Offline anderspihl
#1 Posted : 16 November 2015 09:48:41(UTC)
anderspihl
Dear railroaders,
Recently I tried to create a MCU with heterogeneous Märklin locos. The locos in question are the BR 01 138 (article 39008 /MFX+ decoder) and BR 103 (can’t remember article/MFX).
With heterogeneous decoders, the locos do not run at the same speed when operating the MCU. W/O MCU and with manually aligned speed, I notice the vertical green speed bar (next to the engine icon) displays different (~30%) speed values . Hence, achieving the same speed requires different loads on the heterogeneous decoders.
Is there any way to compensate for the different decoder behavior to get a heterogeneous MCU to work on the CS2?
Anders Pihl Knudsen
CS2 60213+MS1, 60052 60VA Trafo, K-tracks, Viessmann 5211 (K83)
Offline tulit
#2 Posted : 16 November 2015 13:06:59(UTC)
tulit
Originally Posted by: anderspihl Go to Quoted Post
Dear railroaders,
With the cs2 and appropriate decoders, you can define the speed curve for each locomotive. You'll need a speedometer of some sort (like m#78111) to measure the speeds of each individual locomotive to then compensate for it on the curve. If precise speed matches aren't important, I have done it by trial and error running the two locomotives on parallel track and adjusted until they were running pretty close.
Offline anderspihl
#3 Posted : 19 November 2015 15:58:21(UTC)
anderspihl
Thanks for the tip. Sounds a bit tricky, but I will give it a try.
Anders Pihl Knudsen
This page was generated in 0.339 seconds.
