Offline MACER
#1 Posted : 16 August 2014 14:13:19(UTC)
MACER
Argentina
Hi alls.
In this case i make the grave over M System.
the upstairs are gypsum.
The deep of same is for 1/87, equal to grave K.
Many thanks.
Edited by moderator 18 August 2014 10:04:37(UTC)  | Reason: Removed capitals from heading - Using capitals is like shouting!
thanks 4 users liked this useful post by MACER
#2 Posted : 16 August 2014 15:04:07(UTC)
Very good! ThumpUp
#3 Posted : 18 August 2014 10:06:51(UTC)
Hmmmm, I'd be worried about the loco's slider getting stuck in the hole when a loco goes over the 'grave' with dire consequences as a result. Do you fit a centre rail or wire to prevent that?
Offline MACER
#4 Posted : 18 August 2014 16:59:46(UTC)
MACER
Argentina
Hi Bigdaddynz
In this case the loco stop with terminal stopper, and here have one track M of more only for see the action, en reality the V200
have a large slide, and is impossibly a bad function, too use in reverse is good, in my case no have problems.
The M system was sold 5 months ago, and have in use K and part C, with an adaptor track C-K.
Have too other grave track K, in the pictures its the same.
Many thanks.
MACER
This page was generated in 0.288 seconds.
