#1 Posted : 16 July 2015 09:28:19(UTC)
When i read my MS2 data,it shows 17,7 volts as power.
So i wonder if i can reduce power voltage,when to use DCC and 2 rail?
I didn´t try it yet,so standing an question first are more safety.
#2 Posted : 16 July 2015 09:31:27(UTC)
I think the MS2 is showing off. Track voltage probably is around 16 V and should be no problem for two-rail H0 items.
You cannot get 17.7 V track voltage when using an 18 V switching-mode power supply.
#3 Posted : 16 July 2015 09:40:54(UTC)
Are you sure?
It shows same every time i use MS2 and check.
#4 Posted : 16 July 2015 10:51:28(UTC)
Are you sure?
I am sure. The question is where do they measure the voltage - and how.
My 18 V Märklin power supply delivers 18 V +/- 0.1 V.
Inside the track box there is a bridge rectifier (voltage drop of two diodes).
At the track stage there are two transistors (voltage drop of two transistors).
You simply cannot get 17.7 V track voltage from 18.1 input voltage with two diodes and two transistors in between. Track voltage must be lower than that.
Use a True-RMS volt meter to measure the track voltage.
Or try switching-mode power supplies with 16 V or 14 V to get a lower track voltage.
#5 Posted : 16 July 2015 10:59:31(UTC)
I know you have MS2 too.
Can you show the picture,when check at the voltage in the MS2?
You must only use same power feeder as i do,it´s 66361.
Offline efel
#6 Posted : 16 July 2015 14:21:05(UTC)
efel
The NMRA standard states:
"Digital Decoders intended for "N" and 70 smaller scales shall be designed to withstand a DC voltage of at least 24 volts as measured at the track.
Digital Decoders intended for scales larger than "N" shall be designed to withstand a DC voltage of at
least 27 volts as measured at the track".
So, why a 18V voltage on the track is a problem?
Furthermore, I agree with H0: if your MS2 is fed with 18V DC, it's impossible to get 17.7V on track.
Fred
thanks 1 user liked this useful post by efel
#7 Posted : 16 July 2015 15:03:29(UTC)
Fred
The NMRA standards says soo...but real for the difference scales.
N scale recommend maximum 14 volt on the track,cause of the wheels and smaller motor etc...
Topic is about how to fix the problem by reduce voltage to 16 volt.
It´s my goal.
If you too have MS2 and 66361,please check data in the MS2 and show with an picture,if you get same result or not.
#8 Posted : 16 July 2015 21:47:08(UTC)
Hurray, a new voltage / rectifier / diode topic. LOL
I'm looking forward to see the detonations.
#9 Posted : 16 July 2015 21:58:13(UTC)
I know the voltage reading of the MS2 is nonsense by design. Screenshots won't make a difference.
Would be interesting if someone with a high-frequency true RMS voltmeter or an oscilloscope would measure the actual track voltage when using a 66361.
#10 Posted : 16 July 2015 22:12:09(UTC)
I just measured, using a Fluke 189 True RMS multimeter.
Output from the 66361 was 18,090 V DC.
Track voltage was 15,418 V AC. ( Only multimeter was connected )
MS2 showed 18,3 V.
#11 Posted : 17 July 2015 10:48:03(UTC)
MS2 showed 18,3 V.
Then in case...it´s bug in the MS2. LOL
#12 Posted : 17 July 2015 11:40:19(UTC)
No, it's a feature, to tell you the approximate voltage from the 66361.
Nobody have promised that you could measure the track voltage.
#13 Posted : 17 July 2015 16:56:27(UTC)
No it´s not feature.
It´s default in the MS2.
#14 Posted : 17 July 2015 19:16:00(UTC)
It's a feature, chosen by Märklin.
If you want a controller with a feature that lets you measure track voltage, then you have chosen the wrong controller.
That is your fault, not Märklin's.
This page was generated in 0.395 seconds.
