Offline kweekalot
#1 Posted : 15 March 2014 14:46:44(UTC)
kweekalot
According to todays German newspaper der Badische Zeitung, a defect Model railroad transformer possibly causes a fire. Crying
TRANSLATION:
Model railroad transformer possibly cause of fire.
A fire in a a roof structure in Betzenhausen caused a loss of € 80.000,=
The fire was reported at 14:40 yesterday, around 15:00 the fire was extinguished.
No one was injured.
The man who had discovered the fire, was examined for smoke inhalation, but had no serious injuries.
According to the police a defect in the transformer of a model railway may be the cause of the fire.
thanks 5 users liked this useful post by kweekalot
#2 Posted : 15 March 2014 20:53:44(UTC)
It is indeed a scare of mine!
My train room has smoke detectors and two fire extinguishers...
Don't ever leave your layout under power if you're not in the train room!
Call me paranoid...but my boss used to say "Only the paranoid survive..."BigGrin
#3 Posted : 15 March 2014 21:01:09(UTC)
Always unplug or isolate the transformers and power supplies from the mains when you leave the room.
My pet hate is people leaving phone chargers permanently plugged into the mains. Although they have been making them much safer over the years there is always the risk that they can go wrong when there is no-one around.
Offline kbvrod
#4 Posted : 15 March 2014 21:39:19(UTC)
kbvrod
A home/flat/apartment should have fire extinguishers,in the kitchen(the usual place for a fire) a fireplace and a one near an oil finance,if that is what you have.Keeping a few around the layout and shop wouldn't hurt either.
Your layout transformers should be plugged into a protected power strip and that is how you make sure everything is powered off.It's called a switch.
D
thanks 1 user liked this useful post by kbvrod
#5 Posted : 15 March 2014 21:51:23(UTC)
I always unplug my layout from the mains supply whenever it is not in use.
A friend in our Marklin Club who had a large H0 layout (900 sq ft) had a lightening strike on his house, which cooked his 6021 / 6051 controllers / boosters and rendered the layout inoperable until they were replaced / repaired.
The same person is now building a large G1 layout (22m x 10m) in a purpose built basement, and that room has surge protectors installed on the mains outlets.
#6 Posted : 15 March 2014 23:22:50(UTC)
In one of the Märklin magazines, (years ago) there was this collector who had a Gauge 1 layout and his son was never allowed to go in the room by hmiself (220 Volts locos), any after his father died he commissioned someone to rewire the whole layout so he and his children can be save but you wouldn't believe it, the whole layout caught fire and was completely destroyed.
#7 Posted : 15 March 2014 23:42:21(UTC)
Agreed, and not only is there the risk of failure, but you have all these millions of chargers, plugged in, consuming a small amount of power each, doing nothing other than generating heat, and we seem happy to pay for it.
I'm guilty of it as well, but we do have most of the phone/ipod chargers on one strip so when they are not in use they can be all turned off and you can easily see the consumption drop in the power meter.
#8 Posted : 15 March 2014 23:44:19(UTC)
Just try and get a teenager to switch off her Iphone, IPad, Laptop and hairdyer. Scared
Offline kweekalot
#9 Posted : 16 March 2014 09:30:32(UTC)
kweekalot
It is a pity that the newspaper did not mention what kind of transformer caught fire.
On some mmr forums, you see a lot of hobbyists that still use the pre-war black transformers, mounted directly on the (woorden) layout.
#10 Posted : 16 March 2014 09:37:51(UTC)
These old transformers should really be consigned to the display cabinet. The insulating materials from that era were notorious for falling apart with time. No-one in his right mind should use one of these except in the most carefully monitored conditions, and even then with a master off switch very easily to hand and a fire extinguisher ready!
Old trains will run just as well with a modern transformer to provide the power. Safety first!
#11 Posted : 16 March 2014 22:37:43(UTC)
A small warning
in our washing room, we have a rechargeable vacuum cleaner in a holder on the wall. It is charged by a small 12volt power supply, more or less permanently connected in the 230 Volt wall outlet. One day, passing it on the way to my train room, I detected a burnt smell. I noticed that the power supply's white housing suddenly was light brown. It was too warm to handle, so I used some kind of tool (cannot remember what) to pull it out of the wall outlet. I cut the wire and threw it all away (after cooling down)
Before connecting anything to the wall outlet, I will install a switch.
All my MMR power is connected via a central switch.
We have three smoke detectors connected via our alarm system.
thanks 2 users liked this useful post by intruder
Offline Janne75
#12 Posted : 16 March 2014 23:26:06(UTC)
Janne75
Thanks to all from warnings. I just went to train room and unplugged my rechargeable vacuum cleaner and iPad chargers... But also my layout power, CS2 with transformer, separate transformer for layout lights and accessories + one transformer for my Märklin My World series signals are all connected to a central switch before wall socket. My stereos below my layout are also connected through a different switch to other wall socket, but that switch is in very difficult place and I don't turn it off. Maybe I should, but I have never heard of an stereo amplifier or cd player to cause a fire... Unsure Mellow
Janne
Edited by user 17 March 2014 12:49:20(UTC)  | Reason: typo newer => never
#13 Posted : 17 March 2014 02:25:17(UTC)
.....I have newer heard of an stereo amplifier or cd player to cause a fire... Unsure Mellow
I have heard of instances where an amplifier caught fire, but this is a very very rare occurrence. Many high quality amplifiers are made to be on all the time, as the continual thermal stress of powering on and powering off can cause output transistors to blow - especially if the amplifier has a high inrush current when turned on.
Offline DigitalNZ
#14 Posted : 17 March 2014 23:16:38(UTC)
DigitalNZ
I remember we used to leave our amplifiers the school hall on for a whole term at a time! We only ever turned the off in the holidays, if we actually remembered to! BigGrin
Someone used an isolating transformer to try and reduce the impact of a ground loop with the projector one day and it worked. A few months later we borrowed one from the woodwork room, we had some All Blacks visiting for the rugby world cup and we wanted to try and stop the flickering picture. It tripped almost every circuit breaker in the hall and we were expecting 1200 people to arrive in 5 minutes. It was the first time the amplifiers had been off in a about two months! I was glad to get it all going again.
Carrying the transformer back to the other side of the school on the other hand was another matter. This was the small one, it only weighed 25kgs!
Moral of the story... Get everything (well, almost everything) that connects to the mains tested every few years. Especially if it was made in the last century!
I did have a vacuum cleaner catch fire..
Daniell
thanks 1 user liked this useful post by DigitalNZ
#15 Posted : 19 March 2014 08:06:10(UTC)
According to today's German newspaper der Badische Zeitung, a defect Model railroad transformer possibly causes a fire.
No further news about this fire yet, so we don't know what caused the fire.
Might well be that they write "transformer" but actually refer to "power supply".
I remember a case where a fire was caused by a defective laptop power supply. Owner let the supply plugged in all the time.
Insurance company didn't pay because they said the device was not made for perpetual operation.
In general it's a good idea to disconnect all consumers that are not needed and that don't have a primary switch (some computers have a primary switch at the back, some don't even have one).
And maybe one day we'll get further information about the cause of the fire at Betzenhausen.
#16 Posted : 26 March 2014 16:16:04(UTC)
I recently ran a wire across the basement to a single LED at the stairs - if the layout is powered up the LED is on, this way I can see it is on if I go upstairs.
Offline EvanG
#17 Posted : 24 May 2014 07:40:28(UTC)
EvanG
Hi everyone,
The report about a laptop power supply blowing is correct because I have had two people blow them while using their laptops continually, so this is a nice warning to people
with laptops don't use your laptop power supply continually it is meant to charge the battery ONLY BigGrin
Also I had a computer fried by a power short and our plasma TV has also shorted too in recent timesCrying
This page was generated in 1.010 seconds.
