Offline CHARLES MAGNO
#1 Posted : 12 July 2015 21:20:44(UTC)
CHARLES MAGNO
Brazil
Good afternoon everyone.
I need help.
I'm riding a marklin model with 50/70 years stuff and I'd like to know how the reverse gear of locomotives in AC since 7186 and have a turntable their home locomotives . How do the locomotives enter backwards in their respective bays ? The turner is incumbent that?
I thank you help.
Offline waorb
#2 Posted : 14 July 2015 15:19:08(UTC)
waorb
Brazil
Hello Charles!
How are you?
Let me know if I understood correctly... You want to know how to run the locomotive backwards inside the garage, after turned it 180 grad in the turntable?
Since you said you are working with 50/70's stuff, you need to switch the locomotive relay to run in reverse, i.e., turn the control knob to 'below zero' just a few seconds to 'click' the relay; after that just run the locomotive backwards.
After that, you should 'click' again to exchange to the forward run position.
Also, maybe your locomotive also have a lever on the sides to manually exchange the relay.
Walter
Offline Renato
#3 Posted : 14 July 2015 23:55:21(UTC)
Renato
Hi Charles,
Welcome to the forum !
I confirm what Walter has already explained.
Renato
#4 Posted : 15 July 2015 08:57:11(UTC)
Charles:
A little more clarification of the above. Drive the locomotive onto the 7186 turntable and bring it to a stop. Rotate the turntable until the locomotive is facing away from the track leading to the shed/track that you want to store it on. Activate the reverser using the control as mentioned above. Slowly reverse until the locomotive reaches the point that you want it to stop at. Make sure that your shed/storage track has it's power isolated so that the locomotives don't move when you are operating other ones.
Offline Moritz-BR365
#5 Posted : 15 July 2015 09:55:23(UTC)
Moritz-BR365
I guess, these old models have the mechanical turn switch on the side of the loco. Therefore, You can't reach the turn switch when the loco is stored in the roundhouse!
Look this picture of one of these old Märklin models with manual switch: http://www.history.nimg....n/T790.1-3-flosil112.jpg
Or this one with red manual handle on the right: http://up.picr.de/5572551.jpg
This page was generated in 0.498 seconds.
