Offline charles Sharpe
#1 Posted : 03 March 2014 14:27:08(UTC)
charles Sharpe
I was wondering which decoder you people are using. I don't use my TT very much and when I go to use it it goes out of sync on me. I am using the LDT TT Decoder and now when you press the program button the red/ Green lights don't flash they come on both stay on. Any thought on what might be wrong. I forgot to say I am using 60215 with c track
Charles.
CHARLES SHARPE
#2 Posted : 03 March 2014 17:52:17(UTC)
1.Did you first add number 15 as keyboard before to program?
2.What version do you have with LDT TT decoder?
#3 Posted : 03 March 2014 18:03:10(UTC)
charles Sharpe
Hi Anders.
Not quite sure about adding number 15. Page 15 is for the TT. The part no for the Decoder is 010502 which is a TT-DEC-G finished module in a case.
Charles.
CHARLES SHARPE
Offline Danlake
#4 Posted : 03 March 2014 18:38:38(UTC)
Danlake
Hi Charles,
I am also using the LDT TT decoder (although controlled by PC software instead of CS2).
I noticed that my TT may get out of sync if I forget to switch off the power to the decoder before shutting down my software... I have fitted a small toggle switch for this reason. Same when starting up - first I boot up Cs2 (and in my case PC as well) and then power on the decoder.
Below is extract from manual for programming the TT:
First step is to check that communication is working between CS2 and decoder:
1. Switch-on your digital-layout and the TurnTable-Decoder TT-DEC. If you
want to perform the programming of the TT-DEC via your model railway
software you have to switch-on those and adjust the turntable if required at
first in accordance to the relevant instruction of the software. It is important
that your model railway software supports the Märklin-turntable decoder
7686 because the TT-DEC is compatible to the commands of the Märklin
decoder.
2. Please press shortly 1-times the key S1 which is located at the right side next
to the TT-DEC heat-sink. Now the yellow LED will flash.
3. Send now several times the command >Drehrichtung< (Turning Direction) at
clockwise direction or anti clockwise from your command station or from
your model railway software in accordance to the programming- and control
table (chapter 4.7.). If the TT-DEC has recognized the command after several
sending intervals this will be indicated by a switched-off yellow LED.
4. The TT-DEC will leave the programming mode automatically. All three light
emitting diodes will glow.
And this steps are for actual programming the TT:
1. Press shortly the key S1 2 times. The green LED flashes.
2. Send now the command >Input<. The red LED will be shortly switched-off
and the turntable bridge turns eventually to the last programmed reference track.
3. Turn now the turntable bridge with the commands >Step< (clockwise or anti
clockwise) to the track 1 (reference track).
4. Send now in accordance to the operation instruction of your command
station or your model railway software the command >Clear< or >Clear< and
>Input< to store the position track 1 (reference track). The red LED will be
switched-off shortly.
5. Turn the turntable bridge with the command >Step< clockwise to the next
required track connection. Please consider eventually as well single
opposite track connections.
6. Store the track connection with the command >input<. The red LED will be
7. Prepare further track connections on the same way.
8. If you have completed the programming of all track connections send the
command >End<. The turntable bridge will turn to track 1 (reference track)
and the programming mode will be automatically finalized. If the turntable
bridge will not return to the defined reference track you have to repeat the
programming process.
Brgds - Lasse
#5 Posted : 03 March 2014 22:19:03(UTC)
charles Sharpe
Hi.
Not quite what you mean by software to run the TT. I am using the CS2 60215. I have done what it says in the instruction manually but still no luck.
Charles.
Charles.
CHARLES SHARPE
#6 Posted : 03 March 2014 22:49:04(UTC)
Originally Posted by: charles Sharpe Go to Quoted Post
Hi.
Charles.
Charles.
I use Marklin 7687 Digital Retrofit Set on 7286 Turntable with using CS2 and it work fine.
Offline Danlake
#7 Posted : 04 March 2014 02:32:49(UTC)
Danlake
Hi Charles,
So basically pressing the button S1 on the LDT decoder once or twice you are not able to get into any of the programming mode?
Brgds - Lasse
#8 Posted : 04 March 2014 07:13:12(UTC)
charles Sharpe
Hi.
Charles.
Charles.
Hello Steven.
Would you have the instruction handy for the marlin decoder. Could you e mail/pm them to me.
CHARLES SHARPE
#9 Posted : 04 March 2014 07:16:07(UTC)
charles Sharpe
Hi Charles,
Brgds - Lasse
Hi.
Thats right some time I am unable to get passed that and some times I can to half way thought programming the TT and it will not let me go any further it just seams to freeze.
Charles.
CHARLES SHARPE
#10 Posted : 04 March 2014 17:28:52(UTC)
Hi.
Charles.
Charles.
Hello Steven.
copy and paste the link into new window.
http://medienpdb.maerklin.de/product_files/1/pdf/7687_betrieb.pdf
Offline Danlake
#11 Posted : 05 March 2014 03:37:32(UTC)
Danlake
Hi Charles,
Brgds - Lasse
Hi.
Charles.
Hi Charles,
I would try and contact LDT and let them know excatly what your problem is. You may have a faulty decoder?
Brgds - Lasse
#12 Posted : 05 March 2014 07:28:46(UTC)
charles Sharpe
Hi Charles,
Brgds - Lasse
Hi.
Charles.
Hi Charles,
Brgds - Lasse
Hello.
I think I might give that a go. I can get a new one in the UK for £100.
Charles.
CHARLES SHARPE
#13 Posted : 05 March 2014 20:48:27(UTC)
here is how I did it..
http://layout.mixmox.com...igitizing_turntable_7286
I gave up on the Märklin decoder (I understand you are using another one)
#14 Posted : 05 March 2014 22:57:01(UTC)
I used Dale's solution as well (I also gave up on the Marklin decoder - I suspect mine was faulty out of the box, but too expensive to send back to Germany for repair). You don't need to remove the rectifier from the 7286 controller as Dale did - you can use an appropriately speced purchased rectifier, but just be aware that the pin connections might be different.
The solution works well and is reliable.
Marklin 7286 turntable. (H0-scale)
by steventrain 23/03/2008 11:34:44(UTC)
This page was generated in 0.551 seconds.
