Offline BrandonVA
#1 Posted : 12 November 2013 16:29:09(UTC)
BrandonVA
I have a loco that I got on ebay a while ago (3304) that after some time has developed a slippage in the axles. Both the first and third axles slip. That is, the wheels on each side of the loco are able to turn independently of each other, and thus the loco binds up and gets stuck. The wheels were so loose I was able to pop them off the axle with almost no effort.
I took the valve gear off the loco except for the rod that connects the wheels. I tried to align the wheels by hand and apply a bit of Loctite, but I am having a lot of trouble getting the alignment right. Is there any trick to it, or do I just need more patience/skill?
Thanks in advance.
-Brandon
Offline Yumgui
#2 Posted : 12 November 2013 21:38:02(UTC)
Yumgui
Hi Brandon,
I have had the same problem ... and as much as I've been able to repair wobbly and loose wheel sets with LokTite on N scale locos and wagons ... it hasn't worked great on HO scale as precision and solidity needs augment proportionally to the scale ...
Unless you've seen this post already, I suggest you thoroughly read through abisel's post (there are others too) here :
3048 Drive Wheel/Axle Repairs and ...FINISHED
Some of Jacques' (jvuye) posts on "knurling" and "quartering" are very informative on these subjects :
https://www.marklin-user...FINISHED.aspx#post375137
https://www.marklin-user...FINISHED.aspx#post375499
https://www.marklin-user...FINISHED.aspx#post391808
I've concluded that it's the only way to go for HO and O scales, and therefore need to invest in a lathe and milling machine ... have even momentarily stopped buying trains in order to build up the necessary budget ^^ ;)
Can get very very involved ... yep
Y ThumpUp
Offline BrandonVA
#3 Posted : 12 November 2013 22:40:28(UTC)
BrandonVA
Thanks Yum. I have seen this thread before, one of the most interesting and beneficial threads I have seen. Anyone reading who has any interest in this should read the whole thing through.
You're right the Loctite is not a great solution for these. I may try and knurl the end of the shaft, but I don't have the equipment. Now, getting a lathe, etc is very tempting...it's been a while since I was in a true machine shop. But, I think I'd better resist, or at least for one loco.
It sounds to me from the linked post that to align the wheels, you pretty much just turn everything by hand on the track with the motor removed to see if you have it right. However, since the wheel will need to be pressed on, how do you get the alignment right at the press? I think I may be looking for a trick that doesn't exist, there are no alignment marks that I can see.
I don't mind the involvement, it sounds fun. This cheaply acquired 3304 may be a good learning case. However, at the same time...one may ask, is it worth it for this one little loco? :)
-Brandon
Offline Yumgui
#4 Posted : 13 November 2013 06:43:57(UTC)
Yumgui
Brandon,
Knurling without a lathe may be more than tough ;)
What I have done on the N locos is to file some notches or grooves at 45° angle on the axle before pressing on the wheel with LokTite ... gives the glue somewhere to go ... not necessarily a pretty site, but it works.
As for pressing straight you can get tins like these : http://www.fohrmann.com/...ahner/pressure-tins.html
... or make them with a drill press and some solid steel or brass tubing, need a sander too ... then press using a smooth jawed machinist's vise. While it has worked for me on N (most of the time), the slightest offset makes the wheel go on crooked on HO.
As for quartering, well ... I just eyeball it ^^.
Agreed that investing in these tools for just one loco doesn't make sense, but I have other projects as well, including making other tools ...
What I've seen one repair guy do is set up a hand drill upside down in a jig, he uses that as a crude lathe and manages to crank out new carbon brushes for old O scale locos ... he's had years of practice ;P
No magic solution for sure,
Y Wink
PS: Webmaster, abisel's thread should a sticky imho ^^ !
Agreed!
Offline BrandonVA
#5 Posted : 13 November 2013 14:11:52(UTC)
BrandonVA
Thanks Yum. This is all helpful.
I will have to decide what to do with the project. I am very interested in giving it a go. At the same time, I have a lot of other projects that probably should have priority (layout!!!), and a limited amount of to get them done. Luckily this is the only loco I have at the moment with this kind of problem.
As a curious side note, I have had a couple of 3318/3518 BR18.4 in the past that had this problem on the rear driving wheel. I don't know if it's more common with that model or if I am just lucky. I also have a 3604 with an earlier production date that got thrown in with a set of coaches, no problem with this one. The 3304 has the blackened wheels, 3604 with the silver.
In the end though, this 3304 is probably my fault. These are geared for low speed driving. One time a couple of years ago my son was driving it, and he cranked to the speed...it went fast for a moment, until the axle slipped and it bound up. I put it aside and never got back to it until recently. I hope I don't get in trouble with the Marklin police ;)
-Brandon
Offline Yumgui
#6 Posted : 15 November 2013 07:35:53(UTC)
Yumgui
Hehe,
He's not the only one. I've done that many times too ;)
Y Cool
PS: Good move Webmaster, thank you ^^ !
This page was generated in 0.276 seconds.
