Offline sikardon
#1 Posted : 28 January 2014 04:22:42(UTC)
sikardon
Indonesia
Hello All,
Until today, my understanding is that 3 rail must be AC, and 2 rail is DC. But today, I just learn that there is 3 rail DC as well. I know this from an ebay seller, I bought his Roco loco (my first purchase of non-Maerklin loco BigGrin), and he told me that this is 3 rail DC, and converting to AC is easy to do. I googled and found this https://www.marklin-user...operation/OP3raildc.html , but unfortunately, it is for analog operation, while my layout is digital.
So I would like to ask following question.
1. If I buy non-Maerklin loco, how do I know that this is 3 rail DC or 3 rail AC? what to look? what differences?
2. How to convert from 3 rail DC to 3 rail AC? well, the train is on long journey via DHL, so I guess it is hard to answer this question without some picture...
3. Can I run directly 3 rail DC loco (without any modification) on my digital layout using CS2?
BTW, its Roco 63422. From googling, I know that this is DC/GS loco.
Thank you.
BR,
Sony
#2 Posted : 28 January 2014 06:55:46(UTC)
Originally Posted by: sikardon Go to Quoted Post
Hello All,
Thank you.
BR,
Sony
If yours locomotiv wheels are non-isolated and has pick up shoe,you can easily drive on the 3 rail tracks.
If there is no decoder in this locomotiv and yours layout is digital,i suggest you put decoder in the locomotiv.
#3 Posted : 28 January 2014 07:54:36(UTC)
to convert a loco from 2 rail into 3 rail is much easier, whether its AC or DC. for instance I sometimes buy 2 rail DC loco for my layout, instead of having wires coming from the wheel set (+ and - ) you combine these wires (track current) the free soldering pad is now going to be used for your either middle contact and overhead pantograph.
When buying a second hand loco be careful it has a DSS (digital circuit board) and it has either an eight pin plug or a 21 pin board, all you have to do is plug the digital decoder into it if it has already a decoder and it suits you you can leave it in.
Most Roco locos come either in 2 rail or 3 rail and you can recognize them by their number e.g. 62..., 63.., 72... or 68...,69..., 78.... buying a second hand 2 rail loco make sure they also make it in 3 rail and than you have to get the bottom assembly to convert it into 3 rail or you wait until a suitable 3 rail loco comes along instead of converting it and buying extra bits for it.
Also with Roco locos (with these numbers above and there are some who had a DSS before the numbers 62 and 69 came along e.g. 43...
the benefits are: new motor type, DSS and ready to be converted to your liking with minimal fuss.
buying Roco steam locos is a different challenge, (most electric or diesel locos can out pull a Märklin loco because of its driven axles on both bogies), the driving force is in the tender and sometimes 2 or 3 axles are driven, the weight ratio motor-weight of tender is to minimal to pull a descent load and one loco I have BR 18201 I've used 2 motorized tenders.
comparing a Märklin Steam loco with a Roco steam loco and if you want to get onto equal footing you most probably need 2 Roco steam locos for 1 Märklin one.
I've bought a diesel loco which to date hasn't come out in 3 rail [there is no assembly for to convert it into 3 rail (wiper)] but here one has again options, you can add a 4 pin Roco electrical coupling on one end and use a Märklin carriage (with wiper or the possibility to add a wiper) also converted it with a 4 pin electrical coupling.
there are a lot of people (manly ignorance and people who never owned a Roco loco ) who think Roco locos are inferior because of the fact the housing is plastic but there is one particular loco which has a metal housing on both ends, the Swiss Crocodile, the middle housing is plastic.
When buying a Roco loco always make sure how many axles are driven, there are exceptions whereas the loco only has on bogy with driven axles
#4 Posted : 28 January 2014 09:19:11(UTC)
If you are indeed referring to Roco 63422, this is a 2 Rail DC model of a DB Class 290 Diesel. AFAIK this model was never released for 3 Rail DC (Trix Express). It is possible that somebody converted the loco themselves or had it done by a professional. An AC model was available under the number 69422.
From what I can tell, your model should either have been two rail DC or 3 rail AC. The AC lok would be equipped with a digital decoder that converts 16VAC to DC to power the motor.
It would not be too difficult for somebody to convert to Trix Express 3 rail DC. Most AC decoders can also work with DC.
Your best option would be to post a photo of the bottom of the bogies as well as a photo of the PC board showing the decoder, so that we can assess exactly what you have in your hands.
If you have any specific questions, you may be able to send them to service(at)roco.cc or roco(at)roco.cc.
Can you post a link to the actual auction?
Offline Markus Schild
#5 Posted : 28 January 2014 10:29:08(UTC)
Markus Schild
Hi Mike,
3-rail DC is misunderstandable. On one side there is the TRIX-EXPRESS-System which is a 3-rail-DC-system using one outer rails to supply one loco and the other for a second loco. The center-rail is common ground. This system also used special wheels which are not compatible.
On the other side there is also another 3-rail-DC-system which was used for example in France: Two outer rails for ground and the the center-rail supplies the loco. This system was also popular in Germany before the digital era. TRIX made special versions for this system with Märklin-style wheels and a DC-motor. On loco which were originally delivered for 2 rail-system you must just mount a pick-up shoe and insert a rectifier and a pole reversing switch between the transformer and the layout and you can use DC-models and traditional Märklin side by side.
Markus
Offline Ian555
#6 Posted : 28 January 2014 12:38:34(UTC)
Ian555
Hornby Dublo 3 Rail from the 1950's, used a solid center rail very similiar to Märklin's track from 1935- 1940's.
Ian.
3 rail.
3 rail.
3 rail.
thanks 2 users liked this useful post by Ian555
This page was generated in 0.352 seconds.
