Offline AJH4
#1 Posted : 14 August 2014 03:47:44(UTC)
AJH4
There seem to be lots of Era III layouts and collections that include military transports. Anybody ever put together a set or layout in Era IV with U.S. vehicles and DB rolling stock and locomotive? It is fairly easy to piece together something for other NATO forces using 4MFOR pieces, but to assemble a set with U.S. vehicles seems to require 1/87 Roco plastic unpainted vehicles. I have some of the 4MFOR items, but I still need to get a BR216 or 218 and a few flat cars and stake cars. Just curious to see how it turned out and any suggestions. Also, my recollection was that the DB would put two M113 type vehicles on a stake car with lift up sides, but that would seem to exceed the wright for a Kbs 443 unless my conversion or specs for the 443 are wrong. If each variant is approximately 12,000 kg that would limit the load to one if the 443 is only rated to 13k kg, but I am not sure I found the right specs for the stake car. Do I have the wrong version of the car or can the 443 handle closer to 26 US tons?
Confused
Edited by user 14 August 2014 13:19:47(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by AJH4
Offline Mark5
#2 Posted : 28 August 2014 03:05:08(UTC)
Mark5
Great questions AJ
.... bumping this back to the top to see if anyone answers.
- Mark
Offline rmsailor
#3 Posted : 28 August 2014 14:58:23(UTC)
rmsailor
Coaches for USA use have been produced in the past both by Roco and Liliput. Roco have also produced at various times flatbed trucks carrying military vehicles and these are painted. To find out exactly would require going through all the old catalogues. Perhaps the simplest would be to set up a search on E-bay.
thanks 1 user liked this useful post by rmsailor
#4 Posted : 28 August 2014 19:28:11(UTC)
Not US Army but German Bundeswehr M113: Two of the latter loaded on a single two axle DB Rungenwagen - see pic. According to the German Bundeswehr website M113 "combat weight" is 10.8 metric tons:
http://www.deutschesheer.de/portal/a/heer/!ut/p/c4/04_SB8K8xLLM9MSSzPy8xBz9CP3I5EyrpHK9jNTUIr2S1OSMvMxsvezUkpJUvVxDQ2P9gmxHRQDdaS7R/
Probably the weight is sufficiently reduced when shipped without crew on board (and maybe stripped down a bit)?
Offline rmsailor
#5 Posted : 28 August 2014 20:37:18(UTC)
rmsailor
It would be safe to assume an axle loading of twenty tons and the wagon itself would not be more than about fifteen. So even with two personel carriers there would still be a good margin.
Bob M.
Offline Mark5
#6 Posted : 28 August 2014 20:43:30(UTC)
Mark5
How about trains during the 50s with both US and German military equipment mixed.
Any knowledge of that... now getting into prototype and model of course.
- Mark
Not US Army but German Bundeswehr M113: Two of the latter loaded on a single two axle DB Rungenwagen ....
#7 Posted : 28 August 2014 23:37:47(UTC)
The German Bundeswehr was only founded in 1955 and it took some time to get up to speed. Even uniforms were lacking at the beginning. Thus hard to say if there was enough equipment to be shipped by train.
How about this instead: German Leopard 1 A1A1 on former US military flat car (Talbot 1955/97092).
Offline AJH4
#8 Posted : 29 August 2014 00:33:47(UTC)
AJH4
Thanks to all for the great information. The combat weight is only about a ton more than the empty weight and for the M113 variants I am looking at and that would be about 11 to 12 tons. That is close enough to prove my memory right. What is the Marklin model number equivalent; the one I mentioned originally?
#9 Posted : 29 August 2014 10:34:53(UTC)
If you are specifically interested in military railway operation in Germany you may be interested in the Military Railfest to be held at Long Marston next May 6th to 10th.
Link to Military railfest notice
See also this page Long Marston railway info
I received a PDF of info about the LMMR from Train of Events (where those links are hosted) but unfortunately it doesn't appear on the web pages that I can see. It is 2MB so if anyone would like to see it PM me with an email address I can send it to.
This page was generated in 0.420 seconds.
