#1 Posted : 14 June 2014 12:55:52(UTC)
Hi all, recently after much searching I've acquired one of these at a price I could live with and really it's everything I anticipated, but a couple of problems needing attention.
I'm having some peculiar results with the rotation and reset of the platform, once it's working it turns in both directions smoothly and raises/lowers without any problems but often it will give quite a 'flick' and of course the poor Preiserlings get thrown around the platform often falling off and I can tell you, they don't like it!
The reset option (F4) is meant to initialise the motor but using my Intellibox, each time I press F4, it rotates a little clockwise and I can actually get it to go fully 90º, but testing it last night on a CS2 it would not do this, it still jerked and seems to have a bit of free-play but repeated use of F4 didn't make it rotate further so I suspect this may be an SO setting in the IB. I'll see if I can make a video of this 'flicking' of the platform at some stage.
I am indebted to Ross Offline for his tips on configuring my IB to access the additional functions via his article, http://members.ozemail.c.../pdf/39970_functions.pdf
But the main problem for now is that the Pantograph won't raise or lower and I suspected this might be a problem even before I got it because the auction pictures were clear enough to see that the thin cord did not appear to be attached and sure enough it was not connected. Sadly for me, the problem is not as simple as what Bill midwestbls Offline found in his topic....
https://www.marklin-user...ntograph.aspx#post344045
Last night at the club with the help of Peter clapcott Offline we had a bit of a play around, opened it up and I have confirmed this morning that the cord is broken entirely and only a short length of it remains so I am going to have to replace at least the cord, which I suspect comes with the arbour it's attached to and the small 'dogbone' pin to sit in the Panto wiper.
But when I lifted the body off a small extension spring fell out (glad I saw and caught it) and I was puzzled where it came from.
Having studied it closer this morning and taken some photos I think I know where it's from and would seem to tie in with how it all works. I've emailed Ross to see if he can take a photo of his inside but haven't heard back yet so while I wait I thought I'd share what I do have, and some close-up photo's for those who are interested.
First is the removal of the body, very simple. I suggest you work on a clean rag or something soft to place things down on and to catch anything that might be adrift.
There is a small panel on the platform deck (directly above the hoist ram) which you need to pop out, you'll see a small thin seam where it joins, push down just to the left of the seam and it will pivot up where you can grab it with tweezers. Undo the small Philips screw, remove it and gently lift the entire platform off.
The body is a 'friction fit', and for me I found it easy to place my thumb onto the hoist ram, then place my middle finger of each hand on the bottom edge of the body below the platform, roughly about where the wheels are and just lift with both fingers while gently pushing down on the hoist ram with my thumbs. Kinda hard to explain but easy in practice. Lift the body slowly and you may encounter some resistance when the electronics PCB hits the headlight shroud, mine was a very tight fit here but moving the body about slightly released it, then it just lifts clean away.
Body Removal
As above, at this point was my first surprise with the spring and very glad I saw it, would have been very easy for it to have passed my eyes unnoticed. If your panto is working this spring will be secured but if your cord has also broken, this will almost certainly be loose within, and with a very real risk of shorting across the electronics PCB so should your cord break, STOP using the Loco until you get it fixed.
Ok, so here's a photo of the spring and initially I was puzzled where it might have come from even wondering if it was part of the platform mechanism but the more I thought about it this morning and looking at the very limited diagram in the booklet the more I determined that it was part of the Panto drive and pending more detail I decided to take some more photos because I could find very few so here was a perfect opportunity to create a reference for others.
Phantom Spring
Looking in underneath the Pantograph and the upper portion of the drive clutch - this appears to be a one-way kind of clutch mechanism where the pawl will catch in one direction but slip in the other. Unfortunately with the body on there's no way to see the two parts correctly engaged (mated if you prefer) and if I could get my hands on a sacrificial body shell where I could cut the side out at the corner for a 'cutaway' view it would be very easy to see how it works. It may yet be possible to achieve a view by removing the shroud around the drivers cab at that end and with a strong light and a hack of a good lens possibly catch the mechanism in action - I'll keep that thought for another day.
Detail of the underside Panto drive
At this point I could see the end of the VERY thin cord, this really was a surprise, much thinner than I thought. Not a lot thicker really than a human hair or a strand of fibre-optic cable. I grabbed the end with my tweezers and gently pulled, it only unraveled a small amount but I didn't go any further at that stage.
This morning I got back into it again at home and this time decided to remove the upper clutch from the roof underside. Here are some detail photo's at different angles and I can actually see them much clearer from these images than with my own eyes - misplaced my jewelers head magnifying glasses which I will absolutely have to find when I get to repair it so I can see!! It's obvious that the cord has snapped and where the other end has gone who knows. And I am a little worried has this broken from the friction of repeated use or mis-use? (accidental I'm sure)
Clutch and cord different angles....
Clutch & cord
Clutch & cord
Clutch & cord
Ok, now I turned my mind to that spring again and a closer look underside after studying this image from the booklet...
Booklet
The cord seemed to just disappear in a loop and I wondered if it went away through the end-loop of the spring. Looking closely at the roof underside was a small post with a shoulder on it just as you'd expect from a spring anchor, and the spring sits nicely here...
Clutch & cord
OK, seems very likely. Will find out soon enough. On with some photos of the rest of the interior
One side image....
 One side image
Platform Piezo 1...
 Platform Piezo1
Other side image...
 Other side
Platform Piezo 2...
 Platform Piezo2
Lower portion of the Pantograph clutch mechanism cam...
Panto drive Piezo,,,
 Pantograph Piezo drive
See above a bit of a possible build-up on the white wheel which I will try to clean off before it gets worse, perhaps with a little Iso-propyl-alcohol on a rag or cotton bud (q-tip)
Electronics Decoder/s...
The Electronics/Decoder PCB
** note this Loco has two decoders, the primary one is the Mfx decoder, and secondary decoder for the platform motion appears to be standard Motorola format and of course there is also sound. You'll see a small piggy-back PCB underneath the main one so just what controls what I do not know at this stage.
And during the editing of this topic which has taken most of the day with visitors, taking photo's uploading etc, I did receive the awaited photo from Ross and exactly as I suspected, the spring provides a bias tension onto the cord. The booklet clearly states that for long periods of non-use, shipping etc the pantograph should be raised by the motor, then manually clipped down to lock back into place. This spring is probably what keeps the cord under a little tension so that it does not unravel from the drive clutch nor unhook from the Pantograph itself while it's relaxed.
Ross Stewart's photo
So my mission now given that most of the cord is missing is to obtain a complete replacement cord with clutch and the pin for the Panto. It's not shown in the exploded view and there's a chance it may only be available as part of the body. I emailed Marklin Service earlier today with photo's to ask about availability. Shall have to wait and see.
On a hopefully positive note, although I purchased the Loco used on eBay, the Seller is a store located in Spain and they have already responded apologising that this function does not work and promising to reimburse me via Paypal for the repair cost. I'll keep that aspect of this topic updated as well.
And for those who may not have seen it, this short 1 min promo video has a fantastic animation that does show how the Pantogrpah Piezo drive works, in this case on a Cl.103 but it's very similar...
And seeing as this Loco also has Sinus drive, this video too is relevant...
The only thing for me, that could possibly be added to this Loco would be Telex otherwise it ticks ALL my boxes and I just LOVE IT!!! Wub
Hope this has been enjoyable and maybe even helpful for some and I welcome any comments, feedback etc. I just hope the images display correctly or else I'm in for a bit of editing!.
Edited by user 15 June 2014 04:07:07(UTC)  | Reason: Spelling Piezo, typos
Offline Renato
#2 Posted : 14 June 2014 14:53:05(UTC)
Renato
Hi Steve,
Very interesting topic indeed.
Now I know better the technology of this beautiful model.
Renato
#3 Posted : 14 June 2014 15:46:32(UTC)
Steve, I've looked at this item before and I thought what a useless bit of a maintenance car and the price didn't impress me either but looking at the inner works this is impressive. thanks for sharing and having the guts to open it, it takes me hours sometimes I take something apart it falls apart and suddenly I'm presented with several parts I have no idea where they came from until you put your thinking hat on and eventually figure out where everything goes.
Offline Renato
#4 Posted : 14 June 2014 17:17:39(UTC)
Renato
Hi Steve,
Having a look at your picture, it seems to me as the wire broke sharply and is not consumed close to breaking.
IMHO maybe the pantograph was lowered and then blocked in that position, which is not recommended in the instructions booklet.
Infact the plastic wire is under the spring tension and forming an acute angle broke (and the tranport shocks help in that).
Renato
Offline Ross
#5 Posted : 15 June 2014 01:27:26(UTC)
Ross
Hello Steve,
I'm glad you found the photo and PDF helpful. Good article for future reference ThumpUp ThumpUp
Ross
#6 Posted : 15 June 2014 04:37:31(UTC)
Hi John, appreciate your feedback, and I do agree the price is rather high, but once you see what's inside at least you know where some of your money is going :-)
Opening it was much easier than I first feared and I have to tell you John, the 'play-value' for me at least, is very high.
But it is quite fragile, lots of additional bits on the roof alone that could easily get damaged with the wrong handling.
Sadly we don't really have a yard on our big club display layout where I could exhibit it, and use would have to be very limited otherwise I could see the mechanisms becoming worn very quickly after a weekend of near-constant use. Be interesting to know what Marklin planned duty-cycle and expected life-span of this feature (Piezo) is.
So perhaps now if you get the opportunity and the price is right you'll look at it with new eyes? BigGrin
Steve
#7 Posted : 04 July 2014 03:52:19(UTC)
Update for those who have been interested.
I have received my reply from Marklin Service..... (14 working days, I guess that's about right)
Dear Mr. Cook,
below is the parts list from the model 39970.
The required spare parts are no longer available.
The model can not be repaired.
We regret that we can not give you an enjoyable message.
Sincerly yours
Märklin Customer Service
Alexandros Karamichailidis
Gebr. Märklin & Cie. GmbH
P.O.Box 960
D 73009 Göppingen
phone +49 7161 608-222
E-Mail: Service@maerklin.de
Well, of course I'm disappointed, but I'm also somewhat realistic - it is after all 7 years since this model was first released, but then again, not yet 4 years since it was withdrawn. It would seem to me that the panto cord would be a bit of a vulnerable item and that replacement parts of this nature might be needed.
So now I have a few questions.
1: The parts diagram shows two different references, one #5 - p/n 115279 for 'Dach' (the roof) and #4 - p/n 115276 for 'Aufbau' (construction, or what I assume to be the body).
Note that the entire upper body is actually two main parts. The yellow body is plastic, the grey roof is diecast. Therefore, if I was to order the Roof, would it come complete with the Pantograph operating parts - ie the clutch to engage with the Piezo, the nylon cord, and the pin for the Panto? (as per my images)
2: The parts diagrams for the 39970 & 39972 show different numbers. The 39972 does not have the operating Panto, so perhaps the difference lies in one having additional parts?
3: Is it more likely that the part I want is in fact the roof assy, which would come complete with the Panto parts but the entire roof assy is no longer available?
What about the 39971? this is the Maroon version, but still has the working operating Panto - the roof for that is p/n 138641
I can just imagine the stream of confused emails back and forth trying to resolve this so it occurred to me that it may be far quicker and more reliable to have one of our native German speakers actually phone Marklin Service and clarify this. I have emailed Markus Schild separately in this regard as he is always very helpful with tricky questions but I did wonder if anyone had anything to add, and also if anyone would know whether those parts in the 39970 are the same in any of the other working Panto models?
I've got our local dealer Dion of Toot Toot on it also, trying hard not to leave a stone unturned here.
It looks like I might be on the hunt for some very fine nylon cord and that WILL be a fiddly job. Never ever ever tell a Kiwi (or an Ozzie) that something can not be fixed, it's just not in our nature.
Steve
#8 Posted : 04 July 2014 05:01:12(UTC)
Steve, I can't help you but one thing I can say, employees of these model train manufacturers are not as experienced as we are when it comes to spare parts.
if it is not available on their spare part list for a particular model: sorry its not available and I think this is exactly the point you are making. one would have to look at the different spare part list from different models as I've done so in the past with success most the time.
another option and I can't remember back what your problem is or which part had been broken but would it be possible to create or make a new part ? and this is another thing I've found out after long discussions and fruitless efforts to get a spare part. I've just read it again, its a thin nylon cord.
#9 Posted : 04 July 2014 08:05:37(UTC)
No piezo motors in that rail car.
Märklin have economised their spare parts department. You can always get what you want - but sometimes you have to buy 20 when you only need 1.
Various nylon lines can be bought in decoration shops or as fishing lines. You just have to find the correct diameter and length.
#10 Posted : 04 July 2014 08:47:46(UTC)
Quite right, my mistake, somehow I got it in my head that the Maroon one had the extra functions as well.
The 39970 is the one with bells and whistles, 39971 & 39972 are largely identical except for the colour and 39971 comes with the trailer?
I will have to look into thin nylon, I'm sure it won't be too hard to find.
Steve
Offline nero328
#11 Posted : 18 June 2015 18:46:55(UTC)
nero328
Hello All. I found this topic on the 39970 and thought it would be the best place to post my question. I have a 39970 and the problem I am having is that I can get neither the panto nor the platform to move. With the shell off, I can see that when I put the wagon on the track, a light on the board will come on, the wheel visible from the top (referred to as the Lower Portion of the Clutch Mechanism cam in the pictures below) will spin for a couple of seconds and then stop. Pressing the function buttons does nothing. If I lift the wagon off the track and place it back down, the same thing happens each time.
Any thoughts on what could be wrong? I am using the CS1 Reloaded, and have tried both calling up the decoder from the database (39970), and manually (71) - no difference. I see the video below of how the piezo motors should move, and that is certainly not happening. The panto wire is intact, so the problem is more general as I cannot get the platform to move either. F4 doesn't seem to do anything.
As background, the problem progressed as follows: first the platform stopped going up (however it would turn); then everything stopped working. The other functions of the wagon (sound, movement etc, work fine)
Many thanks for any assistance that can be provided.
This page was generated in 0.539 seconds.
