Online dickinsonj
#1 Posted : 15 April 2016 01:50:45(UTC)
These are cute and I could eventually see one or more of these sitting around, but I am wondering about actually using them in shunting operations.
That would be entertaining to watch if they have enough power to pull it off, so to speak. BigGrin
Opinions?
#2 Posted : 15 April 2016 08:19:54(UTC)
I don't know how these locos were used in Austria, but in Germany they were built for branch line service, not for shunting.
A branch line train with 2 or 3 cars (2 axles each) should be possible without inclines.
Offline BrandonVA
#3 Posted : 15 April 2016 17:11:36(UTC)
BrandonVA
Speaking strictly from a model perspective regarding the Marklin Glaskasten locomotives; they are very light and as a result do not have a lot of traction. I have 3686, and while it's lovely, I think it would struggle to pull more than three cars (about 6 axles), especially if any of them were heavier metal wagons (as opposed to the more modern plastic wagons from the 80s-on). However, I know it can pull at least two plastic wagons (4 axles) up a 4% grade, as this was done on my previous layout.
The limiting factor here is weight of the locomotive itself, it's just not heavy enough to provide good traction. Also, with shunting there is a possibility of transversing turnouts at slow speed, another challenge for a very lightweight digital locomotive.
-Brandon
Online dickinsonj
#4 Posted : 16 April 2016 00:48:54(UTC)
-Brandon
OK - that is basically what I had assumed but I wanted to see what others though. It actually was kind of a dumb post since it is a branch line and not a yard type lok anyway, as HO pointed out. So it is cute and one or more would look nice in a yard or making excursion runs, but I need the $$ elsewhere at the moment.
Thanks for the input.
Edited by user 16 April 2016 10:04:47(UTC)  | Reason: Not specified
Offline BrandonVA
#5 Posted : 16 April 2016 05:05:24(UTC)
BrandonVA
OK - that is basically what I had assumed but I wanted to see what others though. It actually was kind of a dumb post since it is a branch line and not a yard type lok anyway, as HO pointed out. So it is cute and one or more would look nice in a yard or making excursion runs, but I need the $$ elsewhere at the moment. How they fit sound into that lok is beyond my understanding.
Most likely a prototype can be found for most anything if you look hard enough. :) German trains often dropped off cars and picked up cars along their route, the locomotive doing it's own shunting, especially at smaller stations. Not yard work per say, but perhaps excuses could be made.
At any rate, slightly heavier locomotives like BR80, V60, etc are all excellent shunters, not only in real life, but also due to the good traction the Marklin version's have.
-Brandon
Online dickinsonj
#6 Posted : 16 April 2016 10:12:18(UTC)
-Brandon
I am good at coming up with ways to link what I can or want to do with some prototype behavior, even when it is a stretch. :-)
I agree - there are lots of good Marklin options for shunting operation available with good traction and telex couplers too.
This page was generated in 0.313 seconds.
