Offline Roland
#1 Posted : 29 February 2016 05:13:12(UTC)
Roland
Hello All,
I am about to purchase two loks which do not have extensive sounds built in:
Marklin 37851 (BR151)
Marklin 37436 (BR143)
If I wanted to expand their sound capabilities, what exactly do I need to install? ESU Loksound decoder? Or does that require ESU LokPilot? They do have mfx decoders so replacing seems like it would be a waste of a perfectly good decoder. I have tried searching but have not yet been able to confirm the answer to this question.
Thanks in advance,
Roland
My Layout Build | Märklin CS3+ | K-track | Merkur | Viessmann | LDT | iTrain | Modeling primarily DB EpIV-VI
Online H0
#2 Posted : 29 February 2016 07:51:29(UTC)
Hi, Roland,
There is no easy answer.
LokPilot is without sound, LokSound is with sound.
Some Märklin decoders have amplified AUX3/4, some have unamplified AUX3/4. ESU decoders for 21MTC never have amplified AUX3/4.
Some locos do not use AUX3/4 and any decoder will fit. Some locos either require amplified AUX3/4 or unamplified AUX3/4.
With your 37436 it should not matter. With your 37851 check what AUX3 and AUX4 do and whether they are amplified - post a picture of the decoder if you don't know where to look.
There are two incompatible standards for 21MTC (NMRA and NEM) - and Märklin usually ignore both.
Offline Roland
#3 Posted : 29 February 2016 16:23:46(UTC)
Roland
Hi, Roland,
Hi Tom,
Thanks for the response. Are you saying LokSound = LokPilot+sound capabilities? No need to have both?
I will post pictures of the decoders once I receive the loks.
Roland
Online H0
#4 Posted : 29 February 2016 17:36:59(UTC)
Yep, Märklin and ESU sell decoders with or without sound - and there is no upgrade path to add sound later without replacing the original, mute decoder. I think it's the same with Zimo.
So you need a sound decoder - ESU LokSound or mSD or such.
With diesel locos you sometimes here the engine speed up before the loco starts moving - decoder and sound work together to achieve this.
Uhlenbrock sell decoders and sound modules, so you need both to get "music". I think this limits interaction between sound and movement.
This page was generated in 0.401 seconds.
