Offline sahsuse
#1 Posted : 03 September 2014 13:13:07(UTC)
sahsuse
Turkey
I have esu ecos 50200 central station. New arrived. ı want to register my marklin mfx loco by using programming track output.
and ı seperated rail for programming. if program track happen electrically short during loco programming . what esu 50200 does do ?
because ;
when ı was using marklin cs 60212 and when ı was registering my loco (mfx) by using programming track socket. program rail shorted electrically accidentally and 60212 mfx fucntion stopped and not work anymore.
Is there any protection for electrical short during programming mfx loco? or what can ı do protect 50200??
Thank you.
Offline biedmatt
#2 Posted : 03 September 2014 13:25:46(UTC)
biedmatt
The program track is internally protected from short circuit damage. Edit: On my small track, I will move the connector to the program track output while I fine tune loko speed, sound synch and other functions. I have shorted it when placing a loko on the track without any problems.
You should not "need" to register your MFX lokos. Like the CS2, the loko should automatically register and import icons for functions. Edit: Forgot to say this auto register will occur on the main line output of the 50200. It does not need to be the program track. MFX registration is very slow. Go pour yourself a glass of scotch while you wait. MFX registration is less frustrating when you are drinking scotch. Once registration is complete, you will see an M4 icon in the bottom of each throttle screen. M4 is ESU's way of getting around Marklin's registered trademark MFX. Press that icon and you will go directly to that newly registered loko on that throttle.
Matt
Era 3
Offline sahsuse
#3 Posted : 03 September 2014 13:49:44(UTC)
sahsuse
Turkey
hi,
thank you for reply
Offline sahsuse
#4 Posted : 03 September 2014 14:21:49(UTC)
sahsuse
Turkey
hello,
Thank you again your best answer. That speciality as what ı want . and beautiful specification programming loko on main line output so ı will be able to use with safely.
thanks a lot
Offline biedmatt
#5 Posted : 03 September 2014 14:28:41(UTC)
biedmatt
Another edit. I think that now is all I have to offer.
Matt
Era 3
Offline sahsuse
#6 Posted : 03 September 2014 14:36:56(UTC)
sahsuse
Turkey
Thank you for sharing your experience
50200 best solution thank you.
Edited by user 05 September 2014 08:01:43(UTC)  | Reason: Not specified
70412 Home Signal with ESU EcOS 50200 (Digital)
by Richard_Pymble 30/07/2023 10:34:49(UTC)
ESU Ecos 50200 (Digital)
by Dave Banks 09/05/2023 05:29:41(UTC)
ESU ECoS 50200 Update query (Digital)
by Marklineisenbahn 18/10/2020 18:34:33(UTC)
ESU Ecos 50200 issue. Won't go past "Please Wait". (Digital)
by Dave Banks 31/10/2014 04:22:45(UTC)
ESU ECOS 50200 - EDITING ROUTES (Digital)
by lvfocus 21/03/2010 12:53:25(UTC)
ESU ECOS 50200 COMMAND STATION (Digital)
by lvfocus 07/03/2010 15:11:31(UTC)
This page was generated in 0.252 seconds.
