Offline chrisisrang
#1 Posted : 28 March 2015 14:53:57(UTC)
chrisisrang
Can anyone possibly help explain the difference between Marklin 74461 and 74465? Do they support mfx, similar to the upcoming Marklin signals? Thanks a bunch in advance.
Chris
Offline siroljuk
#2 Posted : 28 March 2015 15:16:53(UTC)
siroljuk
Hello Chris.
Both decoders are for turnouts, 74461 is for normal turnout and 74465 is for threeway turnout.
This is 74461:
Built-in digital decoder
Installed in all C Track turnouts with electric drive. Connection via plug contacts. Address 1 to 256. adjustable with coding. For the electric turnout can be used simultaneously or subsequently a digital decoder. The decoder is easily connected with plug contacts and can be addressed individually for each switch (address 1 to 256). Tools or special skills are required for installation. The digital power supply can be taken directly from the track current contacts on the turnout. In this way, a complete digital turnout that is ready for immediate use on mobile equipment.
and this 74465:
This decoder can be installed in the C Track three-way turnout (24630) with electric mechanisms. It can be used with the digital formats Motorola and DCC. Connections are made with plug-in contacts, for Märklin and Trix C Track turnouts. An address can be set with coding switches (Motorola Format 1 to 320 / DCC Format 1 to 511), and can also be set on the programming track. Turnout lanterns can be connected and can be controlled (soldering skills required). A digital decoder can be installed at the same time as the electric turnout mechanism or can be installed later. The decoder is easily connected with plug-in contacts and can have a custom address set for each turnout. The digital power supply for the decoder can be taken directly from the track current contacts on the turnout. This means you can have a complete digital turnout that can also be used on temporary layouts.
Jukka
thanks 2 users liked this useful post by siroljuk
Offline chrisisrang
#3 Posted : 28 March 2015 23:54:06(UTC)
chrisisrang
Thank you very much for the detailed response...in essence 74465 is for the 3-way turnout 24630 while 74461 goes into all other turnouts in the C track system.
#4 Posted : 29 March 2015 00:49:47(UTC)
Originally Posted by: siroljuk Go to Quoted Post
This is 74461:
Jukka
Your description appears to be for the 74460 not 74461
While both 74460 and 74461 are for single motor turnouts ...
the 74460 is old school (MM only, DIP swicth addressing only)
ref medienpdb.maerklin.de/product_files/1/pdf/74460_betrieb.pdf
the 74461 and 74465(3 Way variant) are the same generation (MM/DCC, DIP or program addressing)
ref medienpdb.maerklin.de/product_files/1/pdf/74461_betrieb.pdf
ref medienpdb.maerklin.de/product_files/1/pdf/74465_betrieb.pdf
Note: the MM 256 address limitation is a 6021 control unit one, not a device one, The devices in MM mode can address to 320.
Offline siroljuk
#5 Posted : 29 March 2015 08:50:41(UTC)
siroljuk
Peter is right.
I used text from here:
http://www.modellbahnsho...-gb-h-0/ein_produkt.html
Later on I´ll try to use text from Märklin.
But the point is that 74461 is made for c-tarck single turnout and 74465 is for c-tarck threewayturnout.
Latest versions of these decoder can be programmed via software, older version can be programmed only by usin dip switchs.
Happy tarining everyone
Jukka
thanks 1 user liked this useful post by siroljuk
This page was generated in 0.256 seconds.
