Offline skeeterbuck
#1 Posted : 29 December 2015 00:28:25(UTC)
skeeterbuck
I have a Marklin BR41 loco and have broken off the steam generator from the left upper part of the boiler. I went to Marklin website to look up the exploded diagram for the engine and it only shows the boiler as a complete assembly. Here's a link
http://www.maerklin.de/s...&artikelnummer=37924
It's located between the smoke stack & first steam dome on the left side closest to you on the diagram. I can't believe you have to buy the complete boiler assembly to get this part. (at least I hope you don't) Crying
Any idea how I can find this part number? Thanks for any and all help!
Chuck
#2 Posted : 29 December 2015 04:52:38(UTC)
Some of the fine details are either delivered as integral to the shell or are molded as part of the housing. There does not seem to be a separate part for this item. You should check with service(at)maerklin.de to see if they can be of assistance. I could not even find a part number for the complete shell on the exploded list.
Offline Roberto Romano
#3 Posted : 29 December 2015 05:56:30(UTC)
Roberto Romano
Are you refereeing to the circular part where the arrow of 30 ends in the diagram?Confused Confused
Regards, Roberto
#4 Posted : 29 December 2015 06:20:01(UTC)
A few years ago Märklin Service was able to give me spare part numbers for two small parts of BR 01.10 that were not listed on the explosion diagram. I ordered those parts and got them in short time.
That was some years ago and they changed their spare parts strategy since, but I would still contact them first.
Offline skeeterbuck
#5 Posted : 29 December 2015 12:51:51(UTC)
skeeterbuck
Robert, it's in the same area as where 30 is indicating, but instead of being on the right side of the boiler it's on the left.
Thanks!
Chuck
I located a pic that shows the part clearly. It's that electric motor looking part behind the smokestack and before the forward steam dome. Wink
Offline skeeterbuck
#6 Posted : 29 December 2015 12:56:15(UTC)
skeeterbuck
Mike, it's not part of the boiler casting, it's a separately applied part. On my boiler you can see the area where it is applied there is a notch like shelf set into the boiler casting where this part is attached. The boiler is cast metal as this part would appear to be plastic.
Thanks!
Chuck
Offline skeeterbuck
#7 Posted : 29 December 2015 12:58:33(UTC)
skeeterbuck
Tom, that's what I'm hoping too. I know that every part for this locomotive is not indicated on that exploded diagram. I email Marklin and reply with what I find out.
Thanks!
Chuck
This page was generated in 0.403 seconds.
