Offline PMPeter
#1 Posted : 12 November 2014 02:42:54(UTC)
PMPeter
I recently purchased a Viessmann used double arm semaphore signal and I can't get it to work. I have removed the solenoid case to check if anything appeared burned out or broken, and see nothing obvious.
The model number is unknown and it has 2 black leads as shown in the photo instead of the normal read leads for the track power contacts.
If I connect the brown and yellow, the LEDs light up. If I connect the green and red (broken off in photo) to a control box, I cannot get the solenoid to activate. Manually moving the actuator up and own shows a switching action between the red and green using an ohmmeter. I was able to put voltage on one of the solenoid solder terminals and the solenoid switched. I couldn't get at the second one.
Any ideas or did I make a bad purchase?
Viessmann
Offline PMPeter
#2 Posted : 12 November 2014 06:58:12(UTC)
PMPeter
I think I found it. It appears that the mechanism is slightly twisted and the sliding contacts are not centered. If I twist it the other way I can get the green working. I'll have to solder the red wire back on to see if I can get it to operate in the other direction with the same twist. Not sure what will happen when I snap the cover back on.
Offline PMPeter
#3 Posted : 17 November 2014 17:48:07(UTC)
PMPeter
Without the solenoid cover on, the signal works properly in both directions. However, the minute I add the cover it will not work at all. I have checked for any possible shorts or mechanical interference and I see non. I don't even need to snap the cover in place, just attach it to the top positioning pin and the signal stops working.
Any ideas?
#4 Posted : 30 November 2014 09:54:35(UTC)
Viessmanns old semaphore do have an very small hole under the drive mechanism,by use with an needle to adjust the wing arm.
You should try to fix.
But don´t have the power on,when you do it!
If yours semaphore generation of today is new,Viessmann reccomended return semaphore back to repair.
Offline PMPeter
#5 Posted : 30 November 2014 17:22:46(UTC)
PMPeter
Thanks Goofy.
I found 2 things. When I compared this signal to other Viessmann signals the previous owner reversed the brown and yellow wires. So once I reversed those I can operate the signal in the proper direction from a K83. However, the minute I placed the solenoid covers on I could only operate the green aspect. Once I used your needle suggestion it will operate in both directions but I can only get the arms part way down and up for the red thus showing a red and partial yellow light.
Do I keep pushing with the needle to move something or is this the best I can get?
#6 Posted : 06 December 2014 08:45:53(UTC)
I believe yours semaphore is default.
It looks like very old signal when i did look at yours picture of the signal.
It´s first generation of Viessmann signal you got there.
This page was generated in 0.264 seconds.
