Offline bcovill
#1 Posted : 05 January 2016 21:37:54(UTC)
bcovill
I've got an RM-88-N-O from LDT that I would like to connect to an Arduino.
From the arduino part it's OK.
I've got now 6 wire coming from Arduino : data, gnd, clk, load, reset and 5V.
But I don't know which wire to plug on the ST1 LDT Board. No wiremarker on it. Confused
I asked them but no answer..
Has someone got an idea of the wiring of these two connectors ST1 & ST2 ?
Many thanks for an advice.
Best Regards,
Benoit
Märklin H0 - French Mountain layout in construction - MS2 Raspberry DSPi Arduino CanDIY Railuino
Offline amartinezv
#2 Posted : 05 January 2016 22:14:50(UTC)
amartinezv
ST1 is the standard connection to central digital from marklin (or equivalent, 6021, IB, CS, EcOs) and the ST2 is the connection to the next s88. This two conections are equivalent or similar to adjacent RJ45 plugs.
best regards
Antonio Martínez
www.raildigital.es/davidruso
Offline bcovill
#3 Posted : 05 January 2016 23:21:51(UTC)
bcovill
Thanks for your answer. I knew about ST/RJ45 in/out function.
What I was looking for is the pcb layout of the ST pins.
According to S88-N standard, here it is:
S88-N pcb layout
But I'm quite confused with that scheme cause the MASTER is on the right side (blue letters). Does this mean that ST1 is on the right side on the pcb layout ?
According to this pcb, the sequence for ST1 pins from left to right will be:
PIN1 -> Data
PIN2 -> Ground
PIN3 -> Clock
PIN4 -> Load
PIN5 -> Reset
PIN6 -> 5V
Benoit
This page was generated in 0.479 seconds.
