Offline Roman
#1 Posted : 09 August 2013 02:28:30(UTC)
Roman
Hello all,
Are the prototype diner's pantos up when rolling or at the station/siding? I haven't seen any films that depict them up while under way. Thanks.
Roman
Offline jlopez
#2 Posted : 09 August 2013 02:58:10(UTC)
jlopez
I remember reading somewhere that they only use them when they are stopped in a station/siding.
thanks 1 user liked this useful post by jlopez
Offline ozzman
#3 Posted : 09 August 2013 04:01:47(UTC)
ozzman
I think this question has been asked before, and from memory that was the answer, more or less. While the train is under way the kitchen draws power via a connection to the loco. However, I do stand to be corrected on this!
Gary
Z Scale
thanks 1 user liked this useful post by ozzman
#4 Posted : 09 August 2013 05:10:50(UTC)
The answer is correct, only when the SBB restaurant car is disconnected from the train does it use its own power supply of the kitchen appliance (stove, refrigerators, ventilation) and of course the AC when so equipped.
The pick up slider is not configured to sustain continued rubbing against the overhead line, it is a mere contact blade.
The pantograph folds automatically as soon as the car is moved to avoid any entanglement.
I do not know whether the process is the same with the DB/DSG coach but I would suspect so.
thanks 6 users liked this useful post by jvuye
#5 Posted : 09 August 2013 20:20:32(UTC)
I think Jacques' answer is bang on, although I was not aware that there was any difference in the wiper of the pantograph. I assumed that these were fully interchangeable with other similar models in use on loks.
Offline BR01097
#6 Posted : 12 August 2013 04:12:36(UTC)
BR01097
For most modelers, it's preferable to run the trains to follow the operation of the prototype, so I am very grateful for this detailed information.
However, now that I've bothered to wire the interior lighting of my TEE coaches to draw from the catenary in this practical way, it seems dumb to undo the set-up. Aha! I'll run them only at night with the pantographs extended so as not to be so noticeable.
Flapper
This page was generated in 0.256 seconds.
