Online JohnMishler
#1 Posted : 21 April 2016 20:59:21(UTC)
JohnMishler
I've read and re-read documentation and tried a couple of times but my skull is evidently too thick. How do I adjust the CV values for a M83 using a MS2? I'm using MM protocol and want to adjust the values at CV34 and CV35 to tie ports 1 & 2 to simultaneously switch turnouts connected to them and ports 3 & 4 to do likewise.
Check out progress on my layout here.
#2 Posted : 21 April 2016 21:58:50(UTC)
CV 34/35 may be setup using either MM or DCC mode
As you have a MS2, the DCC option is a bit cleaner but it involves temporarily ..
- setting DCC on the m83 (DIP switch 10 on)
- setting the MS2 Accessory protocol to DCC
Then you (temporarily) define a DCC Locomotive, as this is used to send the programming stuff to the track. (address is irrelevant)
Note:
- make sure your m83 is the only thing connected to the MS2 in the following
- ideally you would have an external power supply for the m83 - but this is not essential for this little job
From the Loco edit screen (Shift-Loco)
- scroll down once to select programming
- scroll (Shift-dial) to address 34
- read
- change to the value you wish (1=3Way turnout, 2=Doubleslip)
- write
- scroll (Shift-dial) to address 35
- read
- write
- Exit out to main menu
Revert
- MS2 Accessory Protocol to MM
- Set m83 DIP 10 to off (Power Off, change switch, power on)
Test
if you do want to persevere with MM mode, please refer
http://www.maerklin.de/f...mmierung_M84_Signale.pdf
This is designed around the 6021 but can be implemented with the MS in a (even more) convoluted way.
Online JohnMishler
#3 Posted : 22 April 2016 04:00:08(UTC)
JohnMishler
I tried for about an hour this evening and still couldn't get it accomplished. I really don't know what I have done wrong but I'll give it a try again at some point. Thanks for the advice.
This page was generated in 0.224 seconds.
