Offline taliesin
#1 Posted : 30 March 2014 22:58:16(UTC)
taliesin
Hi all, i am new here and possibly these questions have been asked before but here goes,
can a digital ho engine be run on analogue? if so what controller would you suggest.
Also i understand the digits in the box code mean something, so for instance what does the box code 3752 signify?
Finally for now, to go digital is it best to get a start set and possibly end up with an unwanted loco and stock or get individual components? thanks Rob
Offline Renato
#2 Posted : 30 March 2014 23:51:21(UTC)
Renato
Welcome to the forum.
Yes: a digital H0 locomotive can run on analogue, providing that you use the new white transformer (not the old blue transformers that can damage the locomotive decoders).
If you go on digital the start set is a good choice as you save money: most of the times you have the digital controller as a bonus.
Renato
thanks 1 user liked this useful post by Renato
Offline taliesin
#3 Posted : 30 March 2014 23:58:38(UTC)
taliesin
Thanks Renato, do the start sets contain the full digital system or a cheap version? Cheers Rob
Offline petestra
#4 Posted : 31 March 2014 00:06:03(UTC)
Hi, Take it from an old Märklin old-timer's stats.
1964-Oct. 2013; Only analogue
Oct.2013-present; Analogue & Digital. Now I love both but if I were just starting out I'd definitely choose digital.
Have fun, Peter ThumpUp Smile
Offline Renato
#5 Posted : 31 March 2014 00:08:06(UTC)
Renato
Hi Rob,
A good choice is to buy a Start set including the MS2 (60653) and power supply, tracks and of course locomotive and wagons.
This controller is better than the infrared controller, as the MS2 can control digitally also the turnouts (you have to buy also the motors and the decoders for the turnouts).
Renato
Offline kbvrod
#6 Posted : 31 March 2014 00:28:05(UTC)
kbvrod
Blink Blink Blink
Online cookee_nz
#7 Posted : 31 March 2014 03:06:58(UTC)
Renato
As above, just be aware also that any digital 'features' of the loco such as Headlights, Telex, Smoke etc will not work under analogue.
I'll further confuse the issue by noting that in some cases (depending on the decoder), the headlights on certain decoders may operate just like they do in analogue, ie they will change direction, but will also increase or decrease in brightness depending on the speed of the loco - if I recall, some decoders have a setting to activate this mode.
Steve
#8 Posted : 31 March 2014 04:18:05(UTC)
Originally Posted by: taliesin Go to Quoted Post
...what does the box code 3752 signify?
3700 series locos indicate that they are early digital locos.
Online cookee_nz
#9 Posted : 31 March 2014 07:58:06(UTC)
Early yes, but at least it's high-efficiency 5-pole, it 'could' be worse and be a 36xx item - first generation digital. Blushing
37xx is still first generation but performance definitely improved over 3-pole (poles referring to the motor armature, the more there are the smoother it runs).
Assuming what you have is actually 3752, this was a one-time item produced in 1995, and among the first of the Swiss 460 Loco models with very distinctive and colourful advertising, there were a large number of different models produced and collecting them all would require quite a large display cabinet (and an even larger wallet!) - I've seen a large collection of them and it's pretty impressive.
3752 is the so-called "Alpine Loco", attached below is the page from the 1995/96 catalogue with the item info... (hope it's interesting)
Steve
#10 Posted : 31 March 2014 08:22:45(UTC)
I'd call 37xx the second generation (with 36xx being the first generation).
37xxx can be anything from second generation through seventh (eighth?) generation digital and ref. numbers have become meaningless.
Offline taliesin
#11 Posted : 31 March 2014 08:43:25(UTC)
taliesin
Thanks for all the replies, yes I do own a 3752 as I thought the livery was so bizarre I just had to have one. At the time they were hugely expensive, to me anyway, and rather thin on the ground so it's taken the best part of 20 years to cure that itch. Would I be correct in thinking that all Marklin digital controllers would operate it ok or do I need to match one of a similar age? Cheers Rob
#12 Posted : 31 March 2014 09:49:23(UTC)
Any Marklin digital controller will control any Marklin digital locomotive, regardless of age.
Some of the simpler controllers, previously known as Delta, will only control a subset of the digital addresses (Delta addresses 1-4), and none of the functions, but will still run any loco provided they can be reprogrammed to one of the Delta addresses.
I would recommend the MS2 to get you started in the digital world.
http://www.maerklin.com/...ch%2Fproduct_search.html
Offline Renato
#13 Posted : 31 March 2014 12:14:05(UTC)
Renato
Blink Blink Blink
Hi Kevin,
I suggested to run a digital H0 locomotive on analogue using the new white transformer, as this is electrically safer than the old blue transformers.
The decoder installed in the locomotive is of the older type and not an MFX one, so the old blue transformers could be used.
Do you agree?
Renato
Offline taliesin
#14 Posted : 31 March 2014 12:40:53(UTC)
taliesin
Well i have looked around and found a digital start set for sale, number 29720 which i think contains what i need to get started. From what i can make out from pictures it contains the MS2 controller and it's uk spec so has the correct voltage power pack.
Hopefully this will give me a good start and i have also bought a reasonably new catalogue of ebay to give me an idea of whats available nowadays as for some reason there does not appear to be many, or any? uk dealers nowadays, cheers to everyone for your help, Rob
Offline Renato
#15 Posted : 31 March 2014 12:59:02(UTC)
Renato
Hi Rob,
Good choice !
You will have some sounds to operate.
Renato
Offline taliesin
#16 Posted : 31 March 2014 13:26:36(UTC)
taliesin
Thanks Renato, sounds as well, looks like i am going to be on a steep learning curve. First up will be just getting it connected up and moving, then adding some more track, then coaches for the SBB460 etc etc cheers Rob
Offline kbvrod
#17 Posted : 31 March 2014 15:35:36(UTC)
kbvrod
Hi Renato!
Hi Kevin,
Do you agree?
In a way,if checked there is nothing wrong with the old transformers,then they can be used. As I don't have any mfx loks better safe than very sorry Cool ,I use to set up an oval of M-track and 'break' in my 37XX locs and use a smaller transformer from my 2955 started set. I then got a couple of M 280's off eBay,one was used to update my IB on the desktop away from the layout and the other was used for model lighting on the layout.
Best,Dirt.
thanks 1 user liked this useful post by kbvrod
#18 Posted : 31 March 2014 18:13:44(UTC)
Hi Rob,
Welcome to the forum!
Offline taliesin
#19 Posted : 31 March 2014 18:29:38(UTC)
taliesin
Thanks Stephen, cheers Rob
Offline taliesin
#20 Posted : 31 March 2014 19:07:08(UTC)
taliesin
I can only wait for the postman now, whilst i am full of questions what coaches would be suitable to run with 3752 SBB 460? cheers Rob
This page was generated in 0.956 seconds.
