Offline baggio
#1 Posted : 18 April 2016 03:03:42(UTC)
baggio
I was wondering if K track is NOT intended to be used without ballasting. I have tried to use it as it is and I ma not happy with the looks or the performance. The track is either very hard to assemble (hands get a painful experience) or they come apart easily once assembled and disassembled and do not look straight any more.
Has anyone had the same experience?
In addition, the K track turnouts are problematic: the locos jump - small Marklin locos in particular, and the Roco locos and wagons sometimes just clash with some small part of the turnouts. One side of the wagon works and other does not travelling in the same direction.
Are there BETTER K track turnouts? Or can one make them more "friendly"?
Thanks.
Offline rbw993
#2 Posted : 18 April 2016 03:33:22(UTC)
rbw993
Which turnouts are you using? Part numbers please.
Roger
Offline baggio
#3 Posted : 18 April 2016 03:41:46(UTC)
baggio
Hi, Roger:
22715 and 22716 turnouts - suitable for 2 rail and 3 rail dual mode operation.
Offline PMPeter
#4 Posted : 18 April 2016 04:23:54(UTC)
PMPeter
Thanks.
I love K track and wish I would never have started with C track. However, it is not very user friendly if you want to assemble and disassemble it on a regular basis. The end connectors can get bent quickly and then further assembly is difficult until you straighten them. I solder all my K track connections except at isolation points and I have no problem with it. You just have to make sure that the contacts overlap properly when you join two pieces. If there is significant resistance in trying to push two pieces together, chances are that one of the contacts is interfering with the plastic isolation piece above the contacts. A very slight twist downward usually solves this and the tracks snap together.
I do not know why you say it is not intended for ballasting. It certainly is and even M used to provide details on how to do it. You do need a base such as cork, Merkur, Noch, etc. to make it look proper. K track direct on plywood does not look good in my opinion.
I do have a problem with the older switches with built-in solenoids. The movable portion of the points lift up when a magnet passes over them and cause a derailment or short circuit. So I have to be careful to place my magnets (for reed switches) at a point where the locos' wheels will keep the points section down. I am now replacing most of these switches with the newer style with detachable switch motors. They do not lift up to a magnet due to different design.
thanks 4 users liked this useful post by PMPeter
#5 Posted : 18 April 2016 11:00:20(UTC)
M-locos shouldnt have problems with the "stud-ramp" for the slider crossing the rail. That is indeed strange!
-But for the other problems;
YES; hands and fingers will hurt after prolonged work with the stuff.
YES; You can use it perfectly, even unballasted.
YES; Conections becomes more loose after some use. It is better not to handle it too much, as it is so flimsy...
Non-M locos can have problems with the mentioned "puko-ramp" for the ski-slider. Some -originally DC- models doesnt have enough free space underneath for the slider.
Non-M waggons can have problems with tracking, if the wheels has not been changed to proper AC-ones, or does not have the right spacing. With a spacing of 13.9mm between the inside of the flanges, you should have no problem with K-track.
#6 Posted : 18 April 2016 12:09:20(UTC)
Hello Baggio,
I am not sure what you mean, by way of your double negative, could you please clarify what you mean
Clearly my curiosity is piqued by your comment since I have considered the problem in the past.
PJ
#7 Posted : 18 April 2016 12:46:43(UTC)
Well here we have a topic and this again is a complete surprise to me, although I can relate to joining the tracks can sometimes somewhat hard or difficult and suppose if you take them apart and connect them again several times or even more it gets easier every time, I've used k-tracks now for over 40 years and have never had a problem with them, however I must point out I don't take them apart very often and I have several turnouts and tracks left over. I bought the older version of the sleek turnouts and had some trouble with the moveable heart section and to be honest if I could buy turnouts from some other company I would, the turnout mechanism is something from a failed junior experimental experience. complicated, to many moving parts etc etc.
sorry can't help you with this one
but the trains are running over them without any problems.
Offline BrandonVA
#8 Posted : 18 April 2016 17:16:47(UTC)
BrandonVA
Some of the newer M locos have shorter sliders, with the long turnouts and double slips you have to make sure they are mounted and screwed down well to ensure they are very flat. If they are slightly bowed there can be problems with short sliders or very light locomotives (Kof, etc). Overall I have found K to be very reliable, but I use it for permanent layouts.
-Brandon
Offline baggio
#9 Posted : 19 April 2016 01:17:47(UTC)
baggio
I meant that my usual habit of using C track (or all other track I have used) WITHOUT spending time and effort in ballasting the track, so as to use it "right out of the box" does not work for K track; meaning that K track are meant to be ballasted, with cork or other material, and NOT to be taken down and re-positioned a few months later.
When I re-use K track, the whole line of straight track is loose and does not look straight.
The power to two-rail locos is reduced and so is the speed. (I used K track for dual two and three rail locos - in that sense , it works).
I just put it away, for now at least, and simply put a Roco Geo R3 set (equivalent to Marklin R2) and made a nice oval with one turnout while inside I have a Marklin R 1 set (that I was hoping I could adapt as in the geometry discussion - no luck there) that is dividing the Marklin oval to carve out parking space. ThumpUp
Offline baggio
#10 Posted : 19 April 2016 05:12:38(UTC)
baggio
I was referring to two-rail locos that I was using with K track (in a dual mode oval).
I just set it aside and for now am using a Roco outside oval (DC) and a R1 Marklin oval inside it. This way I run two locos rather than three at the same time, but so far I do not miss the third loco and concentrate instead on the two that are running. BigGrin
#11 Posted : 19 April 2016 06:19:42(UTC)
floor/table layouts would mean that you constantly either remove or reorganize the track layout and whether you use M or K track the stiffness would disappear after a while, knowing what it does or doesn't do for these type of casual layouts I assume C-tack would be the most suited track system. I can't see however what ballasting has got to do with it as it is not intended as a permanent layout without scenery it may give you the extra ecstatic look,
so what you've described and you aired your disappointed experience, I would suggest stick with C-track, it more or less fulfills all the requirements you need and eliminates all the negatives you've recognized
#12 Posted : 19 April 2016 06:58:48(UTC)
I did tested by use ballast and water glue to the K tracks.
Never get problem so far i did used by test.
The only i don´t like are stainless steel on the rail. Mad
#13 Posted : 19 April 2016 16:25:32(UTC)
Hello Baggio,
Thank you for your reply.
May I precede my response by noting that we all enjoy Märklin in numerous and diverse ways and I respect every one of them.
If your modus operandi is "out-of-the-box" or to be dismantled and re-assembled then perhaps K-track is not for you, but this is an individual decision.
However this is my K-track story:
In the mid 1980's when I became very interested in Märklin I carefully considered how I wanted to go about it. I decided that I wanted a "permanent" (are they ever complete or permanent ? ) layout with "lifelike" track and "roadbed", signals (I decided on Brawa), stations and related areas, realistic overhead catenary (I decided on Sommerfeldt) and scenery (I decided on Woodland Scenics).
Looking at the available track from Märklin I decided on K-track (being aware of the extra particulars required with use of K-track)
Not long after, C-track became available but I did not think the "ballast" was lifelike-enough to come near the K-track with appropriate ballasting.
Thus I settled on K-track. It clearly needed roadbed ballast and peripheral ballast to make the most of it's realistic appearance.
I searched further. In my first layout I used Mössmer, a foam plastic, molded to various, including Marklin K-track. This is now currently produced by Noch with some adherent ballast granules. However I found that the foam deteriorated after 10-15 years and became a contracted degenerate gooey mess:
In my current layout (built commencing 1998) I used Merkur roadbed/ballast underlay for the K-track. This is a different substance : it is very firm, fits well with the K-track :
After 18 years it shows no signs whatsoever of deterioration:
and has a matching scatter-particle ballast that can be used for peripheral and associated matching ballast:
In some areas I did not use Merkur roadbed and used either Woodlands ballast or my own mixture of various (mostly Faller) ballasts, such as at station platforms :
in the freight yard :
and in the steam service area :
So my response is this : to each is own, we all enjoy Märklin in an eclectic manner. If what you want is K-track and if you want it to look more realistic than stand-alone (but resisting the obsession of the "rivet-counters" - not that there is anything wrong with "rivet-counters"- we need diversity in this life) , then the most "realistic", long-lasting and convenient "roadbed" is Merkur together with the matching scatter ballast plus other ballasts to taste.
Just my humble personal experience and opinion.
PJ
thanks 13 users liked this useful post by PJMärklin
#14 Posted : 19 April 2016 19:07:20(UTC)
Excellent review of Merkur longevity. I've got experience with what is surely the same chemical structure of foam used in Mössmer's solution, in that it was used in fittings and to seal the edges of flaps in my 1994 VW Golf automobile. After about 8-9 years that foam also began breaking apart and came shooting out of the air vents as a sticky, messy spray of bits. Whatever that foam is made of, the exposure to atmospheric gases and/or UV and/or ozone causes it to break down.
#15 Posted : 19 April 2016 19:13:43(UTC)
Have had the same experience with the Mössmer foam as PJ, have not used the Merkur roadbed (yet)...
Offline Rwill
#16 Posted : 19 April 2016 21:30:31(UTC)
Rwill
In my first era of M railways in the 90's I became an absolute fan of Merkur Styroplast it was readily available in the UK albeit expensive as every turnout and radius of curve needed its own part number. There was no flexible option. It made my limited scenic abilities acceptable and I only really considered K track although I occasionally used to "look over the other side" and quite liked the look of Fleishmann profi track for two rail. The Styroplast did not dissemble or store well for the time the kit spent in the loft so on my return last year looked for new supplies and could not really find it in the UK or Germany. Merkur have been taken over by Noch who really want to sell you the foamy stuff so On Ebay, amazon etc you only seem to find an occasional random piece of Merkur and it is not a product for the second hand market. Maybe someone will tell me it is still readily available in the USA or down under in which case I recommend it.
Offline BrandonVA
#17 Posted : 19 April 2016 22:43:50(UTC)
BrandonVA
I believe for a time Noch took over Merkur. They are now back in business on their own. I recently (before Christmas) ordered a fairly large shipment from them for my new permanent layout. I would not use Merkur for anything other than a permanent layout. It could be reused on another layout, but it's not something you want to fiddle with on a regular basis. Customer service on ordering was great, and everything is as expected. Sometimes it takes them a couple of days to respond.
They can be found here:
http://www.merkur-styroplast.de/
-Brandon
Offline baggio
#18 Posted : 20 April 2016 05:20:34(UTC)
baggio
I agree with you, but I was trying to run on the same track DC and AC; it works, but not as well as I would like because the K tracks are not user-friendly. Sad
Offline baggio
#19 Posted : 20 April 2016 05:30:35(UTC)
baggio
I love your layout, P.J. BigGrin
When may come over to see it? Laugh
Between your layout and your beaches, Tasmania is looking better and better to me.
How are the turnouts, though? Do the locos struggle across them? That was one of my problems.
#20 Posted : 20 April 2016 12:40:49(UTC)
Hi Baggio,
Come over anytime you want.
The turnouts are fine. Work best if all level.
PJ
#21 Posted : 20 April 2016 12:43:47(UTC)
http://www.merkur-styrop...erklin-H0:::46_72:2.html
PJ
Offline jcrtrains
#22 Posted : 20 April 2016 13:12:13(UTC)
jcrtrains
PJ;
Who makes your platforms?
#23 Posted : 20 April 2016 20:16:40(UTC)
Looks like there now is a flex-track option:
http://www.merkur-styrop...klin-H0-200105::190.html
Offline BrandonVA
#24 Posted : 20 April 2016 20:29:37(UTC)
BrandonVA
Yes, and this option covers all "normal" straight options (2200, 2201, 2202, 2203, 2204, 2205, 2009). However, the Merkur is very set on having the sleepers in the right place, so I'm not sure this could be placed under other track (say a 2251 curve). It will not work with odd sleeper arrangements like 2293 for sure. The are a bit longer than a single piece of 2005 flex. I'll check tonight to see if you can lay it under other curves.
-Brandon
#25 Posted : 21 April 2016 04:10:47(UTC)
Originally Posted by: jcrtrains Go to Quoted Post
PJ;
Mainly Kibri but others :
The station is Faller "Bonn" used as an endstation rather than the prototype Bonn which is a through station:
the platform edges from this Faller "Bonn" kit form the abutment platforms for the end station platforms :
The passenger platforms are all Kibri. Made from a number of the 9544 units:
but also with the extension sets for the 9544's and a number of extra sections
the preiserling travelers and railway staff were all painted by me and from the blank white molded large packets by Preiser
all assembled to fit the length and end requirements :
The "service platform" needed to be without obstructions :
I made the service platform from plastic sheet cut to size and edged with Brawa platform edging :
For lighting I custom fitted small seed globes to the platform roof; standard globes light the station interior and the free-standing lights on poles on the unroofed platform sections are by Brawa :
Sorry if my answer was too detailed (my kids do say "nothing is ever simple with Dad")
PJ
thanks 9 users liked this useful post by PJMärklin
Offline jcrtrains
#26 Posted : 21 April 2016 16:54:14(UTC)
jcrtrains
PJ;
Nothing is to detailed in railroading. The whole thing is excellent. The platforms in particular caught my eye as I clearly need to paint the edge brick work on mine as they really give it some nice pop.
Thank you
thanks 1 user liked this useful post by jcrtrains
Offline BrandonVA
#27 Posted : 21 April 2016 20:14:34(UTC)
BrandonVA
I don't think it would work for anything smaller than gentle curves. R5 would require a lot of cutting to work with the flex Merkur piece, and the sleepers would probably not sit right.
-Brandon
Guest (7)
This page was generated in 0.857 seconds.
