#1 Posted : 17 June 2014 20:47:12(UTC)
Do anyone have this Bayern wagonset that fits with the peat steam locomotiv?
I need info about the lighting in the wagons.
Is it digital lamps or warm lighting LED??
#2 Posted : 18 June 2014 09:28:18(UTC)
Nobody who knows...?? Confused
#3 Posted : 18 June 2014 11:18:35(UTC)
Sorry Anders, I don't have this set.
#4 Posted : 18 June 2014 17:40:45(UTC)
It don´t stand in Märklins homepage,about the lighting bulbs.
I suppose it´s standard lighting bulbs for digital nr:61008.
#5 Posted : 18 June 2014 18:04:47(UTC)
Video by Glenn at UK marklin club.
#6 Posted : 18 June 2014 18:55:00(UTC)
There is it! BigGrin
Thanks Steven! ThumpUp
#7 Posted : 20 June 2014 16:48:15(UTC)
Is it possible to put an function decoder in this wagon set?
I miss manual to download from Märklin/Trix homepage.
#8 Posted : 21 June 2014 07:52:06(UTC)
I mean manual of the wagon set.
Does anyone have this?
#9 Posted : 24 June 2014 17:18:29(UTC)
No one have this manual to read...?? Confused
Offline Nigel Packer
#10 Posted : 24 June 2014 23:28:10(UTC)
Nigel Packer
This set is designed to be connected with a current-conducting coupler to a loco that provides current for the interior lighting. The Bavarian class B VI loco such as 37981 has this feature.
The interior lighting is actually yellow LEDs. It would be possible to fit a function decoder in the baggage car, but these cars are not really designed for that and it's a fiddly job. You would need to add a pickup shoe, too.
Best to run it with the loco it's designed for, I would say!
Nigel
#11 Posted : 25 June 2014 09:22:35(UTC)
Thanks Nigel!
But i use 2 rail and have Trix B VI locomotiv,so i shall buy Trix wagon set 24884.
That´s way i wanted to asked first and reading manual.
But it seems no one have manual of this wagon set... Confused
#12 Posted : 25 June 2014 16:44:15(UTC)
Nigel Packer
Thanks Nigel!
Hi Anders,
The Trix B VI loco 22251 shows a Digital function of "Innenbeleuchtung", so this might mean that the rear coupling on the tender has a lighting output, as the Märklin version does. I can't find the loco manual online to check!
If this is the case, you don't need to add a decoder or any parts to the wagon set to use the interior lighting.
Best wishes,
Nigel
#13 Posted : 25 June 2014 18:08:17(UTC)
I know loco has this function in F1 to control the lighting of the wagon set.
But there is only contact on the rear couple of the locomotive and not in the front of couple,which i miss it possible,so i could use contact couples instead.
Märklin have this nr item:72021.
It´s bad that there is no possible to use front as power feeder for the wagon set.
That´s way i´m also asking,if there is possible to use an function decoder to put in the postage car.
So i can switch the lighting off and on.
#14 Posted : 30 June 2014 18:26:05(UTC)
I did tried to contact Märklin,but still no respons about manual this wagon set to show up.
ThumbDown
#15 Posted : 06 July 2014 07:26:54(UTC)
I´m really upset,when there is no information.
ThumbDown
User is suspended until 21/07/4752 11:48:10(UTC) Barguest
#16 Posted : 10 July 2014 00:20:55(UTC)
Barguest
I have several of the baggage cars by Trix. Old ones with bulb that lights the side lamps by prism.
Has two-rail current pick up as normal Trix. Lights take space for one end only.
I can do photos if you like?
Alias for Mulldog Lemmon
#17 Posted : 15 July 2014 08:09:31(UTC)
Bastard!
A hobbystore did already sold this wagonset,so i missed it.
And Trix homepage says:no more producing... Crying
#18 Posted : 15 July 2014 09:43:11(UTC)
Barguest
Bastard!
Modelbahn Seyfried has them.
thanks 1 user liked this useful post by Barguest
Offline LA2019
#19 Posted : 17 July 2014 04:09:18(UTC)
LA2019
Thanks Nigel!
Is this what you need Anders? Hope it helps?!
Ken
USofA
thanks 1 user liked this useful post by LA2019
#20 Posted : 17 July 2014 08:34:41(UTC)
Very nice!
Thanks! ThumpUp
But i have Trix locomotiv for 2 rail.
What i´m looking are Trix 24884.
I suppose there is switch over in the package wagon.
Märklin have pick up shoe,while Trix have...?
Offline pab
#21 Posted : 17 July 2014 10:15:48(UTC)
pab
Hi Anders
In most cases the current in 2 rail comes via the wheels or contacts to the tracks. So no pick up shoe needed.
The other solution is via the locomotive
#22 Posted : 17 July 2014 19:39:36(UTC)
Originally Posted by: pab Go to Quoted Post
Hi Anders
Confused
I have F1 as digital function with locomotiv for the wagon set.
That means the contact in the package wagon must switch off from the track.
It´s necessary by do this.
That´s way i´m asking about Trix wagon set 24884.
If you have permanent contact in the package wagon,i cannot use F1 function because it destroy decoder!
#23 Posted : 18 July 2014 09:07:58(UTC)
Barguest
Hi Anders
Confused
Trix is one wheel and axle. Then isolate other wheel.
Contact is sometime swipe on axle, other time can be swipe on isolate wheel.
Single trix speisewagon has this way, but light on always, not control.
Putting decoder in wagon. Not contact to loko. If you like switch on/off.
Maybe dealer here can explain more?
#24 Posted : 18 July 2014 09:23:20(UTC)
The Wheels are isolated,but both have contact on the rail.
Plus and minus.
That´s way i´m confusing about locomotiv F1 function to switch on/off lighting,if there is no switch off in the wagon set.
Märklin have pick up shoe,which can removed if you want to control via locomotiv F1 function.
I think there is Trix pick up shoe resting on the wheel,which shall remove.
Never mind...i shall ask Märklin,if they have manual from Trix wagon set.
#25 Posted : 23 July 2014 07:07:43(UTC)
Never mind about Trix wagon set.
I give up this set.
Thanks for the helping anyway and the manual of Märklin wagon set. ThumpUp
This page was generated in 0.712 seconds.
