Offline TheFatTick
#1 Posted : 12 March 2015 19:30:14(UTC)
TheFatTick
I have a 28970 Glaskasten "Wedding" loco, celebrating the union of Marklin and Trix and produced in 1997. I believe it is Delta equipped.
Can I run this loco safely with a Marklin 6646 transformer? I assume I can't get near it with my blue metal transformers.
Thanks!
Edit: I'm fully analogue, FWIW.
Offline lglarsson
#2 Posted : 12 March 2015 21:12:04(UTC)
lglarsson
Thanks!
You can run it with the 6646 transformer without any problem. Don't use the old blue one. You can of cource run as digital also. Since it is a Delta Product you have 15 adresses avaiable for digital use.
LG
Märklin collector/K-track, permanent layout since 1985/60214 CS2, CS3+, 60174 Boosters/WinDigipet, WinTrack, Collection/
thanks 1 user liked this useful post by lglarsson
Offline TheFatTick
#3 Posted : 12 March 2015 23:02:57(UTC)
TheFatTick
Fantastic! I can't wait to run it.
I'm afraid digital is not in the picture at the moment. But I do intend to use the Glaskasten as a shuttle using a 6600 controller.
Offline BrandonVA
#4 Posted : 17 September 2015 22:38:39(UTC)
BrandonVA
TheFatTick,
I'm very late on this response, but I would be careful using a 6600 with a decoder based locomotive. It's fine for analog loks, but using it on a digital lok running under analog control may be bad. Delta controllers should be a little more tolerant, but not sure about using them with 6600. If you have another Delta lok (maybe a diesel) to test with that may be better, replacing the decoder on a Glaskasten a pain due to the tight space.
-Brandon
This page was generated in 0.224 seconds.
