Offline Torstein
#1 Posted : 27 March 2015 12:45:48(UTC)
Torstein
I have the set 42750 "schnellzugwagen" set and want to install led light in the coaches, but I do not know how to open them. It seems to be between the floor and wall but I am afraid I destroy something if I use big pressure.
Please give me an advice on this Confused
Torstein BigGrin
#2 Posted : 27 March 2015 21:15:53(UTC)
Have you try removed black at both end of coach before open?
Just be carefully open with black underframe about 20 years old may have crack or broken if bit bend off body.
Offline 3rail4life
#3 Posted : 28 March 2015 02:08:09(UTC)
3rail4life
As Steventrain mentioned, you want to remove the diaphragms on each end and then gently pry away the bottom bases from the upper portion of the coaches taking care not to force anything. Sometimes you may have to try different spots find out where it will release, once it starts to come apart it is pretty easy.
A cool video of the whole process can be seen here:LED Coach Lighting
enjoy,
Gordon
thanks 2 users liked this useful post by 3rail4life
Offline Torstein
#4 Posted : 28 March 2015 13:28:21(UTC)
Torstein
Yes - the diaphragms was the trick.
Thank you gentlemen ThumpUp
Torstein
thanks 1 user liked this useful post by Torstein
This page was generated in 0.265 seconds.
