Offline transform609
#1 Posted : 21 October 2013 09:22:25(UTC)
transform609
Turkey
Dear friends,
As you can see at the picture,i want to remove the digital decoder in from my old diesel lok for use the decoder on another dc lok.I do not know how can i remove it..I marked some places in the picture,is it enough remove from these points?
Also,if my other lok is digital schnitstelle,is it enough to remove only the small part on the fingertip of the cables?
Thank you very much
transform609 attached the following image(s):
#2 Posted : 21 October 2013 10:16:10(UTC)
609,
You've got an early ESU decoder (lokpilot) or even the early Roco decoders with an 8 pin plug.
If your other loco has the same digital socket all you have to do is take this one out by lifting it off and press it in into the other loco digital circuit board.
there are 2 things you have to be aware off:
a.) the decoder plug has to go into the position with the red wire facing a star on the circuit board
b.) make sure your other loco has a digital circuit board and not an analog.
having an 8 pin plug or a 21 pin circuitboard, this is the way to go and the advantages are, you don't have to do any extra soldering. the only wire which is not part of the 8 pin plug is your violet wire (Aux 2) if this has been used you have to unsolder it and see if you can use it on the other loco. if you can show us the other loco I will be able to tell you if its suitable. make sure you tell me the item number and who has manufactured it.
regards.,
#3 Posted : 21 October 2013 10:42:36(UTC)
transform609
Turkey
Dear John,
Thank you very much for the valuable information you gave.yes you are right,i should show the other loco for aim shot..I did not decide yet :) I will inform you soon,and thank you very much again friend..
This page was generated in 0.348 seconds.
