#1 Posted : 27 January 2015 06:06:12(UTC)
I already own the 37755 with the 46370, 46371 and 46372 sets, so why did I need to buy the 26800 set?
Part of the answer is sentimental - we really enjoyed our time in Scandinavia a couple of years ago and the other part of the answer is another question: What looks cooler than a Dm3 with 18 wagons? Another Dm3 with 12 wagons.
This set comprises a 37753 Dm3 and 12 wagons. Six of these wagons are the same as the 46371 set, but the other six wagons do not come from the 46370 or 46732 sets. I have no idea where they are from unless Marklin has used different road numbers for wagons in the three sets.
One disappointment is that when I placed the loco on the track and started the eCOS so that mFx would register, it took off like a scared rabbit. The only way I could get control of the loco was to place it on my rolling road and let it run at full speed, let mFx register the loco on the eCOs, then move the throttle from 0 to midway and then return to 0 - only then did the loco stop. Once again, I am not convinced that these locos are test run at the factory!
The second disappointment is that I think there is an intermittent connection fault. When I returned the loco to the main line it would not work - even pushing the whole loco along the track did not make a change. I picked up the loco and placed it down again in the same spot and the lights came on. The same thing happened after I picked up the loco and placed it on the starting point for the WindigiPet calibration. I will keep an eye on this!
Some photos.
Nice long train next to a longer one. BigGrin
Lights are good.
The wagons are weathered too.
Front of the loco.
Rear of the loco.
I will upload a video after she has been through the calibration process.
thanks 6 users liked this useful post by xxup
#2 Posted : 27 January 2015 07:38:59(UTC)
Hi, Adrian!
This could be the "result" of a test run: if taken off the track too quickly the loco will remember the last speed setting.
Weak evidence for a test run - not necessarily at the factory (some dealers give the items a test run to reduce reclamations).
#3 Posted : 27 January 2015 07:59:18(UTC)
Okay the calibration run is complete. The slow speed running, up to speed step 25 (128 mfx steps/15 WDP Calibration points * 3 poor running points) is terrible - very jerky like the front and rear motors are not running at the same speed. Beyond this speed step, it runs well. Perhaps the loco needs some time to "run in"?
I tried to take a video, but it was too dark (no exposure adjustment on the little camera I use for train pictures) so I will try again in the morning. Blushing
Overall, I think that the 37755 is a better built loco than the 37753 that comes in the 26800 set.
Offline NZMarklinist
#4 Posted : 27 January 2015 14:27:41(UTC)
NZMarklinist
Hi Adrian,
I have seen the testing at the factory, (2013 M days Factory tour) and they do a digital and function test, and also an analogue test on the same circle or figure 8 track, which normally have a few switches (points) included.
I'm not sure which order they do the tests in but I have had a few new Loks race off whilst supposed to be registering and it is MY theory that, the some of the test and packaging, girls probably remove the Loks from the track with analogue throttle still on and when the lok sees 18volts again off it goes, full speed !!OhMyGod
I have usually just hit the stop button a few times and they settle down and do the normal registration process IIRC I think one time I had to hit the reverse knob a few times and that eventually worked and stopped the loco. It's just a case of signalling the decoder that digital power is here Sneaky
So if my CS1-R is not on, I power it up first and then hit the stop button before placing the new lok on the track, you should (for the nubes) hit the stop button, when placing any digital Lok on the track anyway Scared
Nice Loks and Ore Trains Smile ThumpUp
Glen
Auckland NZ
thanks 3 users liked this useful post by NZMarklinist
Offline Shamu
#5 Posted : 28 January 2015 06:45:09(UTC)
Shamu
Huummm......... makes me think that I'll be using the roller stand in future for "first time out of the box checks". It has never happened to me yet....... BUT........Confused
Out of the around 20 lok's I got last year only about a third got tested and nothing since about September when I started packing all the train gear away.
thanks 2 users liked this useful post by Shamu
#6 Posted : 28 January 2015 08:32:11(UTC)
.......it is MY theory that, the some of the test and packaging, girls probably remove the Loks from the track with analogue throttle still on and when the lok sees 18volts again off it goes, full speed !!OhMyGod
I have usually just hit the stop button a few times ...... It's just a case of signalling the decoder that digital power is here Sneaky
Hi Glen and Adrian,
A likely explanation.
The same happens occasionally in DCC locs on 2 rail.
(Both protocols having same features, mainly the recognition of mode of operation, you would expect the same anyway)
At the first chance, I disable DC/AC analogue.
Otherwise it can happen again for no apparent reason.
#7 Posted : 28 January 2015 08:40:18(UTC)
I only had this with new Märklin locos coming out of the box. I never disable analogue mode for Märklin locos with programmable decoders and this never happened to me later on. I believe it has to do with how the locos are put into the box after the test run.
Apart from that, there are older Uhlenbrock decoders where I had to disable analogue mode to prevent problems when mfx is present on the track. But that's a completely different story.
This page was generated in 0.369 seconds.
