Offline Hackcell
#1 Posted : 23 October 2015 21:05:07(UTC)
Hackcell
Costa Rica
What motor is good enough to replace the 216907 motor which is included on the 37991 BB locomotive? Somebody is selling one of these models without the motor on a very cheap price, however I want to put a quality motor inside as I couldn't locate online the original motor and I don't want to use the cheap motor.
Thanks.
Danilo Jiménez
Costa Rica, pura vida!!
Offline tfk
#2 Posted : 23 October 2015 22:52:02(UTC)
tfk
That's the big boy isn't it?
http://www.maerklin.de/s...&artikelnummer=37991
This one has a can motor in it. See the following link.
http://www.marklin.com/bigboy/
Here are some pictures:
http://wiki.3rail.nl/ind...%A4rklin_Klokanker_Motor
I would go for the original set-up as the decoder may only know about this type of motor. Secondly, on this locomotive eight axles are driven via cardan shafts. So the whole set-up is built around this type of motor. Also realise that this big locomotive may need all those axles to be powered to perform correctly. The marklin.com link mentions the flywheel which smooths out some imperfections in performance using kinetic energy and helps the locomotive overcome power gaps.
So my advice is to check what parts are missing and try to find out what the costs are to put everything back together. When the total costs are higher than the price of a pristine one, don't do the deal.
Hope this helps.
TFK
TFK
#3 Posted : 23 October 2015 23:39:45(UTC)
Big Boys up to 37793 had the "high-efficiency can motor with a bell-shaped armature" aka coreless motor.
Starting with the 37794 the motor is no longer coreless, the armature is no longer bell-shaped.
Danilo is trying to find one of those coreless motors.
Offline Hackcell
#4 Posted : 23 October 2015 23:45:18(UTC)
Hackcell
Costa Rica
Exactly! Or a extremely good replacement :-)
Danilo Jiménez
#5 Posted : 23 October 2015 23:48:58(UTC)
Good point. The old decoder has DIP switches and was optimized for coreless motors. This could lead to problems with the new type of motor.
The DIP switches are no problem by themselves, but those decoders do not have CVs that allow adjustment to a different motor type.
Offline Hackcell
#6 Posted : 24 October 2015 00:43:53(UTC)
Hackcell
Costa Rica
Based on the price I'm getting for this loco, I have no problems installing a newer decoder. What it really concerns me is to have a reliable engine as the one originally installed.
Far as I've heard the newer decoders installed on the BBs (37994, 37995) are a joke compared with the old ones.
Danilo Jiménez
#7 Posted : 24 October 2015 08:28:56(UTC)
With respect to decoders there is more than just "old" and "new".
The 37990 had two decoders for a total of about 9 functions. Probably the Big Boy with the worst sound.
37991 and early batches of 37993 have ESU mfx decoders. IMHO the best sound versions of the Big Boy Märklin made so far.
Late batches of the 37993 and the 37994 have crippled versions of the MSD and IMHO the sound is notably worse then the earlier mfx generation.
The crippled MSD does not handle the dynamo sound correctly and in the factory configuration you cannot run the Big Boy with lights on, but without dynamo sounds.
With the ESU version the dynamo sound is only on when the chuff-chuff sound is also activated.
I wouldn't call the new decoders a joke, but they are a regression. Same price, decoder is notably worse, motor is notably louder. They did these cost-optimizations not just with their flagship model Big Boy, but also with other models. Good bye, pre-orders. Hello, eBay ...
Offline Hackcell
#8 Posted : 24 October 2015 09:01:05(UTC)
Hackcell
Costa Rica
Mistype error, I meant the motors, not the decoders.
Danilo Jiménez
Offline biedmatt
#9 Posted : 24 October 2015 13:04:28(UTC)
biedmatt
Based on the conversation, it sounds like M no longer offers the original motor for replacement, which would explain the great price. Perhaps the only option is SB-Modellbau. They offer Maxon and Fahlheber motor kits to replace original motors. They do not show one for the BB, but I'm sure they would like a crack at one. I've remotored about a dozen of my sinus drive lokos. The kits and motor are first class and run even better than the sinus drive did.
http://www.sb-modellbau.com
Matt
Era 3
This page was generated in 0.371 seconds.
