Offline Paul59
#1 Posted : 25 September 2013 15:14:38(UTC)
Paul59
Hi all, I have a 3356 Croc that I have converted to digital with a Marklin 60760 set including the 5 pole motor conversion. It runs ok but I think that the decoder is a bit too basic. In particular it has problems with the Alzheimer's effect on my less than perfect old M track. Occasionally it stutters and the loco then stops and starts again from speed step 0 and has to build up to the set speed again. It never stalls completely but this restarting from speed step 0 is very irritating.
I would like to change the decoder for a better one. Most of my other locos have Lokpilot 4s. I like these decoders but I have never tried one with the Marklin 5 pole motor. Do they work ok or would one of the newer marklin decoders be a better choice?
While I am chopping it about I have toyed with the idea of adding sound. ESU produce a Loksound with the correct sound files but I'm not sure if there is enough room to mount the speaker - has anyone ever tried this?
Mechanically the loco is fine.
I love this lok and feel that it deserves something better than it's got at the moment.
Any advice or suggestions gratefully received.
Thanks, Paul
#2 Posted : 25 September 2013 16:32:23(UTC)
Paul,
all my locos have ESU decoders but has nothing to do with my affiliation with ESU.
but you have to decide which one you choose.
as you know ESU decoders are fully programmable with a lokprogrammer you can also change the basic CV's with most digital systems
although you can program these converted locos with a 5 pole motor (in your case a 60961 set (drum collector)
I have found on occasions 60964 doesn't always work perfect but after changing certain CV's I've managed to achieve a smooth running.
#3 Posted : 25 September 2013 16:43:43(UTC)
Paul,
When you put the new decoder where the Delta decoder was (inside the loco "nose") then there should be enough room for a speaker in the cab.
ESU decoders work fine with the 60760 motor (same as 60941). I converted a 3356, but didn't add sound.
The ESU ECoS includes decoder user interfaces for ESU decoders that are very similar to the LokProgrammer screens, so decoder programming will be no problem (a LokProgrammer is required for firmware upgrades and sound project uploads).
Do you have the plastic version or the metal version of the 3356?
Do you have problems in curves? Märklin had a special magnet for the crocs to allow them to take curves but it's no longer available.
Offline franciscohg
#4 Posted : 25 September 2013 17:20:02(UTC)
franciscohg
Chile
Didnt know that curve problem was so spread......my upgraded 3556 tends to derail on curves in ramps, but as it where almost always well solved with fine adjustments on the banking of the curves, i thought that was only a problem with the track laying
#5 Posted : 25 September 2013 17:51:55(UTC)
Hi Paul,
I have numerous conversions, some with 60760, some with ESU LokPilot 2, 3 and 4, and a couple with the newer Marklin 60942 MLD.
I agree that the 60760 decoder is basic, but I am reasonably happy with the performance, especially where it has replaced a Delta decoder. The main advantage is the price, as you effectively get the decoder for free with the 5 pole motor parts.
The LP 3 and 4 offer finer running characteristics, but need a lot of messing about with the CVs to achieve good settings as they are not optimised for any particular motor. The LP4 in particular gave me problems with my 6021 to programme 3 digit CV codes, but this should not be a problem with more modern controllers. The LP2 had a really bad alzheimers effect. I am considering changing those in my earlier conversions.
My recent conversions with the mLd 60942 decoder have been very pleasant experiences. The decoder is optimised for Marklin 5 pole motors, so there is virtually no CV adjustments needed. mfx comes with the decoder, so users of the MS2 or CS2 have the advantage of auto-registration.
Mechanically, the decoder comes with a mounting board which fits exactly where the reversing unit or delta decoder went, and the decoder itself plugs in to this board. Easy as pie. I have no problems recommending this decoder.
At the end of the day it's your choice. Let us know what you decide.
Offline franciscohg
#6 Posted : 25 September 2013 18:09:36(UTC)
franciscohg
Chile
That is a good point, i am doing all my conversions now with the mLD and mSD kits, love the thing that they come with the mounting hardware for the board, also if you have a CS2 the programming is very easy to do.....self registration i have never saw as a very big thing, but doing all the function mapping without have to change CV's one by one is really good, you got that also with M4 lokpilots.....
#7 Posted : 25 September 2013 18:43:44(UTC)
I don't have a curve problem. I modified the field magnet to avoid any curve problems.
At first I considered installing an unmodified field magnet to see if I get trouble. But finally I decided to play it safe and modified it first.
And now I'm curious whether the modification was really necessary.
Here you can find a picture showing the special croc magnet (right) besides a normal magnet from 60760/60941:
http://www.stummiforum.d...pic.php?p=675927#p675927
And here the result of a DIY modification (not mine):
http://www.stummiforum.d...c.php?p=1008600#p1008600
Offline franciscohg
#8 Posted : 25 September 2013 20:18:47(UTC)
franciscohg
Chile
Thanks for the information Tom!
Took my Croc and checked, in fact it appears to be a little interference with the movement, but making it run, now there is no derailment at all.....BigGrin
Anyway, this one was my first modern loco bought about 10 years ago, a model wich i dreamt since a child, also it was my first conversion, so with much less soldering skills, the work was far to be perfect, so i did a complete rewire of it and a complete cleaning, i am very happy with her again now!!!!
Offline Paul59
#9 Posted : 26 September 2013 10:54:47(UTC)
Paul59
Wow, thanks for all the advice guys!
The lok originally was analogue with an electronic reversing unit.
I didn't modify the DC magnet when I first converted it to digital but I will modify it this time round as I have noticed a certain 'tightness in the track' in some curves.
If I decide to go the non sound route I think I'll fit a Marklin 60942 decoder as I've not tried one before.
If I decide on sound then I am torn between the ESU 64471 (eLok Croc) or the Marklin 60967 (eLok).
The ESU has the advantage of actual Croc sounds whereas the Marklin has generic eLok sounds. However the marklin has the advantage of being cheaper and possibly matching the motor better.
Hmm.... Decisions, decisions....
I think I'll take the lok apart first and check out what space is available.
Thanks again for the advice,
Paul
#10 Posted : 26 September 2013 13:31:26(UTC)
you have to ask yourself the question: a sound decoder and its cost is associated with the loco's motor functionality and other mechanical accessories
However the marklin has the advantage of being cheaper and possibly matching the motor better:. I don't think so.
have a look at this video from a SBB Ce 6/8 (3652)
#11 Posted : 26 September 2013 16:24:01(UTC)
Tom is right. I checked ny modified crocodilles. On the originally fitted 5* motor, a part is grinded off the top of the magnet. I have done the same on my modified ones. No curve problems.
Croc magnet
I cab make some better photos, if required.
Offline Paul59
#12 Posted : 26 September 2013 20:40:36(UTC)
Paul59
Hi River,
Your Croc does run and sound nice doesn't it?
Food for thought. If only the ESU Loksounds weren't so expensive Crying
I'll have a serious think about this.
Paul
Offline GlennM
#13 Posted : 27 September 2013 15:33:33(UTC)
GlennM
Nice long wood consist John ThumpUp ThumpUp
I am interested in this croc curve problem, and if I understand you correctly this problem exists only on analogue crocs converted to digital with the five pole motor?
I have several analogue and digital crocs which corner perfectly Confused Confused
BR
Glenn
#14 Posted : 27 September 2013 16:13:07(UTC)
This is a problem of locos where the AC/DC motor was replaced with a DC motor 60901, 60941, or 60760.
Factory-installed DC motors use different parts and don't have this problem.
#15 Posted : 27 September 2013 18:39:26(UTC)
another point would be how tied are your curves and this is not a problem on my layout
Guest (6)
This page was generated in 0.570 seconds.
