Offline zuurstof
#1 Posted : 28 December 2013 17:47:41(UTC)
zuurstof
Hello
Next problem occured.
A train n° 3657 digital adress 10 can be found in the database of the Central Station.
When put on the programming track it won't function.
If I put the same train (3657) on a track with a mobile station it is functioning normally.
What is the problem with the Central station?
Also I would like to bye some 2 hand trains with the same digital encoder butt they wont drive either.
I hope somebody can help.
#2 Posted : 28 December 2013 18:19:45(UTC)
Make sure that red (B) and brown (0) are wired correctly. Such old locos won't run if wires are swapped.
#3 Posted : 28 December 2013 18:20:02(UTC)
Originally Posted by: zuurstof Go to Quoted Post
Hello
3657 has dip switches and cannot program on the program track.
If this loco stand in the CS2 data base,you should scroll after it and accept it.
If you can´t,use program sequence in CS2 and check after if dip switch is correct as adress 10.
Offline zuurstof
#4 Posted : 28 December 2013 18:35:22(UTC)
zuurstof
Hello everybody
First of all. The CS is the CS1.
Second : I did a check on 2 other trainhs also witrh dip switches. And theyu work witout any problems.
To be certen I will check the connections of teh red and brown wire.
#5 Posted : 28 December 2013 19:24:29(UTC)
Newer locos with DIP switches work if wires are swapped, old locos do not work. Or do you have other 36xx locos with DIP switches that work?
Offline zuurstof
#6 Posted : 28 December 2013 20:34:42(UTC)
zuurstof
Hello Gents
Thank you for your reply.
When you look at the maual yo see the 2screws on the connector to the CS.
From ther you put the red wire on de right side and the brown on the left with the connctorscrews on top.
You can program a certan amount of trains without any problem until you get one that cant be done.
I checked the manual again and it mentioned dat the red wire must go to the right and the brown to the left.
Right but with the connectorscrews to the BOTTOM.
My train 3657 did function without any problem.
So did the other trains.
Thanks again and Happy New Year and many miles on the tracks.
#7 Posted : 29 December 2013 12:18:49(UTC)
Hi and welcome to the forum.
3657 was production in 1985/86 with c80 type decoder with dip switch.
Offline zuurstof
#8 Posted : 29 December 2013 13:50:06(UTC)
zuurstof
Hello Steventrain
Yes decode with dip switch.
But problem is solved.
Greetz
Offline eroncelli
#9 Posted : 30 December 2013 09:07:19(UTC)
eroncelli
Greetz
Please, let's know how you solved the problem Confused
#10 Posted : 30 December 2013 09:13:58(UTC)
By swapping red and brown wires.
This page was generated in 0.479 seconds.
