Offline danmarklinman
#1 Posted : 28 May 2015 10:53:42(UTC)
danmarklinman
Hi can anyone tell me were, the radio interference surpreser is in The feeder K track piece 2292. I am told it's built onto it?
Wiking model car Fan
Instagram: marklin1978
Wiking fan
Offline PMPeter
#2 Posted : 28 May 2015 16:29:33(UTC)
PMPeter
If there is no capacitor across the 2 terminals, then there isn't one. It has most likely been removed.
#3 Posted : 28 May 2015 18:23:31(UTC)
danmarklinman
Cheers Peter. I had a dig at the one buried on my layout and could not find anything. I was a little worried as I had been usein my MS2 with it.
Wiking fan
#4 Posted : 28 May 2015 18:47:01(UTC)
The 2292 is not use with Delta/Digital, The 2290 is use for digital/delta only.
The Image is from the Catalogue 2014/15.
#5 Posted : 28 May 2015 23:09:06(UTC)
danmarklinman
Hi Steven, thanks for your help. I think I have the right one. As the one you should not use, has the serpresser attached near the contacts? I think?? The one I have, I dug out the plastic and could not find anything- see picture
Wiking fan
Offline PMPeter
#6 Posted : 28 May 2015 23:52:40(UTC)
PMPeter
Based on your photo I think you are fine. I sold all of mine so I can no longer look, but I believe the track number is the same for both, with the only difference being the capacitor across the input terminals. So unless someone soldered a capacitor elsewhere on the track, you don't appear to have one.
This page was generated in 0.289 seconds.
