Offline arcanjo
#1 Posted : 26 September 2015 18:13:50(UTC)
arcanjo
Hi there!
I have a locomotive roundhouse from Marklin (item 72883) and i have a problem. The leds that came with it, stoped working (after about 5 years of regular use). I suspect that the problem, lies on the circuit board that feeds the leds. I have tried a different power supply, checked the wires to no result. My question is, is there a spare part, so that i could replace the entire set?
Regards!
Miguel Nascimento
#2 Posted : 28 September 2015 19:11:58(UTC)
Originally Posted by: arcanjo Go to Quoted Post
Hi there!
Regards!
Miguel Nascimento
I suspect that the LEDs are all in series in one circuit, and that a single solder joint has failed, or that a track has cracked on the circuit board.
I would look at all the solder joints to see if one looks suspect, or if there is some corrosion or other suspect looking finish on the circuit board.
One simple way you could see if this is the case is to take a pair of tweezers and carefully short one LED at a time while power is applied, and see if the others turn on.
Perhaps you can post a high resolution photo of the circuit board, we may be able to 'remote diagnose' the problem.
[edit] If all else fails, you could send it to me, and I could fix it, shouldn't cost too much to mail it to me in the UK. [/edit]
Offline arcanjo
#3 Posted : 28 September 2015 20:18:57(UTC)
arcanjo
Hi there!
Thank you so much for your answer. I will see what i can do, and I say something after!
Miguel
Offline arcanjo
#4 Posted : 23 October 2015 23:12:44(UTC)
arcanjo
Hi there!
Regards!
Miguel Nascimento
Hi Alan!
Just to say, that Marklin sent me the complete circuit free of charge. I see the "light" again :)
Thanks!
Miguel
thanks 3 users liked this useful post by arcanjo
#5 Posted : 24 October 2015 13:33:05(UTC)
Hi there!
Regards!
Miguel Nascimento
Hi Alan!
Thanks!
Miguel
Well, that is a good result, and saved a lot of hassles.
Excellent news, now your preiserlings will be able to service locos again ... BigGrin
This page was generated in 0.311 seconds.
