Offline StuartA
#1 Posted : 29 December 2014 15:29:08(UTC)
StuartA
I have a V200 39800 locomotive with a problem. It doesn't run. Using MS2 with the sound turned off I can hear a whine from the motor when the speed is turned up, but the loco doesn't move. When I removed the shell I found that the motor was very hot. I removed the motor from the truck and ran it free. Again it whined, but didn't turn. I found that I can turn the flywheel by hand. Then I tried running the motor and it ran, but if I moved the motor it would either violently vibrate, or stop running.
So is the problem with the motor, or with the circuitry of the loco?
Stuart
#2 Posted : 29 December 2014 15:55:47(UTC)
Stuart
As it is a 39xxx series loco, it will be a c-Sine motor, I presume a compact C-Sine rather than the original one.
I suspect that what you describe will require a return to factory for repair. Without having a spare of either the motor or the drive electronics it will be impossible to determine which is faulty without an oscilloscope and probably other specialised test equipment.
It sounds like it has stopped driving at least one phase of the motor, so in certain positions of the rotor there is not enough torque to make the motor rotate. It could be either an open circuit winding in the motor or a fault in the electronics producing this symptom.
Offline StuartA
#3 Posted : 29 December 2014 16:23:17(UTC)
StuartA
Stuart
Thanks for the quick reply. I figured that its the motor, but I like having it confirmed by a second source. I see that Marklin shows the motor are not available, so the owner of the loco may be out of luck.
Have a happy new year.
Stuart
#4 Posted : 29 December 2014 19:27:17(UTC)
Views messages in topic : 15,543
It could also be a problem of the flex cable. The flex cable could be broken or the contacts could be corroded. Pulling the flex cable out and pushing it back in might help.
#5 Posted : 29 December 2014 19:30:30(UTC)
Stuart
If you have another loco with a similar motor handy you could try swapping the motors as a test.
Toms note about cable problems is also worth investigating.
Offline BR218_1952
#6 Posted : 03 January 2015 19:30:38(UTC)
BR218_1952
Stuart
Stuart
Happy new year. Here my recommendations.
1.) As Tom mention, check the cabling first.
2.) Write a letter to the Marklin support, the most likely answer will be, that there are no spare parts available.
3.) Use this reply and send a letter to one of managing director Baechle or Sieber, complaining that this not acceptable. This is only way to create awareness, that this is a serious problem, which needs to be solved.
If the first 3 items, doesn't save your problem. Here you may find an alternative solution or a new attempt from rail4you , however there is only a German version available.
Rudi
This page was generated in 0.597 seconds.
