#1 Posted : 13 April 2015 18:19:04(UTC)
I've made 4 new couplings and they will be my standard electrical coupling for years to come, I think it will take me a while to finish them all off but as you go along things will get easier as you think things through.
I'm quite happy with the results so far, a few adjustments and they will do a good job, coming apart is not on the menu, its actually a bit of a problem to take them apart.
Edited by user 15 April 2015 04:04:32(UTC)  | Reason: Not specified
#2 Posted : 14 April 2015 10:01:11(UTC)
here are some photos from the beginning how the coupling is put together
the first picture depicts the upper row of 4 contacts, one the right hand side are 2 pins for the symmetrical coupling, pin 1 is than connected via a wire with pin 4 and pin 2 and three are also connected together with pin 3 showing the 2nd symmetrical connection
the 2nd and 3rd picture shows the plug with already one pin connector and on the back are 2 pins soldered together which forms the coupling shaft peg.
4th picture, are male pins which I use for connecting pin 1 + 4 on the lower row and use them for the coupling shaft peg and also for the connecting pins. for the upper pin 5 + 8 I use a different wire as it needs to be longer and I form this to hold the coupling shaft into place which you can see this on the previous pictures.
the plug sleeves themselves aren't fixed solid enough into the plug, so the extra solder when pushing them back into the slot stay there permanently and don't fall out or get pushed backwards. the outer 2 plug sleeves I add a drop of superglue to hold them into place.
the second picture also shows a raised border which I've shaved off, this allows the coupling shaft to go a bit deeper into the plug and thous reduces the distance between carriages, in future I also intend to shorten the coupling shaft to shave off the front of it so the carriage is completely together but one has to be careful when going around curves there is no interference with any other part.
I'm looking into it how can I reduce the length of the connecting pins without influencing the strength for both plugs to stay together under pressure
#3 Posted : 15 April 2015 11:47:58(UTC)
and here we have the finished product, the gap has been adjusted and the symmetric coupling got a shrink tube added to hide the inner workings, the pins have been shortened and I will see how far I can take them back without loosing contact or getting separated.
the last picture show the buffers are made closer together.
all in all I think I can reduce the production down to 2 hours
#4 Posted : 15 April 2015 12:10:35(UTC)
Nice!
It wasnt until the second-last photo in your third posting, that I realized you were doing 8-pole couplers. You should state that from the beginning, as it makes the whole thing much more interresting! (Even though I now see that you indicate it somewhere in the text, in your second posting...)
#5 Posted : 15 April 2015 17:37:12(UTC)
Nice!
Its a bit of a tricky one, 4 pole or 8 pole, although it has eight holes it has only four connections hence I call them symmetric couplings and in the end there are only 4 cables or wires attached to it, the benefit of course is, you can use them either way.
the 4 pins are used as follows:
1.) red wire (for function or second decoder)
2.) blue wire: common ground (DC)
3.) Aux 1, toilets, entrance gangway, certain compartments, centre lights for an open seating arrangement, tail lights
4.) Aux 2 rest of the compartments or in an open seating carriage, some centre lights can be turned on or off.
the idea is at night time not all lights are on.
of course the carriage can be connected on either end.
This page was generated in 0.523 seconds.
