4 Pages«<234
#151 Posted : 01 July 2008 23:29:43(UTC)
Hello!
[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz
<br />Then there is mFx - a two way protocol - in that a loco will resolve an address conflict. What else?
With an mfx loco, the CS shows you all the current settings: maximum speed, acceleration and braking delay, etc.
And acceleration and braking delay are set as seconds.
The meaning of writing 20 into CVs 3 and 4 is different - depending on the decoder.
With an Intellibox you can read the contents of CVs 3 and 4 (and others, of course) and check the decoder manual to find what it means.
OK - a combination of PC and IB with a decoder database could do that work for you and show seconds in the GUI.
However, the CS is far from being perfect.
When selecting a loco from the database, it always sets "Motorola 14" - it's up to the user to know if the loco supports 27 or 28 speed steps.
You can always set the volume for MM locos - even if the volume can't be adjusted or the loco has no sound at all ...
#152 Posted : 01 July 2008 23:47:03(UTC)
Through the years I have used Delta (6603), Centarl Unit (6021+6041+6051), Mobile Station (from set 29530) and now CS with two MS connected.
I am very happy with the CS. In ny opinion it has everything, like easy access to the locomotives and function models, not to mention the switches and signals. No need for a number of keyboards.
The adjustment of remotely adjustable fx and mfx locomotives is rather simple.
And it is easy to set train routes.
I am looking forward to receive the missing hardware, not installed during the upgrade. Then I can laso use my s88 (6088) and the CU (6021) via the sniffer connector.
An the other hand; I have never tested controllers from other companies....
#153 Posted : 02 July 2008 00:08:14(UTC)
Well, regarding the CS - I almost fall asleep while it boots... Even our company's mobile PC:s with the Win XP Embedded custom OS I have made are much faster to boot to a ready state... But with Linux, they are just as slow as the CS, unfortunately... So it's obviously a software issue...
I mean, an IB + PC with appropriate train controller software does not take much longer to boot than the CS... I find this a bit annoying regarding a dedicated hardware box...
A dedicated controller should start much faster, in my humble opinion...
Another thing that annoys me is that the multitasking seems a bit under par, if I have a dialog box open on top of the background display - like selection of something - the control knobs do not respond... Strange software priorities...
But in general it's a good controller, even if I am a bit IB-biased...
Offline Lars Westerlind
#154 Posted : 02 July 2008 00:24:48(UTC)
Lars Westerlind
Sorry for my lack of participating in the arguing :-))
Reasons:
1. Been on vacations.
2. Nothing new really.
For me as a customer /systems has meant severe hesitations in buying new Märklin locos.
I've felt faintly that Märklin slowly have made some insights, and slowly turn back in mostly the right direction. If thet weren't so stubborn they could have saved a lot of time, but now it takes some time to them.
I also get the feeling that market is slowly getting some confidence that DCC+Motorola will be the axis for compatibility for some time to go, but who knows.
/Lars
Offline perz
#155 Posted : 02 July 2008 00:45:59(UTC)
perz
[size=1" face="Verdana" id="quote]quote:Originally posted by DamonKelly
"Receiving a signal and sending it back" is bread-and-butter data communications. Doing it with one wire and providing power as well is (however) not easy.
Doing it with one wire is indeed very difficult.
Doing it with two wires, as is the case here, is not trivial, but at least practically doable.
The bi-directional features of mfx are not wireless (i.e. RF). Various "single-wire, bi-directional" systems have been around for a while now. Getting it to work on a MRR track, however, is not trivial, especially when you need to preserve compatibilty with older protocols.
Again, it is not "single wire" even if it is sometimes called that. There are always two wires to the track.
I have tried investigating mfx. Some have suggested it is based on RDS (Radio Data System), but I don't see any connection. (If any super-geek members know anything more, I'd like to know myself...)
The reverse channel of mfx uses the principle of modulating the current draw of the decoder. The current draw is modulated with 57 kHz which is the standardized RDS modulation frequency. The coding of the reverse data is superimposed on the 57 kHz carrier frequency according to the RDS standard. This makes it possible to use a standard RDS decoder chip to decode it in the MS/CS. To extract the signal, the track suppply is fed through a signal transformer, and the signal is picked up on the secondary winding. This principle allows you to detect very minor current variations, even if the total current is huge.
The same principle of current draw modulation is used in the Digitrax feedback system. The principle was invented and patented by a man named Ireland (don't remember his first name). The patent is licensed to Digitrax, but is written in a way that it only protects the situation where the replies from several sections are multiplexed. I.e., it stops non-licensees from using the principle for train position identification.
Offline Tivvy
#156 Posted : 02 July 2008 06:49:12(UTC)
Tivvy
All I can say is that Systems has had one big advantage. It has caused a decrease in price of older motorola format digital items which has allowed me to change over to digital for my new layout biggrin
Ep IV / V Marklin Layout
Under construction.
#157 Posted : 02 July 2008 12:22:45(UTC)
Lars Westerlind
[size=1" face="Verdana" id="quote]quote:Originally posted by Tivvy
<br />All I can say is that Systems has had one big advantage. It has caused a decrease in price of older motorola format digital items which has allowed me to change over to digital for my new layout biggrin
biggrin
/lw
Offline DamonKelly
#158 Posted : 02 July 2008 12:58:34(UTC)
DamonKelly
[size=1" face="Verdana" id="quote]quote:Originally posted by perz
<br />Doing it with one wire is indeed very difficult.
I am aware of that wink
Sorry, I tend to fall back to jargon when I'm talking electronics.
In my field of electronics, "one wire" means one signal and one ground/return. Since every electrical communications systems requires a current return somewhere (even if it's via the Earth), it doesn't get counted. The Dallas/Maxim "1-Wire" has a single power/data/clock line, and GND. I2C is "2 wire" (SDA, SCK and GND).
That makes sense. If you don't mind me asking, where did you get that info?
Damon
Offline spitzenklasse
#159 Posted : 02 July 2008 15:32:59(UTC)
spitzenklasse
Damon, is it like "multiplexing"?
Offline DamonKelly
#160 Posted : 02 July 2008 16:58:20(UTC)
DamonKelly
[size=1" face="Verdana" id="quote]quote:Originally posted by spitzenklasse
<br />Damon, is it like "multiplexing"?
Err, how to explain...
This is how I understand (and use) the term multiplexing:
"Multiplexing" in this context implies multiple "logical" or "virtual" communication channels using the same "physical" connection (e.g. wire, or track)
For example, "time division" multiplexing means each logical channel gets the exclusive use of the physical channel for a specified time-slice.
Or, "frequency division" multiplexing means that the physical channel carries multiple communications channels each on different frequencies (e.g. cable TV, or even broadcast TV, where the "physical" channel is free space).
So...I'm not exactly sure what Per (or rather the patent holder) means by "the situation where the replies from several sections are multiplexed".
Per, what exactly does that mean? [:I]
Damon
Offline Macfire
#161 Posted : 02 July 2008 19:46:47(UTC)
Macfire
OK Damon.
I lost it at "Err" biggrin
Lord Macca
Offline Macfire
#162 Posted : 02 July 2008 20:17:51(UTC)
Macfire
quote:Originally posted by Bigdaddynz
<br />Tony what is the Mega set you have on order. I was not aware of any new ones available but if the locos are what I want then I may also order.
David
David, If I know Macca well enough, it will be the 29840 set with the BR55 and BR85 locos. He has wanted one of these for some time, and was rather jealous when I told him our club had just received one!! [:p][:p]
Big Daddy / Flash Dave,
Yep - right on both counts:
Yes 29840
Yes
[size=2]Green with Envy
(SAS raid being planned on a "certain location" during my next visit to Wellybob - Oops off topic [:I] )
[size=1" face="Verdana" id="quote]quote:Originally posted by frankie
~ one thing you can do is use a Delta control as a booster just for the turnouts and signals, there are plenty of topics around telling you how to do it.
Frankie thanks for the info, I have a Delta controller available from my 29815 set and I currently use the transformer from that to power my turnouts and lighting systems.
<br />Seems to me that the CS was designed for people who cannot program a VCR! That is what Plug and Play is all about! wink
Ron, I believe you had me in mind when you wrote that. wink wink
And thanks to all the others who responded to my booster question as well. Much appreciated.
Big Daddy and Dales blunt comments are also taken on board but being a true "non-geek" someone would have to set up a non CS system for me which would remove the fun of me setting it up. Having said that I am the type of guy that having physically seen and touched something can THEN go home and play so the future may indeed be interesting. But one step at a time Smile Smile
Edited: Additional commentary:
I suppose I'll get a smacked bottie from webby
for this...but here goes:
Sierra Delta - do us a favour and stop being a Delta Hotel (a Richard Cranium)!
Your post was not appreciated. Regarding HOTGOFFFCOTG, we have a similar chapter (club) here at work called WGAFF (Who Gives A Flying F(toss)) specifically for those of us who are not anally-retentive!
The post was cruising along nicely and then came the comments like:
~ "open minded" persons ~
~ You and all the other nice members ~
And the usual crap started again.
Teutonic arrogance is no excuse for the lack of manners.
Some members have had a gutsfull of the attitude of a certain "Messerschmitt" in whose eyes:
1. M* is NEVER wrong
2. Live outside Europe (well Germany) and you don't count.
FYI, as has been stated time and time again we appreciate input from the person we stand accused of "mobbing"
Not everyone has the time (or patience) to "REALLY compares the different motor versions especially in a particular model". and other similar entries. I know I don't. I struggle to get quality plat time - and I am a shift-worker!
During the '70s I brought a 3075 that gave me no end of trouble and had my then local M* dealer at his wits-end. Finally he was able to solve the issue but it nearly came to my either getting my money back or another loco.
Even then M* were not infallible.
Neither are they today.
This forum is brilliant. It highlights the positives as well as the negatives of M*.
And if you think that makes us (or some of us) a bunch of grumpy old bastards because we dare criticise M* and arrogance - well then I guess you are right.
But notice that none of us have ceased, given up or sold our M* equipment!
Why? 'cause we enjoy it.
I, for one, through history as I pointed out in another thread also I would not have 2 rail. Period. THAT my dear friend is MY personal opinion. I respect others who see that differently.
I also assume that I am included in your Magnificent Eight?
If that is so that I appreciate your consideration especially if that means I am not afraid to stand up for my rights.
Lord Macca
Offline perz
#163 Posted : 02 July 2008 23:14:02(UTC)
perz
1. http://www.alice-dsl.net/mue473/mfxmenue.htm
2. By putting together the information from numerous posts in this forum by several people over a long time.
3. Personal investigations.
4 General knowledge about electronics.
I must say that I have not yet made any successful attempts to extract the reverse mfx signal myself. But there was someone in this forum who described it rather detailed long ago. Don't remember who it was.
[size=1" face="Verdana" id="quote]quote:So...I'm not exactly sure what Per (or rather the patent holder) means by "the situation where the replies from several sections are multiplexed".
It means that there is some device that takes in and samples the signals from all the different sections in parallel, and then sends back the sampled results one after the other on one line to the Control unit.
It does not have to be implemented exactly like this physically, but as I understand it, the patent protects the use where you can distinguish that a lok is present on one segment as opposed to another segment. It does not seem to protect the usage where the signals are not "multiplexed" i.e. just used to identify if the lok is present anywhere on the layout or not.
#164 Posted : 03 July 2008 00:34:47(UTC)
I'd say perz has more than "general knowledge" about electronics... wink
#165 Posted : 03 July 2008 01:11:17(UTC)
Very true Juhan. Compared to myself Perz is a genius. I just like everything to work as the instruction book says as to how it works is way beyond me. I can change a light bulb but anything else requires an electricanbiggrin
David
Offline Macfire
#166 Posted : 03 July 2008 05:09:54(UTC)
Macfire
<br />Very true Juhan. Compared to myself Perz is a genius. I just like everything to work as the instruction book says as to how it works is way beyond me. I can change a light bulb but anything else requires an electricanbiggrin
David
DITTO !!!
Signed
The Non-geek
ps Both my boys are computer geeks. That is why I so love the term biggrin
Lord Macca
Offline bmcrae
#167 Posted : 03 July 2008 08:26:23(UTC)
bmcrae
[size=1" face="Verdana" id="quote]quote:Originally posted by Macfire
<br />I know I don't. I struggle to get quality plat time - and I am a shift-worker!.
Ditto for me. I can't even begin to count the number of times I've driven home from the night shift (10:30pm) with good intentions to get down into the train room and enjoy, only to find myself waking up on the couch at 2:30am after reading the newspaper and somehow nodding off..... wink
You'd think with the wife and kids (3 kiddies aged 8 and under) all fast asleep it would be prime time for me!!!!
But alas.........no [V]
#168 Posted : 03 July 2008 11:28:49(UTC)
It happens to me, too, bmcrae.
Nodding off, I mean. Very strange.
Thanks for the mfx explanation, friends.
I understand some of it, after studying the different protocols used for LAN communication in cars.
Offline DamonKelly
#169 Posted : 03 July 2008 16:47:55(UTC)
DamonKelly
I am familiar with that site, but being (unfortunately) mono-lingual, I had forgotten about it.
I assume "Fenster für Bestätigungs" refers to the idle time that the mfx decoder communicates back to the controller.
OK, here I want to tread very carefully, in case I just misunderstood your "tone of voice" (Damn, I hate internet forums -- you can never hear the other persons voice...[:(][:(])
I have been an Electronic Engineer for 20 years, designing all sorts of microcontroller & portable devices. I have difficulty finding information about mfx, I don't have difficulty understanding it.
My apologies if I took that the wrong way...[:I][:I]
Reverse Engineering a protocol like mfx is not trivial.
OK, thanks for the explanation.
Bummer, I had previously thought of breaking my future layout into small sections, and using mfx to locate decoders. Of course, if I'm not going to sell the technique to anyone...
Per, I assume you are in the electronic or software design field. I myself get a bit frustrated with Märklin's "explanations" of digital train control. I suspect it is relatively simple, but trying to get past the "lowest common denominator" factor means that I get lost...[:I][:I]
I wish there was some "techo/geek-speak" documentation.
Damon
Offline DamonKelly
#170 Posted : 03 July 2008 16:58:33(UTC)
DamonKelly
[size=1" face="Verdana" id="quote]quote:Originally posted by Damon Kelly
Another thing (I think - I'm sure others will correct me if I'm wrong ) is that when the mfx loco enters a non-mfx boosted section, it will revert to the 28-speed step protocol, instead of the 128-speed step mfx protocol.
Not correct, see answer from Tom (h-zero).
The only things that are affected by having a non-mfx capable booster are
- No automatic registration of a lok being on the boostered section
- No possibility to read/change configurations in a lok beeing on a boostered section.
The normal operation will be through mfx in any case. Once all functions have been registered in the CS, they will be operable also in the non-mfx boostered sections.
Per, can you clarify something for me? These "boosters" -- do they contain digital HW to receive and then re-transmit digital signals, or do they just provide an "analog" signal repeater function?
I'm curious about your statement that a non-mfx Booster can "boost" mfx signals (at least the outgoing part).
It would appear I've over-estimated the complexity of these "boosters"...[:I]
Edit - Sorry, I'm "crossing the threads" here...
Damon
Offline perz
#171 Posted : 04 July 2008 02:42:57(UTC)
perz
I am not trying to be sarcastic. It is, as you say, difficult to find information about mfx. A person with good knowledge in electronics will understand it, if he/she gets all the pieces of information. But in this case the pieces can be that somebody mentioned one little observation three years ago and somebody else mentioned another little observation two years ago. Not so easy to catch and remember everything. It is kind of a detective work. However Rainer Müller has done most of the hard work for us, don't know how he managed to find out everything so quickly.
Unfortunately this is not such a good idea. Or rather, the idea is good, but it won't work so well with mfx. The CS or MS send "PING" messages regularly to the loks, but the "PING" in mfx is addressed to a specific unit and the answer is just a simple "yes" or not. This means two things:
- The sample interval for a specific lok will be quite long if you have many loks. The CS/MS can not just send "PING" messages, they mainly send "useful" messages. I think there would be a problem with slow detection because of this.
- You can detect that you get a "PING response" on a specific section, but to correlate it to a specific lok, you will need to decode the "PING" message that the CS/MS has sent out as well. Doable but rather complicated.
The Digitrax system uses a broadcast "PING" and a coded response, I think. This makes the detection much faster, but on the other hand makes it less useful if two or more loks are on the same segment.
Yes, I am a chip designer. Nominally that is electronic design, but with modern design methods it is often more like programming.
The traditional 6015 / 6017 booster is just an amplifier/repeater. It does not decode and re-encode the signal. It is however built for amplifying digital signals. A "1" will give a "1" (+20 V) out and a "0" in will give "0" (-20 V) out. If you feed it with an analog signal (e.g. a sine wave) you will probably not get a nice analog signal out. I can't say for sure that you don't but it seems unlikely given the design of it. The Delta (6604 or 66045) is a more complicated device, which "emulates" the simple repeater function. Therefore, the delay through the Delta unit when used as a booster is significantly longer than trough a 6015 / 6017.
When it comes to the new mfx capable booster I don't know the details, but the output portion of it is most likely just as simple as in the old booster. For the return channel, I think the booster will extract the signal as I described it, decode it, and communicate the result over the CAN bus back to the CS. Note that there is some speculation in this since I haven't seen those boosters nor have I seen any descriptions of their internals.
I have seen the suggestion that you could use a 6017 booster and extract the reverse signal with a signal transformer on the track feed from the 6017 booster. Then amplify it and let it cause a modulated current draw on the direct CS segment. It should work, at least in theory.
#172 Posted : 22 September 2008 18:09:47(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by some non-important
<br />blablabla ...
It seems that this happens in almost ANY forum you - YOU - join.
German or International. YOU yourself is the problem - again and again ...
I would like to see a solution to this.
He was looking for trouble even with the BRAUN BROTHERS in their own MIWULA FORUM ...
Pretended to be a M representative and filled their forum up to the line with his bulls**t [xx(]
Well, they weren't as patient as we are. Fired him right on the spot. Read and learn biggrinbiggrinbiggrinbiggrinbiggrinbiggrin
http://www.miniaturwunde...rk-bauen-t11069-s80.html
Henrik Smile - don't know if this is of any help for you but I've made a decision.
Since he's extremely destructive *) he simply doesn't exist, anymore. Period Cool
Those are the <u>facts</u>. Plus my point of view biggrin
*) "Tullius Destructivus"
#173 Posted : 22 September 2008 19:06:52(UTC)
Hi John I wonder just how many forums he causes trouble. That site looks good but problem is the translation which may distort what is being said.
David
#174 Posted : 22 September 2008 19:09:19(UTC)
The 60212 Central station is dropping from Marklin German website but still on database.
#175 Posted : 22 September 2008 20:44:15(UTC)
Thanks for information, dear Steven Smile. You're a never ending source ...
David, Sire - will send you an translated excerpt, soon.
#176 Posted : 22 September 2008 23:05:21(UTC)
<br />Marklin said the 60172 will delivery from October 2008.
Sorry to correct you Stephen, but #60172 has been cancelled. I wonder why someone w/o a CS1 could wait for this booster. And if someone has a CS1, s/he could go along with an ECoSBoost.
Yes, it is replace by 60173 but for use with CS2.
#177 Posted : 23 September 2008 01:18:41(UTC)
<br />blablabla ...
Since he's extremely destructive he simply doesn't exist, anymore. Period Cool
Funny isn't it John, how the same issues keep raising their ugly heads, no matter where you go? What does that say to you?
A lot was lost in the Google translations, but I kept seeing the words "Lutz" and "Forum Ban" in the same sentence....
Offline Macfire
#178 Posted : 23 September 2008 02:03:02(UTC)
Macfire
Nice detective work there John.
Congratulations on your promotion to Chief of the MBI biggrin
Lord Macca
#179 Posted : 23 September 2008 12:54:09(UTC)
Thanks [:I], friends. Just our daily job ...
And re the promotion (Chief of MBI sounds great, Macca biggrin) -
but I'd rather be Director ( =$$$ [:p][:p][:p]) of <u>our</u> company.
#180 Posted : 23 September 2008 13:42:09(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by John Black
<br />http://www.miniaturwunde...rk-bauen-t11069-s80.html
What's really funny is that one of the blokes on that forum looks a little like NevW... biggrinbiggrin Kimball, Rowan, Bob Hunt and Persup will spot him straight away... I won't tell you which one.. You have to hop on a plane and come over and visit Nev.. biggrinbiggrin
#181 Posted : 23 September 2008 13:51:35(UTC)
Adrian - alas, having never met our dear Nev I know his picture, at least ...
So I can imagine quite well (it jumps at you !!!) what guy you're comparing with. Not fair biggrinbiggrinbiggrin
#182 Posted : 23 September 2008 15:08:37(UTC)
John Instant promotion to director.
David
#183 Posted : 23 September 2008 15:14:34(UTC)
Yes, the likeness is astounding. Plus, the writer is having a go at Lutz as well, something about a banning from a forum!
Sounds like our Nev!
#184 Posted : 23 September 2008 16:01:26(UTC)
<br />John Instant promotion to director.
Oh ... [:I] - thanks, Sire! Your servant forever, my King Cool
Offline pserup
#185 Posted : 23 September 2008 22:37:08(UTC)
pserup
<br />Yes, the likeness is astounding. Plus, the writer is having a go at Lutz as well, something about a banning from a forum!
#186 Posted : 24 September 2008 13:46:11(UTC)
<br />The 60212 Central station is dropping from Marklin German website
Because as of today it is no longer actively marketed.
Meaning it is now discontinued!!
#187 Posted : 24 September 2008 16:44:22(UTC)
I think you're right, David.
I wonder when Lutz will call it "discontinued".
It is not available, it is not actively marketed - but it's not discontinued.
It's no longer listed at Modellbahnecke, it's listed as a discontinued item at ETS.
I think the traffic light in M*'s product database will turn grey from yellow without showing green again.
M* SYSTEMS is discontinued (except for the MS maybe), now we have M* DIGITAL!
#188 Posted : 24 September 2008 17:40:47(UTC)
Lutz still has dealers with them in stock and has a thread running stating not discontinued.
Could prove good value at a knock down price.
david
#189 Posted : 25 September 2008 01:49:45(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by h-zero
<br />M* SYSTEMS is discontinued
No regrets, Tom ... Smile
Their chaotic adventure brought us grey hair and them huge losses, presumably [}:)]
That's the only cause they scrapped it - after having released it just before [xx(]
#190 Posted : 25 September 2008 02:49:22(UTC)
<br />It is not available, it is not actively marketed - but it's not discontinued.
4 Pages«<234
This page was generated in 1.469 seconds.
