Offline aquaanox
#1 Posted : 24 December 2015 23:21:54(UTC)
aquaanox
everytime I try to update it keeps highlighting on the usb update as shown. the version number in the information screen is 3.27 --- when I click on the v4 packages, it says they are already installed ?
Also, I'm trying to get the cab view in my new mfx locos, not sure where that option is ?
#2 Posted : 24 December 2015 23:28:26(UTC)
There are many different version numbers on many different information screens. Look for a version number with braces, format "a.b.c(d)".
The latest version is "4.1.0(3)".
3.27 is the version of the GFP, see update 11 in the list.
So most likely the updates are indeed installed.
To activate the mfx+ mode, go to the properties of the loco and set the mode to "Profesional" (sic).
Offline sjlauritsen
#3 Posted : 26 December 2015 07:31:29(UTC)
sjlauritsen
As Tom points out, have you checked the overall version number (Setup -> Version)?
The Central Station is made up of individually updatable components (software and hardware). This means that there is an overall version number (e.g. 4.1.0(3)). Every component in that version has its own version number, which is the one you see in the list. If no changes is needed for a component, that component's version number will not change.
The current version number for every component as of version 4.1.0(3) is:
1. Cleanup v 3.9.0, released 03.03.2015
2. System v 4.1.0, released 17.09.2015
3. Kernel v 2.0, released 15.04.2015
4. Webserver v 4.0, released 17.09.2015
5. Import USB (version "evergreen") - This is the USB import job, and will always run. It has no real version, as it is a job and not really a component.
6. CS2 GUI (user interface) v. 4.1.0(2), released 17.09.2015
7. Spielewelt Dampf v 3.9.0, released 03.03.2015
8. Spielewelt Diesel v. 3.9.0, released 03.03.2015
9. Spielewelt Elektro v. 3.9.0, released 03.03.2015
10. Spielewelt v. 3.9.0, released 03.03.2015
11. GFP v. 3.27, released 28.07.2015
12. MS2 v, 2.5, released 28.02.2015
13. Geraete v. 1, released 17.04.2014
14. Decoder v. 1.17.19.0(b)+1.032, released 03.03.2015
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
This page was generated in 0.340 seconds.
