Offline JD
#1 Posted : 30 November 2009 19:32:24(UTC)
JD
I am looking for instructions (preferably with a pic) on how to make my own C track contact tracks. I have searched the forum and read many posts but nothing clearly explains(at least to me)how to make them. In the past I remember accessing a link to a site that had the details but for the life of me cannot find the link again. Any assistance would be much appreciated.
JD
Offline NS1200
#2 Posted : 30 November 2009 20:15:14(UTC)
NS1200
Muj,
You mean how to connect electric power to the track or what?
If the answer is yes,you have to purchase some Marklin wire sets with connection shoes attached to them,these connection sets are also contained in various track extension sets,that is where i found them.
Turn a single piece of track upside down and simply stick the two wired connection shoes onto the two contact lips seen at the track end,lips facing innerside of the track.
This is all there is to it.
Isolating a piece of track from the rest works the same,only thing you need in addition is isolating shoes which you stick on both rails,left and right,these red isolating shoes can be purchased in the Marklin shop.
Feeder wire set has Marklin number 74040.
Offline JD
#3 Posted : 30 November 2009 20:28:22(UTC)
JD
[size=1" face="Verdana" id="quote]quote:Originally posted by NS1200
<br />Muj,
Paul,
What I am trying to do is make my own equivalent of the 24995 set sold by M. The track is for connection to an S88 module. As the M range of contact tracks is limited, I want the flexibility to use any straight or curved C track piece.
Offline tworail
#4 Posted : 30 November 2009 21:18:07(UTC)
tworail
thanks 1 user liked this useful post by tworail
Offline JD
#5 Posted : 01 December 2009 09:56:23(UTC)
JD
Many thanks John, exactly what I was looking for.
Offline Caplin
#6 Posted : 01 December 2009 10:44:20(UTC)
Caplin
Thanks John. Very informative link and picture.
Benny - Outsider and MFDWPL
Offline davemr
#7 Posted : 01 December 2009 12:36:44(UTC)
davemr
What a great explanation. Well done.
dave
davemr
Offline mascagni
#8 Posted : 01 December 2009 13:48:27(UTC)
mascagni
These work great, BTW.--MM
Michael Mascagni, Tallahassee
Offline oranda
#9 Posted : 18 December 2015 12:09:15(UTC)
oranda
Originally Posted by: tworail Go to Quoted Post
This link appears to be dead - is there an alternative?
Offline Tower
#10 Posted : 22 December 2015 07:21:41(UTC)
Tower
Also dead to me, I would also like to see
Offline Shamu
#11 Posted : 22 December 2015 10:01:13(UTC)
Shamu
The Internet Archive (Wayback Machine) is always your friend........ web.archive.org
I assume this is the photo in question.....
thanks 3 users liked this useful post by Shamu
#12 Posted : 22 December 2015 15:02:53(UTC)
You don't have to use the Marklin insulators, I have used small pieces of heat shrink tube. In this picture you can see where i have used some, and slightly shrunk the outer end to make the tracks easier to mate, but with care, you don't need to shrink it.
Any suitable thin walled tubing can be used.
#13 Posted : 22 December 2015 20:27:26(UTC)
Originally Posted by: JD Go to Quoted Post
Paul,
As well as detecting via the outer rail you can also detect via the center studs, not unlike 24994 except that this is non-directional. Marklin confuse it a little by having referred to them over the years as "Circuit Tracks" and "Contact Tracks". And they are opposite what you might actually assume.
'Circuit' tracks / Switching tracks / Control Tracks refer to detection of a passing pickup shoe on the center/stud rail
'Contact' on the other hand has been referred to as where the outer rail is being bridged by the wheels. There are distinct advantages to each method.
This method below has the centre rail interrupted to provide detection of the shoe and is the same concept used to index the Digital Turntable. This is not my own idea, it was suggested to me by Ross Offline (Ross Stewart) from Australia many years ago.
Note that you should not place this section anywhere that a train would be likely to stop because the few isolated studs do not receive track power, but this method can provide some potentially interesting possibilities.
https://www.marklin-users.net/cookee_nz/gbmc/detect/detect.htm
Offline Tower
#14 Posted : 29 December 2015 08:02:13(UTC)
Tower
Thank You All.
For directional detection I used a small reed switch connected to a relay placed between the centre stud and the outer rail. I attach a small magnet on one of my Metal Box cars that I always run behind my Loco (Or attach with a bit of glue to the underside of a plastic Wagon) ,a spacer is required to get the magnet nice and close to the track).
As a convention I always place the magnet on the left side of the wagon thus giving me directional control.
Hope that helps.
thanks 1 user liked this useful post by Tower
Offline Mark5
#15 Posted : 29 December 2015 19:14:02(UTC)
Mark5
Right side/left side. That is a very smart way to get directional control.
What kind of reed switches are you using?
Any photos about?
- Mark
Guest (4)
This page was generated in 0.452 seconds.
