Offline mikemasey
#1 Posted : 10 June 2014 03:23:59(UTC)
mikemasey
Hi guys,
I have looked and looked and I know that I have seen it some where in here but I can not find it.
Can anyone help me to find the old analogue system of an auto shuttle run?
For A.C. not D.C. using M track and no digital.
I remember that it was possible to find the old transformers on Ebay!
Convinsing my wife that I really do need one may be difficult but I will worry about that later. First I need to find one!!!
mike.
Offline Hoffmann
#2 Posted : 10 June 2014 04:23:25(UTC)
Hoffmann
Hello Mike,
You are looking for Marklin Item # 6600 https://www.marklin-user...0-repair.aspx#post438027
marklin-eh
#3 Posted : 10 June 2014 05:06:15(UTC)
The 6600 cannot be used with modern digital locos. It can be used only with older analog models.
http://www.ebay.com/itm/...h-out-Box-/121345436456?
http://www.ebay.de/sch/i...aerklin&_sacat=22128
Offline mikemasey
#4 Posted : 10 June 2014 07:11:09(UTC)
mikemasey
Thanks for all the help, just what I needed. mike.
Offline Shamu
#5 Posted : 10 June 2014 10:29:42(UTC)
Shamu
Views messages in topic : 1,068
tufftuffde has one at the moment for 46 EU including postage to Oz.
Could be worth a look, guess that would come to around AU 75 Confused
Offline MalinAC
#6 Posted : 17 June 2014 16:09:47(UTC)
MalinAC
Ireland
Hi guys, Would the 6600 work with c track and only running analogue or it only for m track? Just being curious Take care, Eddie Confused Confused Confused Confused
Offline hennabm
#7 Posted : 17 June 2014 16:30:35(UTC)
hennabm
Hi Eddie
It's not so much the track type as whether it is digital or analogue locos you plan on running.
Analogue and 6600 are fine together, no matter what track you use, M, K or C.
1957 - 1985 era
What's digital?
thanks 2 users liked this useful post by hennabm
Offline MalinAC
#8 Posted : 17 June 2014 17:41:48(UTC)
MalinAC
Ireland
Thanks for that , Mike
Offline mikemasey
#9 Posted : 23 June 2014 03:21:10(UTC)
mikemasey
Hi again,
since my last post I have managed to buy a 6600 and a 6699(not from tufftuffde, I missed out!).
The 6699 is to be used as a Fine speed control and not as part of the 6600, is that correct?
It will need to have an input from another transformer and then be used in the normal way?
Plus I have a large Analouge collection of loco's with one Delta. Can I use the 6600 with the Delta or will be be best not to just in case?
I have been looking for any clues but all I have found so far are instructions on how to use the 6600, but not the 6699.
Once again thanks for any help.
Offline Shamu
#10 Posted : 23 June 2014 03:52:35(UTC)
Shamu
Originally Posted by: mikemasey Go to Quoted Post
Hi again............ Plus I have a large Analouge collection of loco's with one Delta. Can I use the 6600 with the Delta or will be be best not to just in case?
At a guess assuming it is one of the early "Delta's" with the 4 piano keys if set to "Analogue" it should be safe......... that being said I would be tempted since all the plumbing is there to swap out the Delta unit for a bog stock "reversing unit".
As I am not at all familiar with either the 6600 or 6699 I would personally go for the swap it path to play it safe, of course the "kid" in me would have a go just to see what happens. Razz
Offline Dangermouse
#11 Posted : 01 July 2014 13:55:26(UTC)
Dangermouse
I have a 6600 and used it with C-track, no problems.
The only thing I would say is not to use the contact tracks with microswitches, like 24994. I had trouble with the pickup sliders sometimes getting hung up on the contact "prongs", cutting the power and stopping the train from reversing. Once you got it going it would settle down and run reliably, but trying to fine-tune it for realistic slowing and stopping seemed to cause more problems with the sliders.
I only used it with locos fitted with a mechanical reversing relay, no Delta/Digital or even electronic reverser.
You can never have too many Silberlinge
Offline TheFatTick
#12 Posted : 01 July 2014 21:46:21(UTC)
TheFatTick
A related question: when I acquired my Dad's Marklin collection a bit over a year ago, it included a 6600 controller. Alas, since it did not have any documentation I have not even pulled it out or poked at it since I have been too busy learning far simpler and more basic aspects of building and operating a layout.
Most of what I have read concerning the 6600 is related to operating a back and forth shuttle. I have no plans for such a line on my layout. But I have seen some intriguing references pointing to the 6600's ability to allow one to schedule or time stops by stations and to have automatic control of speeds entering and exiting stations. Did I understand this properly?
The question I am really asking is what are the capabilities of the 6600, what can I do with the one I have and how would I go about doing it. I will be very excited if I can "program" stops or pauses on my analogue layout, especially since I had no idea I had the capability to do that amongst the equipment I already had.
Offline Yumgui
#13 Posted : 01 July 2014 21:58:33(UTC)
Yumgui
As I have no time to either find nor even less scan my 6600 manual, have a look here TFT :
http://www.digital-train...lin/Maerklin_6600_UK.pdf
Hope it helps,
Y Wink
Offline TheFatTick
#14 Posted : 01 July 2014 22:11:16(UTC)
TheFatTick
That's way cool Yum! Thanks so much.
Looks like I will be doing some experimentation here in the not too distant future.
Offline Dangermouse
#15 Posted : 01 July 2014 22:57:49(UTC)
Dangermouse
As I understand it, the reason why you shouldn't use the 6600 to control anything with a decoder is to do with the way in which it delivers power. Rather than a plain variable AC output it delivers Pulse-Width Modulation or PWM for more precise control.
Interestingly while researching this I come across "Delta Modulation". Anything to do with Marklin picking the word "Delta" for their basic digital system?
This page was generated in 1.026 seconds.
