Offline Moritz-BR365
#1 Posted : 01 September 2014 22:16:01(UTC)
Moritz-BR365
I tried to pull with my E 60 with bell shaped armature motor a Märklin BR 81 (full metal loco). The question is, will the small and not very strong Faulhaber motor stop or will the wheels slip?
Look here what happens:
Edited by moderator 02 September 2014 20:14:37(UTC)  | Reason: Added the YouTube tags to show in the forum /Webmaster
thanks 3 users liked this useful post by Moritz-BR365
Offline Janne75
#2 Posted : 02 September 2014 10:18:58(UTC)
Janne75
Could you add some extra weight inside of the loco body if it is possible? Some lead or other heavy material to add traction.
Janne
#3 Posted : 02 September 2014 10:24:46(UTC)
Moritz-BR365
Hello Janne,
that's difficult, because there is not much space:
Maybe on the right side between the Faulhaber and the metal bow and on the right side of the bow. This will give more weight on the drive shaft with the rubbers (on the picture the third axle from left side.
But, it is important that the motor will not be blocked by too much traction. This will be the death for the Faulhaber motor.
Moritz
Offline Janne75
#4 Posted : 02 September 2014 17:41:17(UTC)
Janne75
Good looking modifications ThumpUp . It must run really smoothly with that Faulhaber motor. May I ask you how much does it weight now? My 3157 with 60760 decoder and 5 pole DCM motor with ball bearings weights only 195 grams and has often traction problems when I try to pull longer freight trains with it. I could add some weight into it...
#5 Posted : 02 September 2014 18:03:24(UTC)
Moritz-BR365
Hello Janne,
the total weight like shown in the video is 215g, only. The BR81 is 385g heavy!
But I get some anglers plumb the next days.
#6 Posted : 02 September 2014 18:06:20(UTC)
Tank loco you did tested by pull weighs about 385 grams...!?
It should equal about 20-25 wagons to pull.
And besides...tank loco do have traction tyres too.
It makes worse by testing pulling tractive.
This page was generated in 0.385 seconds.
