Offline Rocca
#1 Posted : 31 May 2014 20:09:37(UTC)
Rocca
Dear Märklin friends,
I'm really in troubles with my 3092, K.Bay St.B.
I need to change replacing the Lichtkörper (Nr.: E231050).
I have taken off the chassis and I can see the Lichtkörper, but I don't know how to take it off from its place, because it seems all connected inside. Anyway, I cannot put here any link to a pic because I'ven't upgraded to ImageShack, but I can send you the pic at your private e-mail address, if someone needs that.
Hope you can help me!
Stefano Rocca
Rocca attached the following image(s):
Offline French_Fabrice
#2 Posted : 31 May 2014 20:51:22(UTC)
French_Fabrice
Hi Stefano,
You can post an image here in the forum; see "My Dashboard", Manage/upload my pictures. Once uploaded, copy and paste the link in your reply.
Fabrice
#3 Posted : 31 May 2014 22:17:40(UTC)
Hi Stefano,
Fabrice
Or simply use the option right by the forum 'post' button where it says " attach files to this post"
Offline Iamnotthecrazyone
#4 Posted : 01 June 2014 04:19:17(UTC)
Iamnotthecrazyone
I had a look at a similar loco for you but I didn't go all the way as you'll have to take the risk I might be wrong.
You'll need to take the reverse unit out. That will reveal underneath another screw that will allow you to take out the front with the pistons and valves then you should be able to change it. After that follow the reverse procedure.
Offline Rocca
#5 Posted : 01 June 2014 08:25:52(UTC)
Rocca
ooohhh...I understand!! Thanks a lot for the advice. I'll try to do all the job very carefully...Crying Crying !!!!
If you take a look on the Explosive, it doesn't give you any suggestion, really..!!!
Stefano
Offline Rocca
#6 Posted : 01 June 2014 08:28:16(UTC)
Rocca
Hello Fabrice,
I understand what you mean and it is a very usefull tool...I didn't know that...so thank you a lot of the advice!!
Hi Stefano,
Fabrice
This page was generated in 0.267 seconds.
