Offline Moritz-BR365
#1 Posted : 02 June 2014 21:21:40(UTC)
Moritz-BR365
I showed You here the installation of a buffer capacitor circuit for the Trix V 80. I wrote there that there is a free and unused AUX port. This AUX port is mapped to F1. I use it in the following report for the cab lightning.
It is very easy to disassemble the case. I drilled a small hole into the exhaust pipe of the interior furnishing. It will be used for the small cables for the LED:
I use a universal LED-board, ready equipped with resistor and diode. The small board can be bonded to the ceiling of the drivers cab:
Finally, the case must be assembled and the cable soldered to the U+ and AUX port.
After activating F1 on the Mobile Station 2 (You just have to assign a symbol to the F1 button), You can switch on and switch off the light:
Edited by user 04 June 2014 10:17:23(UTC)  | Reason: Not specified
thanks 4 users liked this useful post by Moritz-BR365
This page was generated in 0.315 seconds.
