:25:36(UTC)
NZMarklinist
From what I know about the LUX System, there are several decoder options that they can be ordered with, and I think that establishing what decoder your unit has will be a good start. So either from the documentation included, or by having a look inside the unit. I believe they are easy enough to get into.
Then try here although the set number may help you to investigate on the website; http://www.lux-modellbau.de/
You can choose the language you wish to view the site in at the top left of the home page ! Just checked, the English pages are still under construction Cursing
Also what about copy and pasting your manual pages into Google translate ??!!
Another way is to use a Central Station to do an address search, if you have one ?
Glen
Auckland NZ
Offline sonra
#6 Posted : 14 May 2016 13:39:57(UTC)
sonra
Israel
Hi guys
Thanks for help the address of 3 units are 78
I tries to scan one of the guides ans use the Google Translator but because the pages of guide has pictures built in the Translator did not work
Doron
Doron
Offline nitramretep
#7 Posted : 14 May 2016 14:09:55(UTC)
nitramretep
Doron,
Could you let us know how the Lux units work and if you are happy with them? Thank you.
Offline sonra
#8 Posted : 14 May 2016 14:40:25(UTC)
sonra
Israel
I run the set for first time today and it solved me a problem in hidden part of my layout . I use C type rails
Doron
Offline sonra
#9 Posted : 17 May 2016 12:19:00(UTC)
sonra
Israel
I sent an email to Lux (info@lux-modellbau.de ) and they emailed me English manuals
Doron
thanks 2 users liked this useful post by sonra
#10 Posted : 17 May 2016 13:05:57(UTC)
You need to use some OCR (Optical Character Recognition) software to convert the images into text. Adobe Acrobat has OCR built in as does Microsoft OneNote.
If you don't have any OCR software, post the scanned files here and I can convert them for you (use the forum attach feature to attach a file).
Edit: Just saw your note re the English version of the manuals - are you able to post them here?
Offline sonra
#11 Posted : 17 May 2016 13:43:22(UTC)
sonra
Israel
Instruction art-no. 8830, 8831, 8832.pdf (974kb) downloaded 185 time(s). Instruction art.-no. 9130, 9131, 9132.pdf (1,813kb) downloaded 137 time(s). EN-MLR-1 Wagen.pdf (2,531kb) downloaded 80 time(s).
Doron
thanks 4 users liked this useful post by sonra
This page was generated in 0.345 seconds.
