Offline danmarklinman
#1 Posted : 17 December 2013 14:14:08(UTC)
danmarklinman
Hi could any one tell me please how heavy the Noch pre formned layouts are! My problem is i want a larger layout than i have already and the Noch layout 81610 is about the size i need. But i will need to take it up and down the stairs by myself. Any one have it or knows how heavy they are. i would be pleased to know cheers Dan
Wiking model car Fan
Instagram: marklin1978
Wiking fan
Offline alan
#2 Posted : 17 December 2013 15:45:05(UTC)
alan
I don't know the weight of the HO board
but I have a z gauge suitcase layout about 2 ft x 18 inches
and that only weighs 2k including the suitcase
alan plymouth
alan attached the following image(s):
thanks 1 user liked this useful post by alan
Offline Loadmaster
#3 Posted : 18 December 2013 04:25:37(UTC)
Loadmaster
Send an email to Dave at Itty Bitty Lines (www.ibl.com).
Robert
Offline Winterblade73
#4 Posted : 18 December 2013 04:41:18(UTC)
Winterblade73
Robert, your link goes to a basketball league.
The correct link would be www.iblproducts.com
Phil from SoCal
Member of ETE SoCal since 2011
ETE SoCal Facebook Page
Société Nationale des Chemins de Fer Luxembourgeois (CFL) Era III-VI
thanks 1 user liked this useful post by Winterblade73
Offline Loadmaster
#5 Posted : 18 December 2013 05:36:18(UTC)
Loadmaster
Thanks Phil.
Sorry I didn't make it to Del Mar.
Offline NZMarklinist
#6 Posted : 18 December 2013 06:18:31(UTC)
NZMarklinist
Hi Dan,
I have just the frameless plastic moulding of 81710 that I am incorporating into a larger layout. It is very light and no problem to handle on your own, and can be held by one hand and whilst the wooden underframe, which in the factory ones is approx 40x40mm timber, it still should not be a challenge, if your reasonably able bodied. That said the 81610 is 2m x1.2m and the size of carrying it up and down stairs could present a problem, especially once track and buildings are added. I would guess that the track with wiring and electronics, would add another almost 50% to the weight, !
Even a not so strong helper would be advisable to assist you if possible. In standard form the layouts need a table or frame with legs as per the Noch metal base frame system to stand on !
I am building my underframing for the whole layout in the "open" style using approx 120 x 12mm, dressed, timber. to which legs can be bolted in the corners !
No where can I find a weight quoted for these layouts, but suffice to say, the bare layouts are quite managable, size and space being the main concern !
Good Luck !
Glen
Auckland NZ
thanks 2 users liked this useful post by NZMarklinist
Offline Iamnotthecrazyone
#7 Posted : 18 December 2013 09:48:27(UTC)
Iamnotthecrazyone
I agree with the previous comment, I have handled a lot of them myself. Most of the bare layouts don't require a great amount of force to move them however, as they get larger they are a lot more prone to be damaged by hitting them against wall, step, etc so it is best to get someone to give you a hand. Often they never arrive in perfect condition and might already have minor cracks which are not a problem when everything is set up. However, if you are going to be moving it on your own be particularly aware of such problem because all the flopping about without a frame might substantially increase any existent cracks.
thanks 1 user liked this useful post by Iamnotthecrazyone
#8 Posted : 18 December 2013 10:44:58(UTC)
NZMarklinist
I think you can only buy them individually with the frame, and it did cross my mind that as they can be bought much cheaper in Germany from the likes of Lokshop or other Noch dealers, if I lived in the UK, and had a van or Estate Car, I would probably consider picking one up when over there for a holiday or other reason.
However they do actually come from Noch in a large reinforced box !
Glen
Auckland NZ
#9 Posted : 18 December 2013 10:51:17(UTC)
NZMarklinist
Actually what about taking the trip to collect the layout and everything including track, building models and all the scenery materials as well. The PDF lists on the nett for them are a good starting point for the shopping list ! Wink
Of course some extra Marklin could be included as well Sneaky
Arn't we good at spending other members money on this forum Laugh
Glen
Auckland NZ
#10 Posted : 18 December 2013 11:40:53(UTC)
danmarklinman
I think you can only buy them individually with the frame, and it did cross my mind that as they can be bought much cheaper in Germany from the likes of Lokshop or other Noch dealers, if I lived in the UK, and hyad a van or Estate Car, I would probably consider picking one up when over there for a holiday or other reason.
Arn't we good at spending other members money on this forum Laugh [/quote
Thanks guys for your help. I think I might just stick with a timber extension to my current layout, as you don't get much for the price you pay for a noch layout. Cheers Dan ps here is what I have done so farBigGrin
Wiking fan
#11 Posted : 18 December 2013 23:42:31(UTC)
Iamnotthecrazyone
Ahh... that's another point! Chances are that after you bought "exactly" the track listed on the instructions you'll find you'll need to make some changes :)
In regard of the frame I think I might be getting confused and only some parts were not attached like the base for tunnels. In any case the frame is not all that strong and what I've said about the cracks can still be a problem. Perhaps if you buy them individually you might have a better chance but many importers get them piled up or stored them squashed side by side because they take a lot of space and all the handling under those conditions cause damage.
Offline stevebkk
#12 Posted : 24 December 2013 20:28:56(UTC)
stevebkk
Thailand
Different question on Noch pre-formed layouts: I've been advised by an acquaintance here in the Far East that Noch layouts do not handle the heat and humidity that well over time. for example if you want to drill a hole in the mould to add something, the entire mountain may split open after being exposed to the climate for a few years. Does anyone have any experience in this regard because I'm planning to acquire the Noch Silvretta layout at the end of Q1? Confused
Offline zscalehobo
#13 Posted : 22 January 2014 02:32:29(UTC)
zscalehobo
stevekl:
I have not heard of this problem. The Noch layouts are quite thick plastic. I think the old Kibri pre-forms would have this issue, as they were nearly wafer thin.
For what it's worth, I have sold Noch pre-forms to customers in Singapore, Malaysia, Japan and China.
Frank Daniels
Owner
z.scale.hobo, a USA-based Noch dealer
Frank Daniels
Owner - z.scale.hobo
A Noch "Top Dealer"
Irvine, California, USA
www.zscalehobo.com
Offline zscalehobo
#14 Posted : 22 January 2014 02:37:41(UTC)
zscalehobo
The frame and layout by itself is roughly 15lbs (<7kg) ... if you have tracks and buildings on it, I might not recommend moving it around so much unless you have everything well-secured to the layout... however, it will still be quite lightweight. The girth may be difficult to easily maneuver through doorways and the like, so it is best to have someone helping you.
May be a dumb question ... but why do you need to go up and down with the layout?
Frank Daniels
z.scale.hobo
Frank Daniels
A Noch "Top Dealer"
www.zscalehobo.com
Offline zscalehobo
#15 Posted : 22 January 2014 02:46:45(UTC)
zscalehobo
Agree that cracking can be observed on Noch layouts during shipment ... HOWEVER, Noch has taken strides to improve their packing methods ... I have done what I can to help them via Failure Analyses and packing improvement suggestions along the way. They have gone on to use the wood supports around the boxes... this has pretty much eliminated the soft-handling issues.
However, there are still situations where a "herd of elephants" run over the boxes; Noch has been sending these insured ... so if it is damaged in transit nowadays, they will send a replacement.
Frank Daniels
z.scale.hobo
Frank Daniels
A Noch "Top Dealer"
www.zscalehobo.com
#16 Posted : 22 January 2014 04:46:32(UTC)
You might want to consider the Heidelberg type modular layout if you want to be able to move it around in sections
#17 Posted : 22 January 2014 04:59:47(UTC)
NZMarklinist
Actually you are right, the person I bought my one off was running Flieschmann on it and he said the track plans supplied tended not to fit exactly, and indeed the K track plans don't fit that well either, but you have to start somewhere to prove the plans anyway Mad
Edited by user 27 January 2014 08:34:34(UTC)  | Reason: detail
Glen
Auckland NZ
#18 Posted : 22 January 2014 06:51:31(UTC)
NZMarklinist
My one I bought second hand, rather cheaply, came without a frame and the owner had stored it in a van and one coner was help up by something allowing the summer heat inside the van to distort it. I have a flame throwing heat gun which I hope will help bend it somewhat back to shape, but appropriate framing could also cure the problem. I am considering suspending it in a periferal frame and applying the heat to the affected corner but it has been suggested to me by the owner of the said heat gun, that too much heat could totally deform it & I could end up with a melted mess on the floor Scared
Bare in mind those layouts are made from a sheet of plastic, heated in an oven then vacuum formed over a mould. Too much heat is not friendly to them Scared
I could imagine they may possibly harden with the heat and humidity, but have no evidence of such Unsure Mine is probably 10 years old and still seems quite flexable
I had originally planned to repair and frame mine, fit some track and basic scenery then sell it. However since getting Winrail and playing around in the total space I have for a layout, I've found some suitable extensions pretty much suit my needs, and the size will be 2.7x1.5m with a 800x1200 toe which will accomodate the round house. These Noch layouts do allow for extensions , both their's and whatever you can dream up Smile
(hope you don't all fall asleep waiting for My Layout" thread which will be done once I've got it sorted, but it will be slightly historical, but photographed Wink )
Glen
Auckland NZ
This page was generated in 0.555 seconds.
