#1 Posted : 09 January 2014 22:22:58(UTC)
Hey everyone,
I'm curious to get your opinions: for street lamps and related accessories, what voltage AC would you recommend using? I ask as I've always used 16V without thinking much as that is the back of a Marklin transformer and what they use for all their solenoid accessories, but I've recently encountered a few things such as a roco uncoupler requiring 12 V and light bulbs that were good for 18 V (presumably due to digital current?)
Anyways, any advice on an ideal voltage if you were going to run one accessory circuit around your layout?
-John
Offline Hoffmann
#2 Posted : 09 January 2014 23:02:52(UTC)
Hoffmann
Hello John,
I use a older Marklin Transformer (blue) . I hooked all my lights up to the brown and red terminal it lets me adjust the Voltage ( reversing and Max is locked ).
Those Transformer are cheap at any Train show just make sure the Cord is still in good condition.
Martin
P.S. I have a High Voltage Tester to make sure the Transformer is safe
marklin-eh
thanks 2 users liked this useful post by Hoffmann
Offline BrandonVA
#3 Posted : 10 January 2014 15:52:54(UTC)
BrandonVA
John,
I think in terms of "ideal" voltage, it's going to depend on what you're running. If it's all Marklin gear, 16v will probably be it. If there is a lot of other stuff, 12v may be more common. Using the "red output" method you may compromise and run at something like 14v, as long as the 16v accessories are still performing to your satisfaction (especially turnout motors, signals and uncouples). I am surprised the thread hasn't gotten more responses, but I would be willing to be the most common accessory voltage is going to be 16v.
-Brandon
Offline Renato
#4 Posted : 10 January 2014 19:29:04(UTC)
Renato
Hi John,
I fully agree with Brandon.
Renato
#5 Posted : 15 January 2014 13:05:08(UTC)
I use a TITAN brand 100VA trafo for lighting purposes.
It has two outputs; 16Vac and 14Vac. I use the 14V one. Hopefully I will get longer life for my lightbulps that way...
Offline jorge_vilarrubi
#6 Posted : 18 January 2014 20:08:34(UTC)
jorge_vilarrubi
Well... I've replaced all of my light bulbs with warm white leds, so I feed them with 12VDC. A 1k resistor is installed in series with every led.
Much less power consumption, minimal maintenance, almost no heat.
For turnouts/signals, they are digitally driven.
They are controlled by k83-like decoders connected to a Delta 6603 that works as a booster which, in turn, is fed from a 18V separate trafo.
In this way I have for sure that every mechanichal device will move in a clean way. Pulses are limited to 300 msec. from my Intellibox2.
Jorge.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
thanks 2 users liked this useful post by jorge_vilarrubi
This page was generated in 0.411 seconds.
