Offline charles Sharpe
#1 Posted : 17 October 2014 04:52:56(UTC)
charles Sharpe
Hello.
Its been a long time since I posted anything. Do to health reasons I have down sized my lay out big time and now just about ready to set up the controllers. Can you tell me the code number to order 2 of the small black plugs for the 60052 trans. Also am I right in thinking that now the 60174 booster does not have to be isolated from the same track as the CS 60215 track feed is using.
Charles ps Soon will have list of stuff for sale lots of it.
CHARLES SHARPE
#2 Posted : 17 October 2014 05:39:47(UTC)
Wellcome back,all the best.ThumpUp
Offline pab
#3 Posted : 17 October 2014 10:19:50(UTC)
pab
WElcome back and all the best.
I don't no the sparepart number.
With the new booster you can have a common ground again for the sections. Of course the studs in de sections need to be separated. I know people that always had a common ground and had no problems.
thanks 1 user liked this useful post by pab
#4 Posted : 17 October 2014 13:01:12(UTC)
charles Sharpe
Hello Pab
You have totally lost me. Please could you explain in easy terms.
Charles.
CHARLES SHARPE
#5 Posted : 17 October 2014 13:30:36(UTC)
It means that the brown wire from both boosters and the CS2 can all be connected together - makes for easier wiring. This is what is commonly known as a 'Common Earth'.
As Piet points out, you still need to isolate the centre stud between boosted sections, otherwise you will blow up your boosters and or your CS2, if you feed the output from one booster into the output of another.
As for the plug, you should be able to find them at your local electronics store - take one along with you for comparison purposes. The ones you buy from the store may be green in colour, but should otherwise be the same.
This ebay auction may be for the correct plug, if so the part number is E611719.
http://www.ebay.com/itm/...&hash=item2a45ca9fd9
#6 Posted : 18 October 2014 05:25:48(UTC)
charles Sharpe
All has become clear.
Edited by user 18 October 2014 09:44:55(UTC)  | Reason: Not specified
CHARLES SHARPE
#7 Posted : 16 November 2014 13:36:17(UTC)
charles Sharpe
I managed to get hold of 2 of the E611719 green plugs they fit the CS 1 and 2 so now my 60213 is up for sale. I need some help for the small black plug that goes into the 60052 transformer. Does anybody know there code number
Charles.
Edited by user 18 November 2014 13:22:01(UTC)  | Reason: Not specified
CHARLES SHARPE
This page was generated in 0.285 seconds.
