Offline siewolf
#1 Posted : 04 January 2016 16:20:59(UTC)
siewolf
Hi! Has anybody tested to combine 60128 with 6022?
Maerklin says it does not work, but i dont believe it!
I would like to combine my old equipment with the new one,
but if it does realy not work i will not buy a 60128.
Thanks for your help
Wolfgang
Offline sjlauritsen
#2 Posted : 04 January 2016 21:13:40(UTC)
sjlauritsen
I am pretty sure it wont work. There is more to it than one may think
The 6022 is a different controller than the 6021 and may do things differently and in ways that the Connect-6021 does not expect. The Connect-6021 is designed to communicate with the 6021 which is a more advanced and newer controller. There can be differences in the way the communication is set up and the Connect-6021 may expect information that the 6022 does not deliver, simply because it is an older device.
In a thread on Stummi, a guy tried the setup and found that the 6022 can only do on/off and nothing else.
http://www.stummiforum.de/viewtopic.php?t=118921
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
This page was generated in 0.356 seconds.
